Question about Samsung CLP-510 Laser Printer
Low heater error
This the messege, engine fuser low heat, what i have to do?
  • 3 Answers
I bought another second hand one for € 40,00 and replaced the unit. It's just 5 screws and on we go again.
I have a CLP 500 and bought a CLP510N. The units are the same. unfortunately not all parts on the machine are the same, but for now mine works again.
Posted on May 26, 2008
Error Engine Fuser low heat
possibly the fusers thermostat is displaced. it rides very close to the roller to get an accurate reading, look for 2 wires into a black "thing" toward the middle of the roller. this is a thermistor which sends its reading to the mainboard. check if the fuser is getting very warm, there is a thermo couple in series with the fusers power so it wont overheat but if its getting hot and the printer doesnt know it then the dammaged/displaced thermostat would be the thing to look for,
Sep 28, 2009 | Samsung CLP-600N Laser Printer
Engine Fuser Low Heat Error
You need to replace the fuser in the printer, the part number is JC96-03406A You can do a google search for the best price.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Samsung ML-3561N Laser Printer
Low heat error
the fuser is defective and needs to be replaced.
Jun 11, 2009 | Samsung CLP-600N Laser Printer
What this means is that the fuser is not reaching operating temperature. The most common reason for this failure is the xenon lamp inside the heat roller of the fuser has burned out. You can verify this by checking for continuity between the two contacts that connect to the lamp with an Ohm meter or digital multi meter.
If the continuity is good, the second most common reason for failure would be the LVPS, or low voltage power supply.
And last, although by far the least common reason for this error is the main logic board.
Have you checked to see if the unit is under warranty? If so, this would be a covered repair.
The part number for the fuser is listed below. Depending on your location and electrical system ( 110 or 220 )
ELA UNIT-FUSER 230V part number :JC96-03239A for use with 230V
ELA UNIT-FUSER 110V part number :JC96-03239B for use with 110V
Other then samsung, you can try a google search, and also an ebay search for the part number and find the best price for the item.
Good luck,
Cory
Nov 04, 2008 | Samsung CLP-510 Laser Printer
"Low Heat Error"
Thats probably the best way to solve the solution. Sometimes if there is a thermistor that is causing the problem that can be serviceable in the fuser unit, that can be replaced instead of purchasing a whole new fuser assembly. It's less expensive replacing the thermistor.
Jul 16, 2008 | Samsung CLP-600N Laser Printer
How do I fix an Engine Fuser Low heat error on printer:
UNPLUG AND REMOVE 5 SCREWS ON THE FUSER HOUSEING . CK WITH METER TO THERMOFUSE
Nov 05, 2007 | Samsung CLP-550N Laser Printer
THERMO FUSE OR THERMISTOR DIRTY OR BAD
Low heat problem
Maybe it wants to be in the sun....???  Excuse.me um .. 95% chance it doesn't, it Needs a fuser assembly, the machine fails to come to temp., ie heater lamps or thermister in fuser are Kput! Danger 240v no play zone please call a teco
Oct 16, 2007 | Ricoh FAX2210L Plain Paper Laser
there is a 2 wire device (thermistor) that rests against the fuser roller to measure the temperauture. if the fuser is getting quite hot, suspect the thermistor to be either dirty (remove and clean it with alcohol) or defective. if fuser not getting hot, then suspect burned out fuser heater (look inside fuser roller for a long light bulb).
Aug 28, 2007 | Samsung CLP-510 Laser Printer
Basically the error message is telling you the printer cannot keep the fuser temperature at the proper temperature (too low). It could be a lot of things but typically it is due to a fuser assembly gone bad.
Feb 20, 2007 | Samsung ML-2551N Laser Printer
Samsung CLP-510 Laser Printer Logo
441 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
