Question about Archos Televison & Video
What type of ac adapter do I need for the av700
I have lost the ac adapter can I use any type and what polarity is on the plug
  • 2,326 Answers
I would suggest to check the plug on the av700 and see the polarity, it might be indicated there.
In regards to using any adapter, you could as long is the same polarity. The original adapter is 6 Volts and 2 Amperes.
Posted on May 21, 2008
I need to know the POLARITY of the AC adaptor to provide the correct setting using a universal adapter.
there is no polarity in ac current as ac means alternating current and that means alternating between positive to negative back to positive back to negative and so on
only dc ( direct current ) and the center pin of the plug is designated as the positive pole has polarity, the outer case being the negative
OR Are you asking the voltage of the ac adapter and the voltage of the dc output side of the adapter
Nov 26, 2015 | Office Equipment & Supplies
The power on my banshee is coming on?
Check the polarity of the adapter, if it isn't the original one. Even if you have the right voltage, it still has to have the mA or higher but, most important is the polarity. Most guitar pedals are wired backward on the plug. The positive is on the outside ring of the plug and negative is in the middle. There should be a picture or diagram somewhere on the unit close to the plug to find out. If it is backwards, it could have damaged it, maybe not though. If it is ok, cut the plug off and switch the wires and check it. After all, it's not working now, it couldn't hurt.
Mar 15, 2013 | Rocktron Banshee Guitar Talk Box Talkbox...
Hi, I lost my iView ac/dc adapter and need to buy a new one. Can you tell me the specifications about voltage, polarity and amperes?
the switch that I have is a 4 port, ( and it uses a 9-volt, 400mA A/C adapter. I do know that this type of adapter can be found on most VTECH cordless phone cradles which also has the same size DC plug.
Oct 01, 2010 | IC Intracom iVIEW 4-port KVM Switch
I have a Prolink wireless 900 Mgh wireless speaker system. I have just moved and have lost the plug in adapter for the transmitter. could you tell me what the adapter voltage is into the transmitter. ...
I have Prolink 900 MHz wireless loudspeakers, probably the same as yours. The transmitter is labelled on the bottom as "CAN 2579 102 1811, UNI-ART PRECISE PRODUCTS LTD". That transmitter comes with an AC/DC adapter whose output is labelled as 12VDC, 300mA, with polarity positive outside, negative inside. Note this polarity is the OPPOSITE of what is typical for AC adapters.
Sep 14, 2010 | Audio Players & Recorders
I lost my GE Ultrasonic 2.1 Speaker power adapter and i need need ones but i dont know what to buy, the voltage it requires..6 or 9 volts?
at most electrical stores you can buy a universal power adaptors with a selection of socents to fit most connections. and which has a selector on it for various voltages settings.
take one of the little connectors and see which one fits. then checking the polarity on your device set the polarity the same when plugging the connector into the power supply cable. adjust voltage as needed.
Warning: when connecting a variable power adaptor alway connect on the lowest voltage setting and work up as too high voltage can distroy your appliance.
Nov 13, 2009 | GE Ultrasonic 2.1 Speaker
What is the DC voltage, current, and polarity of AC adapter
Howya mate , i wouldn't use a adapter which your not 100% sure belongs to it , even something you'll have the right connection and the right voltage on the plug it will still fry the chip or electrics cause the designers of the item designs adapters in such a way the voltage might be the same but the current is altered and that's why you have to buy a replacement adapter at double the price.
Aug 19, 2009 | Office Equipment & Supplies
I can't determine the polarity of my GPX PDL705 portable dvd
I have uploaded the GPX PDL705 manual to this site today. If you check tomorrow they may have posted it by then.
If you look at the small print on the adaptor it should indicate by diagram Voltage output, current capacity, type and tip polarity by small diagram. Most adaptors are 'positive' -- but if you are unsure do not plug the adaptor into the device because it will fry it!
Dec 05, 2008 | GPX PDL705
Won't work
oh no maybe you used different adaptor some adaptor have reverse polarity. check the adaptor before plugging it..if you using variable voltage set to 3v then adjust also the polarity. the polarity should match the polarity of your camera.
Feb 05, 2008 | Kodak EasyShare C875 Digital Camera
Televison & Video Logo
161 people viewed this question
Top Archos Televison & Video Experts
Are you an Archos Televison and Video Expert? Answer questions, earn points and help others
