Question about Indesit W 123 Front Load Washer
Indesit 1000 cycle starts but then lights flash
I put onto cylce 8. Water fills drawer on left but then door light flashes and the two end 'extra rinse' 'easy iron' flashes also, drum sounds like it' s turning but it isn't. Have turned it off and on several times, left it for 4 hours longest! please help, have alot of washing!!!
Check the filter which is under the white panel at the front of the machine(the filter is in the lower right hand corner). Unscrew the filter and remove it. Mine was blocked with loads of grease/limescale. I cleared it out and the machine is as good as new again. I cleared the system with half a packet of soda crystals put into the main drum (on its own without any washing in!) and did a wash at 90degrees. Its as good as new now. Good luck. CK
Posted on Jun 13, 2008
Indesit dishwasher idl40 s I have lights 1 and 3 flashing after shortly staring it's cycle. Then it empties and stops but there is no water hardly when I open the door. Any ideas please??
It would appear that the washer is not getting water, though it could be aborting the cycle early for some reason.
Try to google "Indesit dishwasher idl40s lights 1 & 3 flashing", and various permutations to see what others have said. At the least you need to understand what that pattern of lights flashing means.
There is an electric valve that the washer controls to allow it to fill with water when needed. This may be clogged or may have failed.
Pursue the flashing light issue first so you understand what the washer is complaining about.
Pete
Aug 30, 2015 | Indesit Dishwashers
My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
Some appliances malfunction can be displayed in hexadecimal or in binary code.
So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
" E20 " means "No drain water"
" E10 " means "No fill up water"
Dado
Sep 08, 2014 | Zanussi Washing Machines
Door lock and extra rinse light flashes
is it the tub that clunks?was it very noisy in the spin cycle?if so the spider gear is gone and it would be cheaper to replace the washer.you should only be adding two tablespoons of soap that's it,alot of people use to much soap and it eats at the spider gear,if you look inside the tub at the back wall you'll see a piece sign,that's the gear located on the back of the tub
Nov 09, 2017 | Washing Machines
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
WIDL126 flashing light No3 extra rinse). Machine starts to fill with water then the drum spins twice (a little too fast I think), then drains and just stops and the door lock light flashes fast along with...
If spin speed happening during what should be Wash speed then sounds like faulty speed control module/ could also be Tacho has fallen off end of motor;small round coil operated by a magnet which pulses a speed control circuit in the module/check also pump is okay and filter clean.Try resetting if you can,book will show you how to..Good luck
Apr 07, 2011 | Indesit Washing Machines
Indesit DIF 04 error lights halted cycle
i have a indesit dif 04 that starts a cycle fills with water and then the lights on door start to flash,leving all the water in the bottom?
Jan 10, 2010 | Dishwashers
Door locks, but will not fill up with water. Alarm sounds and lights flash once every minute or so
There is a rectangular magnet attached on the inside of the drawer for the detergent. Located on the right hand side near the front of the drawer. This magnet had come loose. Some glue and caulking worked well and the washer is working fine now. Meant to post this weeks ago.
May 12, 2009 | Kenmore Front Load Washer
Indesit IDL40 Slimline Dishwasher - Won't start cycle
indesit idl 40 not pumping water out properly, ends with flashing light no 4 and plates dry but water still in machine -have to pump out using start stop button but within 2 hours base filled up with water. Can't afford massive call out prices as lady on my own.....
Nov 12, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit WIL143S flashing lights
sounds like your power board is damaged. Did you get any washes out of it before it went wrong
Oct 08, 2007 | Washing Machines
Indesit W 123 Front Load Washer Logo
469 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
