Question about Compaq Keyboard
Presario arrow key and return key problem
Since last couple of days, the return key jumps one page instead of one line and arrow keys move in staggerred way in Excel. So If I start with cell A1 and hit right arrow key, it moves to cell B2 instead of B1. If I hit return it goes from cell A1 to A38. how can I fix this?
    Problem Solver:
  • 6 Answers
Examine the keyboard for dirt caught under the keys, this maybe diffucult to spot. this is not going to be easy at first, as the problem may lie further and at a more difficult angle, check also for damage to the keyboard and try to find a mechanical solution before suspecting the drivers here, as this looks like it may just be something caught under the keys, or the keys being dragged down together rather than a major electronic foulup.if you find nothing, then suspect drivers. after that, try checking for programming errors.
Posted on Jun 08, 2008
Curser is set to move by the arrow keys. how di I get it to go back so I can move it through my keypad
most probably you accidently hit the scroll lock button.
press the scroll lock button again.
-----Original Message-----
I must have hit a control function. Now instead of
moving up/down/left/right
in
individual cells, I am moving the whole page. Any Ideas?
Thanks
Ike
Oct 04, 2010 | Acer NSK8458AN Keyboard
Several keyboard keys on my Presario CQ60 do not work... i.e. backspace, delete and any directional arrow keys. Can I reinstall a drive and fix it? Mike
it seems the the middle part of the Keyboard circuit is having the Fault
Backspace arrow and delete keys are located in the middle area the Keyboard
I think its a problem with the Hardware --
Need to change the Key board -- (PROBLEM is with the Keyboard)
if its possible then try with another keyboard
Jan 08, 2010 | Compaq Keyboard
Arrow keys moving whole page instead of cells
highlight a cell then try using the arrows
Dec 30, 2009 | Logitech 967437-0403 Keyboard
Backspace and up arrow keys seam to stick
blow into the arrow keys and into the backspace key(maybe some dust is malfuncioning the keys
Jun 12, 2009 | Logitech Cordless MX Duo 967300-0403...
Guide
General keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • CTRL+C (Copy)
  • CTRL+X (Cut)
  • CTRL+V (Paste)
  • CTRL+Z (Undo)
  • DELETE (Delete)
  • SHIFT+DELETE (Delete the selected item permanently without placing the item in the Recycle Bin)
  • CTRL while dragging an item (Copy the selected item)
  • CTRL+SHIFT while dragging an item (Create a shortcut to the selected item)
  • F2 key (Rename the selected item)
  • CTRL+RIGHT ARROW (Move the insertion point to the beginning of the next word)
  • CTRL+LEFT ARROW (Move the insertion point to the beginning of the previous word)
  • CTRL+DOWN ARROW (Move the insertion point to the beginning of the next paragraph)
  • CTRL+UP ARROW (Move the insertion point to the beginning of the previous paragraph)
  • CTRL+SHIFT with any of the arrow keys (Highlight a block of text)
  • SHIFT with any of the arrow keys (Select more than one item in a window or on the desktop, or select text in a document)
  • CTRL+A (Select all)
  • F3 key (Search for a file or a folder)
  • ALT+ENTER (View the properties for the selected item)
  • ALT+F4 (Close the active item, or quit the active program)
  • ALT+ENTER (Display the properties of the selected object)
  • ALT+SPACEBAR (Open the shortcut menu for the active window)
  • CTRL+F4 (Close the active document in programs that enable you to have multiple documents open simultaneously)
  • ALT+TAB (Switch between the open items)
  • ALT+ESC (Cycle through items in the order that they had been opened)
  • F6 key (Cycle through the screen elements in a window or on the desktop)
  • F4 key (Display the Address bar list in My Computer or Windows Explorer)
  • SHIFT+F10 (Display the shortcut menu for the selected item)
  • ALT+SPACEBAR (Display the System menu for the active window)
  • CTRL+ESC (Display the Start menu)
  • ALT+Underlined letter in a menu name (Display the corresponding menu)
  • Underlined letter in a command name on an open menu (Perform the corresponding command)
  • F10 key (Activate the menu bar in the active program)
  • RIGHT ARROW (Open the next menu to the right, or open a submenu)
  • LEFT ARROW (Open the next menu to the left, or close a submenu)
  • F5 key (Update the active window)
  • BACKSPACE (View the folder one level up in My Computer or Windows Explorer)
  • ESC (Cancel the current task)
  • SHIFT when you insert a CD-ROM into the CD-ROM drive (Prevent the CD-ROM from automatically playing)
  • CTRL+SHIFT+ESC (Open Task Manager)
Dialog box keyboard shortcuts loadTOCNode(2, 'moreinformation'); If you press SHIFT+F8 in extended selection list boxes, you enable extended selection mode. In this mode, you can use an arrow key to move a cursor without changing the selection. You can press CTRL+SPACEBAR or SHIFT+SPACEBAR to adjust the selection. To cancel extended selection mode, press SHIFT+F8 again. Extended selection mode cancels itself when you move the focus to another control.
