Question about Lexmark X5470 All-In-One InkJet Printer
Lexmark x5470 paper not feeding properly
The detection of paper seems to stop the printer feeding the paper properly. Was told that it's a small spring that is delicate that detects the paper being fed. I can see the spring just at the top of the rollers. By the way I feed the paper one at at time so it's never had several sheets in.I have had this problem before and had the printer serviced by a local company. I am reluctant to do it again so am looking for a service manual so that I can (take a few bits apart),sort it myself after all it is a cheap machine don't want to keep paying £30 a time. I cannot find a disassembly guide or manual just wondered if another printers series manual would help with the 5470 instead. Many thanks for your help and any suggestions.
EssexBabe
  • 1 more comment
  • cantste1 Nov 03, 2008
    I load paper into the printer, but it refuses to feed. If I attempt to assist with feeding paper, only half my material prints. It's very frustrating.
  • Anonymous Nov 17, 2008
    this is a big problem and i just wish i could find the answer to fix it because i just spent 75 dollars on ink and the stupid instruction manuel tells you to reinstall the ink but that did not work i have tried new paper thin paper thick paper and it just wont work Help!!!!
  • Anonymous Apr 29, 2009
    how do you take of the back panel?
I've just solved our printer problem!!!! SO, so happy!
Tried cleaning the rollers and as I was lifting the spring loades flaps I could see someting white on the left side, so got a tweezers to pinch it out.....Lo and behold a chewing gum flew out!! ( unchewed ). This has been a nightmare for past few months since my husband couldnt recieve faxes for work.
Its like winning the lottery!!!!! Can you tell that I'm happy?
Posted on Jul 15, 2009
Clean the feed wheels by cleaning with a damp paper or cloth towel. It is kind of hard to get to unless you can take off the back cover. You might try a long handled "Q tip" like the Drs. office has.
Posted on Jun 23, 2008
Lexmark X5490 paper will not feed rollers seem to slip. will work if you help the paper into the printer.
Sounds like the feed rollers are dirty. Use a mild detergent or soapy water and a clean cloth and clean the rubber rollers that turn to feed in the paper.
Do not use alcohol this could dry out and shorten the life of the rollers.
May 18, 2010 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x6570 paper continues to have feed problems after clearing jam.
Hi, In the following link are some tips and a good document on how to clear and how to check if there is something blocking the way of the paper and how to properly load the paper to avoid paper jams.
http://bit.ly/bdk0WJ
Jan 31, 2010 | Lexmark X5470 All-In-One InkJet Printer
My lexmark x5470 printer is jammed inside and I cant seem to be able to open it in order to get the paper jam out of it. Any suggestions?
You can try the following. Press and hold the check mark untill you hear the printer turning the rollers. That will cause the printer to try to feed a paper sheet. If that does not pulls the jammed paper out then you will probably have to find a way to remove maybe using some long nose pliers.
Hi my name is Lecette. I am having some trouble printing on my lexmark x5470 printer. When I print the paper slides in 3 inches and starts to crumble up and jams. Is there any way you can assist me with...
if the paper is crumpling up then something is stopping the paper from moving check the paper path for obstructions. if your first set of feed roller are moving and the second set is not then this will happen also
Dec 04, 2009 | Lexmark X5470 All-In-One InkJet Printer
Paper keeps jamming, seems to want to pull on one side only when part feeded. x5470
then check out the roller by dismantling the printer. check if the roller has jammed in one side where the paper does not get inside..
Mar 09, 2009 | Lexmark X5470 All-In-One InkJet Printer
Paper feed jamming problem
had this problem also try looking for a tiny piece of torn paper in the feed wheel and remove the snag
Aug 30, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
4,250 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
