Question about Canon PIXMA MX310 All-In-One Printer
Picturess cannon mx310
I was under the impression that there was a memory card insert on my printer.  So I haveo n or am I simply not seeing it?
  • 2,016 Answers
In the US, neither the MX300 nor the MX310 have a memory card slot (I'm not sure about other areas). In order to get the memory card reader, you would have to get the MX700 or MX850 (fax capable), or the MP470 or higher (number).
Posted on May 21, 2008
Once I insert a camera memory chip in to the Printer, how do I upload the photos to my computer?
Assuming you have a PC, insert the card into the printer, then open up "My Computer". There should be a drive letter there that wasn't there before, probably F:, but maybe G: or H:. Open this drive and locate the photos. You may have to open a couple more folders in that folder depending on the camera brand that was used to take the pictures. Then create a folder on the desktop and name it, and drag and drop the photos into this new folder. When finished, Simply drag the new folder and place it where you want it. This is all assuming that a dialog box doesn't come up when you insert the card asking you what you want to do with the pictures. When you insert the card, wait a second and see if a box opens asking you what you want to do with them, and then follow the instructions. Let me know if you need more info.
Sep 30, 2010 | Brother MFC 420CN All-In-One InkJet...
Is it possible to get the disc to install the Cannon Pixma MX310
http://www.soft82.com/download/windows/canon-pixma-mx310-all-in-one-driver/
just go to this link and clilck where it says "free download" at the top, this will install the driver on your computer, you don't need the disc. Hope that's what you were looking for.
Jul 28, 2010 | Canon PIXMA MX310 All-In-One Printer
5800 MMC NOT WORKING
If you Nokia 5800's memory card is not working.
It simply means there is a problem or two,
1. the phone might not be reading the memory card,
2, the memory card might be faulty.
test to know if it is the phone,
  1. insert the same memory card into another phone to see if the phone will read it.
  2. insert another tested okay memory card into the phone to see if it will work.
  3. if it does not,then the fault is from the phone,
to fix this,
  1. get the appropriate screwdriver,
  2. open the phone,
  3. carefully open the memory card slot,
  4. clean it properly with naphthalene and dry it under the heat of a bulb,
  5. or you can replace the memory card slot completely,
  6. insert the memory card and turn it on to see if it will read it.
  7. before you couple it back together.
To test if it is the memory card
  1. insert the memory card into another phone to see if it will do the read it, if it does not, then the fault is from the memory card.
to fix this
all you have to do is to change the memory card.
take care
Jun 18, 2010 | Nokia 5800 XpressMusic Smartphone
Trying to add pictures on to phone by memoryy carddd`
Your device is, most probably, not recognizing your card's formatting rules. Save all the card's contests to anywhere you want on your PC. Then, install this program on your PC and run 'SDFormatter V2.0' (under 'C:\Program Files\Panasonic\SDFormatter') to format your card.,Copy the files previously saved back to it, and insert it in your device.
Hope it works for you.
Cheers! Carlos
Apr 15, 2010 | HTC Touch P3450 Smartphone
Where do u insert memory card in samsung impression a877
well on the back of the phone where the battery is, its right next to the sim card. to the left side of it and u see a small slot. Note: insert the micro sd card upside down. insert with the gold part up facing you
Dec 20, 2009 | Samsung SGH-A877 Impression Cell Phone
I just received a fax on my Cannon Mx310 but I
mailcenter12 --
Here are the instructions for retrieving the fax's from the memory:
(I found this at: http://safemanuals.com/annexe_MX310%20series%20Easy%20Setup%20Instructions_CANON_PIXMA%20MX310-_E.htm
�� Printing a List of Documents in Memory
The machine can print a list of documents stored in memory (the memory list) showing the
transaction number (TX/RX NO.), transaction mode, recipient, number of pages, date, and
transmission time of each document. When printing or deleting documents in memory, specify a
document by its transaction number.
1 Press the FAX button, then press the Menu button.
2 Press the [ or ] button to select MEMORY REFERENCE.
3 Press the OK button two times.
The memory list is printed.
�� Printing or Deleting a Document in Memory
3 Press the OK button.
Hope this helps!
-- RT
PS - If useful, don't forget to vote!
Sep 16, 2009 | Canon PIXMA MX310 All-In-One Printer
"set ink cartridge" message on Cannon pixma MX310
pull them both back out. Put them back in until they click. When you put them in push them on an angle
May 07, 2009 | Canon PIXMA MX310 All-In-One Printer
I'm setting up a PIXMA MX310 printer for the first time. After plugging it in and turning it on, it gives me a 5100 error.
I called 1-800-OK CANNON and got a great tech who figured out I'd neglected to take off some packing tape that was UNDER the LCD/control panel in the front—where the paper is loaded. Duh.
Aug 04, 2008 | Canon PIXMA MX310 All-In-One Printer
Help with setting up my cannon mx310 fax machine.
here http://www.generalmanual.com/Printers/Canon-PIXMA-MX310-Office-All-In-One-Printer.htm you can download (under "download now" near the bottom of the page) the manuals you have lost.
Hope it helped you!
Dont forget rating.
Thx.
Jan 19, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
67 people viewed this question
old marine
old marine
