Question about Honeywell Heating & Cooling
My central heating system comprises a worcester bosch system boiler and honeywell smartfit controls. The problem I am having is that the central heating doesn't seem to knock off at the preset temperature I have to go to the room unit and reduce the temperature by 2/3 degrees and then turn it back up; is the fault in the room unit or a sticking relay in the control unit? regards terry
  • 828 Answers
You could possibly have an ignition problem. The controller will go into a lock-out condition if flame is not established. Turning the temperature control down and then back up may be serving to reset the control system so it tries again.
Posted on May 22, 2008
Honeywell technical support
This boiler, from memory, has an electric diverter valve.
If the system has dirty (sludge/scale laden) water then the diverter valve may not return under spring pressure, and therefore not divert all of the hot boiler water to the hot water heat exchanger, leaving some going to the rads.
If I am right then the rads will not get fully hot.
If the valve has failed completely, or electrically, then the rads will get fully hot and there will be no hot water output (hot water will be cold).
Aug 19, 2014 | Heating & Cooling
Worcester MT10 Timer doesn't start. The clock seems to work fine but when it is time to start the heating system doesn't. Please someone csn help me? Thanks
Go to They have a video and instructions plus a downloadable manual to walk you through the process. If it still doesn't work maybe you should return it a get a new one.
Nov 07, 2012 | Watches
Worcester Bosch Highflow 400 Boiler - no hot water or heating
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi, this is Worcester, Bosch Group
Although we don't currently offer live technical support online, our Technical Support department will be able to help. Their number is 0844 892 3366 - they're open 6 days a week and on average answer calls within 20 second. If you want to know more about our Technical Support department visit our website
We look forward to helping you
May 13, 2010 | Bosch Water Heaters
Worcester Bosch 35CDi II banging & wild pressure (CH only)
Hi try bleeding the pump it sounds like air in the pump , but worcester do have a free tech help line look for there wed page on line hope this helps
Feb 16, 2010 | Heating & Cooling
Central Heating\which combi boiler?
HI right first i would look at a worcester greenstar combl
best you can get and you have full back up from worcester leave all rads with stats as they are i think you will have to remove one , the that would be the bath room also the greenstar comes with a clock bulit in these are on the worcester bosch web site i have been a gas fitter fot 30 years and this what i would go with a really good combi, you can also get awire less room thermostat for this hope this helps
Feb 01, 2010 | Desa International CBN30T Central Heating...
Bosch Worcester boiler, central heating not working
boiler may need more pressure in system pressurise to middle of green between 0.5 bar and 1.0 bar
Feb 22, 2009 | Bosch Logixx WFT 2806 Front Load...
Repressurizing my boiler
take your pick from video or text
How to Repressurise a Heating System with an Internal Filling Key ...
? 3:30
Oct 27, 2010 - Uploaded by Worcester, Bosch Group
This video shows you how to repressurise your heating system using your Greenstar gas boiler's internal ...
Repressurise Worcester boiler - YouTube
? 4:12 Nov 10, 2012 - Uploaded by Rory Macfarlane
This video demonstrates how to repressurise a Worcester combi boiler on the.
Product Troubleshooting Videos ' Worcester, Bosch Group > Support > Troubleshooting > Videos How to repressurise a heating system with an internal filling key ... how to repressurise your heating system using your Greenstar gas boiler's internal filling key.
How to top your Worcester combi boiler up - Gas Care. Aug 4, 2014 - If the needle on the pressure gauge on your boiler has gone into the red or down to zero it means there is little or no pressure left in the heating system and it needs to be topped up ASAP. So here's Gas Care Swansea's guide to refilling your Worcester Bosch combination boiler through the internal filling link.
How do I re-pressurise my Worcester Bosch boiler? - My Plumber Sep 1, 2015 - 6) Check the pressure on the pressure gauge. When it reaches between 1 and 1.5 bar, it is time to turn the white knob back to the right to close the valve. Be very careful not to over-tighten. 7) Turn the filling key to the left until the arrow lines up with the open padlock and remove the key.
May 12, 2017 | Heating & Cooling
Heating & Cooling Logo
497 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
