Washing machine I have oil marks (3 lines close together) coming out from under the agitator on the bottom of the drum. The washer is a Amanna 12-14 years old and has not been over used or abused. Now its gotten worse on the next wash with lines of oil spreading out around the entire diameter under the agitator. Must be a seal that is failed and needs to be replaced. Can this be done from above or do I need to replace from underneath ??
  • 177 Answers
12 to 14 years on an Amana, (speed queen) built is about life on that machine, You need a transmission replacement. major work. You could have the machine rebuilt, which while it is being done, you would need a new belt, pump, brake pads, tub seal plus anything else that is rusted. You would be better off $$$ to replace the machine.
Let me know if you have any more questions. T
Posted on May 24, 2008
How do I remove the agitator on my GE Spacemaker model GSLS1100?
Remove Pulsator (Blue) cap,Pulsator nut, Pulsator, and 2 washers and 1 nut. Pull up on the drum. But, 1st ask yourself WHY you want to remove the agitator!
Jul 02, 2014 | GE Spacemaker WSLP1100D Top Load Washer
I have oil coming from under my 2003 ge profile washer agitator. How can I fix this?
The oil is coming from the transmission and it means the transmission assembly must be changed. There is no way to fix it other than replacement. Sorry. It's a big job, but there are plenty of videos on line now that show step by step how it's done. Let me know if you are interested in doing it yourself.
Jan 20, 2013 | Washing Machines
I am seeing a line of **** at the top of the drum even if I use bleach on my whites they are turning brown my dark colors have gray color **** on them is the washer too old?
There is a shaft seal under the agitator that may be leaking greasey oil.If your aagitator wiggles at the top .Or take off the agitator and look
Sep 22, 2011 | Frigidaire Gallery GLWS1339EC Top Load...
I have a GE top loading washing machine. The agitator has stopped working and the drum no longer spins at the end of the cycle when the water drains. What can I do to fix it and get the agitator...
When the agitator on your GE washing machine does not work correctly, the most likely cause is a worn drive bell. The drive bell sits on the agitator shaft inside the agitator. The shaft and the inside of the bell lock together using splines. When the splines inside the drive bell wear out, the agitator will not rotate correctly. To repair the agitator on the GE top loading washing machine, you will need to remove the agitator and the drive bell.
1. Unplug the GE washer from the wall outlet. Open the washer lid to access the agitator.
2. Grab the bottom of the agitator with both hands and pull the agitator out of the washing machine. If the agitator will not budge, rent agitator hooks to pry the agitator out. Agitator hooks are available at appliance repair stores. Set the agitator hooks under the agitator and push down on the handle to pull the agitator off the shaft.
3. Pry off the plug on the top of the drive bell on the agitator shaft with a small flathead screwdriver. Use a socket wrench to remove the hex head bolt at the top of the drive bell. Carefully pull the drive bell up off of the agitator shaft. This may take some force depending on how stripped the inside of the drive bell has become.
4. Inspect the inside of the drive bell. There are splines inside the drive bell that line up with the splines on the shaft. Most often the splines inside the drive bell have worn, causing the shaft to spin but not the drive bell. Also inspect the notch on the outside of the drive bell and the notch inside the bottom of the agitator. If either of these are worn, replace the drive bell and the agitator.
5. Take the drive bell to an appliance repair shop to purchase a new part. If you need to replace the agitator, take the old one with you as well. Compare the new parts to the old ones, making sure they are identical.
6. Position the new drive bell over the agitator shaft, lining up the splines on the shaft with the splines on the inside of the drive bell. Set the securing bolt back into the top of the drive bell and tighten the bolt down until it pushes the drive bell down until the bell bottoms out. Push the new plug on the top of the agitator bell with the palm off your hand until the plug locks into place.
7. Place the agitator over the drive bell and slowly rotate the agitator until the notch inside the agitator lines up with the notch on the outside of the drive bell. Tap the top of the agitator down with the palm of your hand until the notch on the agitator locks down over the notch on the drive bell. The agitator will not bottom out flush with the tub.
8. Close the washer lid and plug the washer power cord back into the wall socket.
The defective agitator is the cause of the drum not spinning. So get the agitator fixed and it should solve the spinning problem.
Good luck.
Apr 22, 2011 | Washing Machines
Can't remove agitator
Get 2 2x2 pieces of wood or 2 oak handles, 20 inches long. lay on on top of the other on the top of the washer. Loop a rope or ******** both sides of the agitator over one of the pieces of wood and tie it to the top piece of wood. Twist the top piece of wood slowly. As the 2 loops tighten up under the agitator the bottom piece holds the rope firmly across the top of machine. This save you from getting socked in the face by the agitator when it come off. You can buy an agitator remover but why not make you one and have so much fun doing it See the pic below? just ease a stick above the 2x4 and start slowly twing till she jumps out. Note: I didn't make this design I found it on line. I would run the rope under the agitator instead of taking a chance on breaking the fins. But that's just me.The trick is to grab it by the neck instead of the base. So try that before concocting a agitator remover. The agitator just snaps on. The drive block under the agitator is stripped out Wh43X10009 91c45a0.jpgis the part number. Here it the manual3c3b88a.jpg
May 25, 2010 | GE Profile WPSR3100W
Clothes coming out with grease marks on them ,washer jumping and not always completing sequence
seems like main bearing under drum is shot and transmission oil comming up. is this an old machine?
Jul 30, 2009 | Washing Machines
How do you remove the nut under the agitator? Ours is leaking gear oil from bearing under agitator. Have the agitator off. GE WBSR3140DW
theres nothing under your agitator, first take cover off your agitator there should be a small bolt
holding it down, take that bolt out then grab agitator from bottom and pull up it should come off easy.
Jun 09, 2009 | GE WBSR3140DW Top Load Washer
Baby clothes under the ringer
Loosening top plastic nut and removed top 1/2 of agitator, then loosened nut to lift out bottom 1/2 of agitator.
Jan 02, 2009 | Kenmore 24032\24036 Top Load Washer
GCXR2080t - top load washer problem
direct drive has broken simple 3 dollar part and changing out is simple turn washer over after disconnect take out motor you will see this part
it comes in 2 parts they both fit together this is direct drive
put back together way you took out motor too and then turn upright connect everything and turn on washer this should be the problem
also since your down there under washer replaceing part get appliance oil and oil all major movable motor mechanical parts
Jun 10, 2008 | GE WBSE2090A Top Load Washer
with the exeption of something you mistakenly left in your clothing and wound up in the washer, not likely stains are from there , most of the time they do come from the dryer, try grabbin an old white rag nad runnig it around hte fron of hte dryer drum and then tyr the rear where the drum meets the back bulkhead. usually leavs brownish streks smome what curved 2-3 inches log. its from hte felt hte supposed to seal the drum. its either wearing thin, or a glide has worn away causing the issue
Mar 22, 2008 | Whirlpool LSR7333 Top Load Washer
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
