Question about Zoom H4 Handy Recorder
Recording with Peavey 480 mic
I have a Pesvey 480 mic that requires phanom power between 9 and 52 volts. I bought a xlr to mono 1/4 " cable...changed to external input, tried both 24 and 48 phanom power and could only hear a hum on the headphone. Is the 1/4 mono jack OK or does it require a stere 1/4" Is the power applied to the audio input?
Earl askearl@bellsouth.net
  • ng7p May 21, 2008
    Thanks for your response. AFTER A CLOSER LOOK, it appears the H4 accepts both a 1/4 " and XLR connector...Thanks for putting me on the right track.
    Earl
  • 4,234 Answers
In order for phantom power to work, you need a balanced cable. That needs 3 conductors. With the mono cable you do not have the phantom power available.
Dan
Posted on May 21, 2008
I just bought a tascam dm 3200 i plug my mic in xlr inputs but cant receive any signal, the manual doesnt tell me how to set up mic for each channel and not sure how to connect to active speakers
This is a very powerful mixer, what do you plan to do with it? Did you receive manual with unit? the manual may take several readings as thus may require steps in a certain order.
XLR is a type of input connector. A microphone is not a microphone. Is your mic a dynamic or condenser mike? The condenser mic requires phantom power is it on? Are you using quality cables or inexpensive cables Does make a difference. The unit has outputs.. Let me know what help you need. Also the best solution would be to call Tascam they will help you.
Mar 24, 2018 | Tascam Audio Players & Recorders
I just bought the GXL2200 CAD microphone without the cabels,(thought they would've came with), what kind of cable do i need?
As with most microphones, these mics use XLR cables. You can get them online or in a music store in many different lengths. What you need is XLR male to XLR female, though most of the consumer-level stores will probably just call them "mic cables." Note that the thing you're plugging into will need to have an XLR input, and will need to provide phantom power in order for that mic to work.
Nov 09, 2013 | CAD Microphones GXL2200 Professional...
What is the best way to run the mic on desktop
Your condensor mic requires special electrical handling usually reserved for proffesional audio equipment, not a PC. You will need two pieces of equipment, a short XLR cable and an adapter cable.
1) Behringer PS400 Ultra-Compact Phantom Power Supply.
This will supply the mic with necessary Phantom Power.
2) Rapco Horizon ISOBLOX Transformer Isolation 1:1 BLOX Device
This will isolate the Phantom Power from your computer, allowing it to work as necessary.
The adaptor connector cable you need will be a female XLR (with pins 1 and 3 shorted, pin 2 hot), through a cable connect to a 1/8" mini plug. They connect in that order with a short XLR cable between 1) and 2). .
Aug 23, 2012 | CAD Microphones GXL2200 Professional...
Hello, i've just bought a sure sm58 mic so i thought i would get a good cable to go with it, i purchased a (Planet Waves 10 feet Custom Series 1/4 inch XLR Balanced Microphone Cable) but when connected...
Where do you connect the 1/4 inch connector? At the same device (karaoke)?
Also check and report if the 1/4 inch connector is "mono" or "stereo"
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
May 16, 2011 | Shure SM58 Professional Microphone
I have a gxl 2200 mic and my computer acknowledges the mic but i cant record anything because when i play it back there is no sound
You'll need a phantom power source, like an interface or mixer. Otherwise, the mic is likely in need of repair.
Sep 19, 2010 | CAD Microphones GXL2200 Professional...
Where to buy a XLR cable extension in Fremont ca required for a Peavey XLR560 power mixer
You can buy them at Radioshack.
39106 Fremont Hub
(between Argonaut Way & Mowry Ave)
Regards,
Gerard
Mar 19, 2010 | Peavey Monster Studio Pro 1000 XLR-XLR Mic...
Mic snaps and cracks when you move the cords. Have changed cords several times. Something may be loose in the mic.
Try tightening the set screw in the tail of the mic near the XLR connector. I that doesn't work it's got to be some loose internal connection.
Apr 12, 2009 | Peavey PVM 480 Professional Microphone
AKG Perception Microphone ony recording in mono but want stereo.
I have similar problems with inputing stereo sound. How do you know your mic port on the PC is set for stereo? What kind of a cable are you using? If it is an XLR, the connection is pure mono. Maybe you need a TRS cable, which looks like a 1/4 inch jack but is really stereo. Maybe you need a stereo mini. Usually a cable mismatch is the problem. Is your phantom power supply passing stereo? All the ones I have seen are mono. You may need two. Is your sound capture set for stereo? Are the input level controls set correctly for equal volume on left or right channel? I would try the mic with a regular amplifier to insure both channels are working. Then trace the signal from mic to power supply and power supply to computer.
Dec 03, 2008 | AKG Perception 100 Microphone
External stereo mic into camcorder not recording audio
You cannot simply attach a mike with a 3.5mm jackplug by using an XLR adaptor, the connections are all wrong. The only way to connect an XLR mike to the XM2 is by using an adaptor like the Beachtek XLR adaptor which is a superb bit of kit. I can't be certain of your problem but may I suggest possibilities? I wonder if the adaptor you bought was a stereo adaptor. If it looks like a larger version of the original plug then fine, if it has only the one long metal contact along the pin and then the tip separately, it is a mono adaptor. Using this on a stereo mike would work but it would be combining both channels into one which would degrade the sound and could give rise to your noise issues. If you have got an adaptor that is stereo, is it just the push in type? You can get adaptors that have a threaded barrel to screw the adaptor to the normal plug to lock them together tightly. If it hasn't got that, I would try putting the adaptor on the mike's 3.5mm plug and then taping it together to hold them very tightly together. This will stop minute movements between the two causing buzzing and other noises. I hope you find that of some help, my apologies if not. Rob
Mar 08, 2007 | Canon DM-XM2 Mini DV Digital Camcorder
Zoom H4 Handy Recorder Logo
78 people viewed this question
Top Zoom Audio Players & Recorders Experts
Jaysan Lunt
Level 1 Expert
Paul Bade
Are you a Zoom Audio Player and Recorder Expert? Answer questions, earn points and help others
