Question about BenQ FP767 17" LCD Monitor
BenQ FP767 contrast keeps appearing
Hi hopefully you can help. The contrast setting keeps appearing and adjusting itself for no apparent reason. Have tried to recall the factory setting which it does but it still keeps happening, approx every 2minutes. Its very annoying.
Have changed the PSU in the tower to a 500W thinking there is not enough power this did not work. Have reinstalled the driver this did not work. Unplugged the power supply to my Geforce 7600GS this only gave me the sentinel warning. Why did it happen all of a sudden, I have it 3 years without a problem and now out of the blue this. Have unplugged for a day, this did not help. Have blown out the air vents this did not help. Any ideas. Im lost. Thanks in anticipation of a result
  • Losing it Jun 15, 2008
    thnx seems sensible to me after trying every thing else im sure this will work
    Champion:
  • 220 Answers
The problem is with front panel switches.The contacts maybe leaky.You need to replace all the six switches.
Samir
Posted on Jun 12, 2008
My BenQ FP767 monitor power is on, but the screen is black. my pc is very good.
open back cover of your monitor then adjust the screen control of the flyback to your desired brightness
Joel
Apr 20, 2013 | BenQ FP767 17" LCD Monitor
The color on my beige BENQ FP767 is blue i cannot fix the color schematics back to the default settings, please help
Blue cast on the screen? Then check all the pins on both ends of the video cable, try it on another PC to make sure it is not video card problems.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 22, 2010 | BenQ FP767 17" LCD Monitor
No backlight in Benq fp767-12 I have replaced all c5707 on inverter board and fu9024n and few capacitors but it still does not work
If you can expose it, examine the ends of the fluorescent tube itself; if there are prominent black rings at the end, the tube is toast. These cost much less to replace and live only about 4-5,000 hours, much shorter than the inverter board usually lasts. You can buy these from several US sources; the one I recently used was great and the part was $10:
CCFL Warehouse
Mar 06, 2010 | BenQ FP767-12 17" LCD Monitor
We have a Benq FP767. when we start the moniter than the screen appear blank and blinking LED light near on/off switch. what i do?
Have you attempted to enter the on-screen menu system for the monitor? There should be a reset system reset option somewhere in the menu selections. If not give that a try.
Also you might want to check your monitor cable. Unplug then replug it in. If you still have a blank screen you might want to try the cable on another monitor if that's possible.
If the cable is not the problem then that leaves the monitor itself or the video card if your system is equipped with one. Check the back connectors and locate the video output plug. If it is located close to the keyboard, mouse, Ethernet and usb plugs it is what's known as on-board video. If it is located below those other plugs it is a video card. Shut your system off and disconnect the power cable. Open up your case and make sure that the video card is seated correctly. They can come loose.
Your only other option is to try your monitor on another system.
I really hope something here helps. Good luck
Dec 29, 2009 | BenQ FP767 17" LCD Monitor
Auto Adjust keeps popping up
Is this a computer moniter or a tuner/tv
Aug 02, 2009 | BenQ FP71G 17" LCD Monitor
Benq monitor
Try checking the cables and disconnect all cables from system and monitor and reconnect all of them.
And in case it does not work,Please change the cable coming from tower to the Monitor as it seems that it has gone bad.
Hope this Help.
Cheers!!!!
Jul 22, 2009 | BenQ FP767 17" LCD Monitor
Computer monitor keeps auto adjusting screen
I have a Benq that was continually auto adjusting, I used electronic cleaner spray on all the controls (a good spray) and now there is no problem, suspect the controls were sticking, especially the on/off and the auto adjust button
Dec 20, 2008 | Computers & Internet
How to get audio from a benq fp767 lcd monitor
You have to plug the audio wire from the monitor into your speaker jack on your computer.
Jun 13, 2008 | BenQ FP767 17" LCD Monitor
BenQ FP767 17" LCD Monitor Problem
IT seems you are not technically trained in electronics.In this case it's difficult to explain via this board,Best you find someone to fix it for you,you can try contacting Benq Support locally.
Sorry for not being able to help.
Samir
Jun 07, 2008 | BenQ FP767 17" LCD Monitor
BenQ FP767 17" Power but no display?
Different faults here.
First fault is no power, it is bad capacitors on the power board.
Second & third faults are the inverters. (power but no image visible, but feint if you shine a light into the screen)
Check the 4 transistors on the main power board for shorts.
If you are unsure what that means, then take it to your local TV technician, he should be able to solve it fairly cheaply.
Hope that helps.
Oct 11, 2006 | BenQ FP767 17" LCD Monitor
BenQ FP767 17" LCD Monitor Logo
318 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
