Question about Vacuums
Irobot run then shuts down-says check brushes-brushes clean-also when running does not pick up hair, and such on carpet.
  • 868 Answers
Has a internal short.
Posted on May 21, 2008
Took Roomba apart to clean and now the pick up brushes start and stop during cleaning. The vaccum is clean but will not constantly spin. Runs great but pick up brushes start and stop. Is there a number...
You can go to www.iRobot.com . This is the roomba website. You should be able to find replacement parts, customer support, videos or the Roomba product, and more.
When you cleaned your Roomba, did you also clean the wheel wells and outer most edges of the brush brush cartridges? There can be lint, threads, and at my house, cat hair, wrapped around the outermost edges of the brush cartridges.
I hope my suggestions help. If so, please contact Fixya and rate my solution.
Thanks and Good Luck!
Dec 02, 2010 | iRobot Roomba 530 Robotic Vacuum
Bin barely fills. Lots of dog hair between brushes and bin, and is now dropping hair balls as it goes around the house
This is why Roomba recommends a thorough clean of your carpet with a standard vac prior to using your mini vac. Once all heavy debris has been removed, the roomba will maintain that state of clean. If you have that much dog hair, you cant expect such a small roller, brush and dustbin to keep up. sounds like you need the dirt dog instead. It is capable of handling heavier demand areas. Or the
iRobot Roomba® 562 Pet Series
Feb 17, 2010 | iRobot 560 Roomba Vacuuming Robot, Black...
IRobot stopped picking up larger bits from the carpet. It picks up the dust, but anything larger, it leaves behind. Have changed the filter/brushes. Is there anything else I need to do
Its sounds like the brushes aren't turning. Pull the vacuum and bin off the back and start it and look to see if the brushes are turning.
Sep 29, 2009 | iRobot Roomba 560 Robotic Vacuum
Irobot roomba brush only spins on hardwood/tile. brush stops when it hits carpet. motor prob's? fix?
Remove and clean the yellow bearing on each brush, then reinstall them. Run the Roomba and ensure that the brushes do turn on hardwood, then test it again on carpet. If the brushes still stop turning on the rug, call customer support at 1-877-855-8593. They'll be able to determine your warranty status and discuss your options.
Aug 05, 2009 | iRobot Roomba 4300 Robotic Vacuum
My roomba 4150 is running very slow. It is fully
may need to clean inside.the wheels pick up trash and deposit it on and near motors.also try to take ends of roller brushes off and clean hair ect.
Jul 09, 2009 | iRobot 4150 Roomba Vacuum
Irobot roomba 560
Ah ha!!! After cleaning the brushes umpteen times I worked out that you have to remove the very small yellow pieces (not the other ones which sit on the end) but the ones right on the end and look for hair that is caught on the spindle. No more clicking noise either!
Apr 12, 2009 | iRobot Roomba 560 Robotic Vacuum
IRobot not picking up dirt
try to replace the filter, that should work.
Feb 23, 2009 | iRobot Roomba 530 Robotic Vacuum
Irobot runs for awhile then says check brushes, brushes are clean, also doesn't pick up obvious debris
if its running id say check the in take for something blocking the in take as ive never had hands on with ibot cant be specific on the procedure if its not sensing in coming then it will think the brushes aren't working
May 21, 2008 | Vacuums
Vacuums Logo
41 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
