Question about Diamond Audio D3-600.1 Car Audio Amplifier
Step by step instructions.
How should i wire 2 dual 2ohm subs to this amp?
  • 119 Answers
Here ya go:
Posted on May 22, 2008
I have 2 12 inch kicker rt dual 2 ohm subs. On a kicker cx1200.1 i want to kno how to hook it up to 2ohm to the amp. And if i can add another 10 inch kicker rt 2ohm sub in the future.
Do to the impedance Of your sub u can't run it @2ohms its going to either be @1ohm or 4ohms and your amp isn't 1ohm stable and u will risk damaging your amp. So your only option is to run it @4ohms and on a good note your sub is 100-600 watts RMS and your amp will push 400-500 watts RMS @4ohms. Now if you want to run 2 sub's in the future That amp will work perfect because it pushes 1,200watts RMS @2ohms and to wire your 2 sub's @1ohm just follow the steps in the image below. Hope this helped.25345194-v0hbouy2nvquqteoroa5j5rq-3-0.png
Dec 30, 2014 | Car Audio & Video
How to wire jbl gto7001 amp to put out 2 ohms to a dual voice coil sub
The wiring of the amp is not what makes it 2ohm or 4ohm, it is the resistive load of the sub, The issue is that your sub, assuming it is the L5 Kicker mentioned above has dual 2ohm voice coils, This means that if run in series will provide a load of 4ohms which will work fine but not make the most of the amp which would only be supplying 425w of it's potential 700w.
if you wire the voice coils in parallel you will end up with a load of 1ohm which will cook the amp.
here is a link to a page that explains how it all works.
Link:
Mar 04, 2012 | Car Audio & Video
How to connect dual vouice coil to amp
Hey well your gonna need to give more info. is the sub dual 2ohm dual 4ohm. if you have a dual 2 ohm you wire one + to one- (like a jumper wire)and then your other +.- go to your amp as 4ohms, if you have a dual 4ohm model and your amp can handel 2ohm stereo then wire your +to+ to +on the amp and the same for your -. it will bring a 4ohms to 2 ohms by connecting pos. to pos. and neg.to neg. then to your amp.
Jan 18, 2010 | Kicker CVR12 Car Subwoofer
I have 2 kicker l7 12 dual voice coil subs.. i just friend a hifonics 1600w amp and am wondering if a kx 1200.1 kicker amp will be enough to power them they are 750w rms a piece .. can these be run at 1...
it all depends on the impendance of your subs if u have duel 4ohm or duel 2ohm, 2 duel 4ohm speakers can be wired at 1ohm to the amp, and with a kx1200.1 that would be pushin 2400 peak and 1200rms
if ya have 2 duel 2ohm speaker than you can only wire them to 2ohm and would be pushing 1200 peak and 600 rms with the kx1200, so if you have the duel 4ohm i would go with the kx1200.1 and if u have the duel 2ohm i would go with the hifoncs
Apr 23, 2009 | Kicker KX1200.1 Car Audio Amplifier
I have 2 kicker l7's 4ohm, how do i wire them down to 2ohm?
If the subs are dual 2 ohm voice coils.....
  1. For a each sub, connect one of the "+" terminals on the sub to one of the "-" terminals. This makes each sub 4 ohms.
  2. Connect the unused "+" terminals of each sub together. Do the same with the unused "-" sub terminals. This makes the sub combination 2 ohms.
  3. Then connect the "+" and "-" sub terminals from the above step to the amp.
If the subs are dual 4 ohm voice coils, you can't connect both subs in any fashion to get a 2 ohm impedance. The best you can do is make a single sub 2 ohms by connecting both "+" terminals together and both "-" terminals together or the pair of subs 4 ohms by doing the same, then connecting one sub's "+" terminals to the other sub's "-" terminals, then connecting the other "+" and "-" terminals to the amp.
Apr 04, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Wiring options for amp
Te dual inputsm are tied together on the output side thus having a "MONO" amp. Most class D anps are stable down to 1 ohm (check your manuel) therefore, 2 2ohm subs are a 1 ohm load. 2 DVC (dual voice coil) 4 Ohm on each voice coil will give each sub a 2 ohm load so 2 dual4 ohm V's will give you a 1 ohm load as well. Parrallel all conections.
What subs do you have? Is this amp 1 ohm ono stable?
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Dec 09, 2008 | Car Audio & Video
Connecting a subwoofer to a mono amp that has 2 sets of terminals
ok this gets confusing sometimes. Ok first look to see what ohm your subs are. If you have a dual 4 ohm sub When you run that on sub + to + and - to - then that will make that sub 2 ohm. its different on ohm if the sub is say a 8 ohm then putting the wires that way will bring that sub to 4 ohm. Now lets say you have 2 subs that are dual 4 ohm and wire both of them + to + and - to - and go bridge the amp which would be both wires from sub both + together and both - wired bridge on the amp will make it a 1 ohm to the amp. Please post what ohm your subs are and i can tell you alittle more about it
Oct 21, 2008 | Verge VGA300M Car Audio Amplifier
Wiring my kicker solo-baric 15's
The best you can do is connect the dual 2 ohm voice coils of each respective sub in series (4 ohms total per sub) and then connect each sub to one channel of the amp. This will give each sub 1000W, which is the rated maximum from Kicker.
Mar 13, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Unsureness of wiring configurations.
Mamola,
Get an amp with at least 200 Watts RMS. The RMS value is what is important about driving Subs. This could be proclaimed to be a 1000 Watt amp. REad the RMS value.
Wiring. It is better to series your Speakers to give them and your amp more reliability,
Get a Mono or Bridgeable amp. If it si bridgeable, BRidge the output as described in the manual you get. Some Amps have a diagram right on the output..
AMP+ to Sub1 +
Sub1 - to Sub2 +
Sub2 - to Amp -
Get a 4 Guage wring kit. Run your power wiring down the Drivers side, and Audio signal wiring down the Passenger side, keep the two separate.
Nov 26, 2007 | Kenwood 12" 4-Ohm Single-Voice-Coil...
Diamond Audio D3-600.1 Car Audio Amplifier Logo
258 people viewed this question
Top Diamond Audio Car Audio & Video Experts
xxxxxx xxx
Are you a Diamond Audio Car Audio and Video Expert? Answer questions, earn points and help others
