Question about Crosley CDE6000 Electric Dryer
DRIER OVER HEATS, WORKS ONLY ON "FLUFF" CYCLE
MY DRIER OVER HEAT IF USE IT ON REGULAR CYCLE. IT WILL WORK ON "FLUFF" ONLY
  • 868 Answers
You need to have the thermostats tested by a qualified servicer.
Posted on May 21, 2008
Dryer won't dry clothes in one cycle
Make sure a heating cycle is selected. Air and Fluff cycles do not use heat.
Make sure that both phases of 120 volt power are energized (total of 240 volts between the 2 phases).
Most likely the heating element is damaged, which usually means there is no heat at all. A dryer with 2 heating elements will have some heat, but not have enough, when 1 heating element stops working. A dryer with 1 heating element can partially fail and have partial heat, too.
Apr 03, 2017 | Dryers
GE - Hotpoint Dryer Model # QUXR453EV2WW (2001)blows breaker what might it be
Shorted heating element. Fluff cycle does not use heat.
Sep 18, 2016 | GE Dryers
Kenmore dryer overheating on airfluff
driers that over heat may have the lint filter blocked preventing free air flow
check / clean it regularly
Have an accredited electrician / service agent check ti out
Nov 04, 2015 | Kenmore Dryers
How do I turn the heat eating down?
Need a make / model of the dryer your asking about. There are far to many out on the market. They work differently. But usually the settings are Regular is high heat easy care is medium heat. And delicates is a low setting for heat.And fluff is No heat.
Sep 30, 2014 | Dryers
Lg dryer dle7177 cutting off during cycle
I had a tumble dryer that stopped working and after much investigation it turned out to be an internal thermostatic switch and lots of fluff around the internal filters. ( Mine had 2 of them 1 would cut the heat and kick back in when the temperature dropped and the other one would completely cut all power rendering the drier non usable until cicuit breaker thermostat was replaced. The reason they cut out is to prevent overheating and possible fire. When the thermostat gets to certain temperature it breaks the circuit. Apparently you shouldn't stop the drier until it has completely cooled down as there will be too much heat which could cause a fire, which is why most drier cycles have 10 minutes of cool/ non heated air at the end. So in conclusion I would take all the filters out and give them a good clean and try to avoid opening the door while there is still a lot of heat in the drier. I'm not sure if this will help but its a starting point.
Feb 03, 2013 | Dryers
The signal dings at end of drying cycle but dryer keeps on running without heat
The drier works fine and heats during the cycle and then when the cycle is over the heat quits but the drier keeps running? Does it shut off when you open the door?
Aug 08, 2011 | Samsung DV330AE Dryer
My drier has stopped working i have changed the fuse but still nothing. Also how do i get to clean all fluff from the inside
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
Dryer Maintenance
heatman101
Dec 16, 2010 | Dryers
Whirlpool dryer LE6810XS110 timer only works on air fluff and tumble press does not work on regular or perm. press
Check to see if the unit will heat up in the time dry. if the heater does not come on in the time dry cycle, then you will need to change the thermol fuse on the back of hte dryer.
Oct 10, 2009 | Whirlpool LER4634J Electric Dryer
Crosley CDE6500AZW heating, but drum not rolling
OK Here is what I think happened. I have heard of this before. You melted a wheel and that broke the belt. This is a simple dryer to repair and parts are not that much. Well worth fixing. Start by popping the top remove the front then get the drum out and inspect the damage.
Mar 01, 2009 | Crosley CDE6000 Electric Dryer
Hoover Vision HD VHC391 saying it is full of water
My son seems to have fixed my dryer.
Although I followed the instructions about cleaning the filter after each cycle and the condenser after ten, fluff had blocked the drainage from the internal reservoir to the water collection bottle. It seems like this will be an ongoing problem, as even cleaning every time, fluff will gradually biuld up. The filter isn't good enough to stop fibres getting into the condenser and then into the reservoir behind it.
I expect that taking the cover off the reservoir to clean it invallidates a guarantee if you have one, but that is what my son did and now the dryer is working.
Jan 12, 2009 | Hoover HDV7FM Electric Dryer
Crosley CDE6000 Electric Dryer Logo
62 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