  • CTRL+TAB (Move forward through the tabs)
  • CTRL+SHIFT+TAB (Move backward through the tabs)
  • TAB (Move forward through the options)
  • SHIFT+TAB (Move backward through the options)
  • ALT+Underlined letter (Perform the corresponding command or select the corresponding option)
  • ENTER (Perform the command for the active option or button)
  • SPACEBAR (Select or clear the check box if the active option is a check box)
  • Arrow keys (Select a button if the active option is a group of option buttons)
  • F1 key (Display Help)
  • F4 key (Display the items in the active list)
  • BACKSPACE (Open a folder one level up if a folder is selected in the Save As or Open dialog box)
Microsoft natural keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • Windows Logo (Display or hide the Start menu)
  • Windows Logo+BREAK (Display the System Properties dialog box)
  • Windows Logo+D (Display the desktop)
  • Windows Logo+M (Minimize all of the windows)
  • Windows Logo+SHIFT+M (Restore the minimized windows)
  • Windows Logo+E (Open My Computer)
  • Windows Logo+F (Search for a file or a folder)
  • CTRL+Windows Logo+F (Search for computers)
  • Windows Logo+F1 (Display Windows Help)
  • Windows Logo+ L (Lock the keyboard)
  • Windows Logo+R (Open the Run dialog box)
  • Windows Logo+U (Open Utility Manager)
Accessibility keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • Right SHIFT for eight seconds (Switch FilterKeys either on or off)
  • Left ALT+left SHIFT+PRINT SCREEN (Switch High Contrast either on or off)
  • Left ALT+left SHIFT+NUM LOCK (Switch the MouseKeys either on or off)
  • SHIFT five times (Switch the StickyKeys either on or off)
  • NUM LOCK for five seconds (Switch the ToggleKeys either on or off)
  • Windows Logo +U (Open Utility Manager)
Windows Explorer keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • END (Display the bottom of the active window)
  • HOME (Display the top of the active window)
  • NUM LOCK+Asterisk sign (*) (Display all of the subfolders that are under the selected folder)
  • NUM LOCK+Plus sign (+) (Display the contents of the selected folder)
  • NUM LOCK+Minus sign (-) (Collapse the selected folder)
  • LEFT ARROW (Collapse the current selection if it is expanded, or select the parent folder)
  • RIGHT ARROW (Display the current selection if it is collapsed, or select the first subfolder)
Shortcut keys for Character Map loadTOCNode(2, 'moreinformation'); After you double-click a character on the grid of characters, you can move through the grid by using the keyboard shortcuts:
  • RIGHT ARROW (Move to the right or to the beginning of the next line)
  • LEFT ARROW (Move to the left or to the end of the previous line)
  • UP ARROW (Move up one row)
  • DOWN ARROW (Move down one row)
  • PAGE UP (Move up one screen at a time)
  • PAGE DOWN (Move down one screen at a time)
  • HOME (Move to the beginning of the line)
  • END (Move to the end of the line)
  • CTRL+HOME (Move to the first character)
  • CTRL+END (Move to the last character)
  • SPACEBAR (Switch between Enlarged and Normal mode when a character is selected)
Microsoft Management Console (MMC) main window keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • CTRL+O (Open a saved console)
  • CTRL+N (Open a new console)
  • CTRL+S (Save the open console)
  • CTRL+M (Add or remove a console item)
  • CTRL+W (Open a new window)
  • F5 key (Update the content of all console windows)
  • ALT+SPACEBAR (Display the MMC window menu)
  • ALT+F4 (Close the console)
  • ALT+A (Display the Action menu)
  • ALT+V (Display the View menu)
  • ALT+F (Display the File menu)
  • ALT+O (Display the Favorites menu)
MMC console window keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • CTRL+P (Print the current page or active pane)
  • ALT+Minus sign (-) (Display the window menu for the active console window)
  • SHIFT+F10 (Display the Action shortcut menu for the selected item)
  • F1 key (Open the Help topic, if any, for the selected item)
  • CTRL+F10 (Maximize the active console window)
  • CTRL+F5 (Restore the active console window)
  • ALT+ENTER (Display the Properties dialog box, if any, for the selected item)
  • CTRL+F4 (Close the active console window. When a console has only one console window, this shortcut closes the console)
Mar 29, 2009 | Microsoft Basic Keyboard 1.0A PS/2 KEMIBA
I have Compaq Presario V3826TU which i bought about 10 months ago. when i am typing in fast mode, the key 'a' and some key on the left hand side tend to working wrongly. For example when A key is press,...
THE SENSITIVITY IS SET TO HIGH IS THE MOUSE OPTION, SOME PROGRAM OFFER A PROGRAM THAT STOPS THE MOUSE FROM MOVING WHEN YOU ARE TYPING, NOT ALL COMPANYS DO THIS.
ROD
CONTROL PANEL, OPEN MOUSE
Mar 05, 2009 | Keyboards & Mice
Browser keeps reloading last page
Bring up your Browser, click on tools and then Options. When the Options comes up in the Start with page, will read "Show my windows and Tabs from last time" and click on the drop down and select "Show a Blank Page." Then it should work okay. Hope this helps. Bud
Dec 02, 2008 | A4tech A4 OP-620PS2 3D Optical Mouse PS/2
Up arrow key sticks
This fix also works for the LX 710 Cordless! Yay! Thank you.
Nov 14, 2007 | Logitech Cordless Desktop MX3200 Laser...
Compaq Keyboard Logo
219 people viewed this question
Top Compaq Keyboards & Mice Experts
joecoolvette
joecoolvette
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Keyboard and Mice Expert? Answer questions, earn points and help others
