Dp2310 panasonic My copier is making dark lines down the side of each page. Do you know how I can fix this
  • 1,326 Answers
Do you want the cheap way or the right way? Try the cheap way first try to change the papers postion in the paper tray.. If it is running LTR change it to LTR-R. If that fix's it your in luck for now, but it will need to be adressed sooner or later.
Posted on May 22, 2008
Printer showing error message ...."printing
This means that your machine has received a print job that is teling it to print on paper that is loaded or supposed to be loaded in the bypass feed tray. You will either need to delete the print job using the operation panel or simple load some letter size paper in the bypass tray over on the right side of the machine.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 18, 2010 | Panasonic Workio DP-3030 Printer
Copying very dark lines down page.
hi just clean complet scanner mirrors and charge and transfer crona wires if solved ok if not solve just replace the drumcleaning blade.
thanks
May 14, 2010 | Toshiba 1370 Black and White Copier
Dark line is printed on the right side of every
Most likely this is the drum. Take a damp cloth and clean the top of the drum roller. This should fix the problem. Good Luck.
Oct 27, 2009 | HP LaserJet 1022 Printer
When I receive a fax it has a large, dark black line down the middle of the page....does anyone know what this is and how to fix it?
Most likely you have a bad drum unit. Remove the cartridge and turn it upside down, swing back the shutter; you should see the large band on the drum.
Aug 18, 2009 | Office Equipment & Supplies
Samsung ml-2010 printer prints vertical lines on the page
it may due to scearch on roller. check the roller for any scearch mark.
Dec 23, 2008 | Samsung ML 2010 Laser Printer
Black line
Probaby an LED segment is burned out in the scanner assembly.
Dec 22, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
HP 2600N dark gray line down the left side
Maybe your transfer belt is damaged. If u have an spare belt replace it for a test. Answer me if it dont work. Maybe i can get an support manual for u. I work in a HP partner company.
Good luck
Dec 15, 2007 | HP Color LaserJet 2600n Printer
60 people viewed this question
k24674
jasbo
jasbo
