Question about Gaggia Classic Espresso Machine
Gaggia Classic Hello! Suddendly I cannot properly insert and lock the filter holder into the brew head. All parts are perfectly cleaned and not damaged. It is a mistery! Thanks for your assistance. Riccardo Gallo Pacific Palisades, CA
Hi Riccardo,
Maybe the rubber ring that is underneeth the boiler has become hard and inflexible. You can order a new rubber ring thru your local dealer.
Marco
The Netherlands
Posted on Sep 09, 2008
I have a Gaggia classic and want to use pods. I've got Illy ese pods and the right (one hole pressurised basket) but still get just brown water. Can anyone help please?
I HAVE BEEN USING THE GAGGIA CLASSIC FOR 34 YEARS AND I ALWAYS BELIEVED THIS MACHINE IS BEING DESIGNED FOR SPECIFIC COFFEE QUALITY. THE ILLY ESE PODS ARE NOT FOR THIS MACHINE, TRY LAVAZZA PODS INSTEAD THAT IS SHAPED PERFECTLY WITH GAGGIA FILTER HOLDER FOR PODS.
Sep 07, 2014 | Gaggia Classic Espresso Machine
Why is there water spraying from coffee head and surrounding area
Grind is too fine and the portafilter chokes when water hits the coffee; or the seal in the brewing head is shot.
Jul 31, 2014 | Gaggia Baby Coffee Makers & Espresso...
Gaggia Baby Ivory, 2 weeks old.Hot coffee spurts out of side of brewing head when brewing. I called your Philips help line & was told that I had to insert a plastic disk, which is not shown on the...
If coffee is brewing out the side of the head then the group gasket needs to be replaced because it is damaged or there might be coffee grounds stuck to the gasket and it needs to be cleaned using a brush or you can also use cotton swabs.
May 23, 2011 | Gaggia Baby Espresso Machine
How do you release the brewing head after removing the two allen bolts pleasse? It needs cleaning and I have a new seal to fit.
  1. release filter bolt
  2. remove filter
  3. release& remove the alien bolts in filter holder
  4. push it from side with screw deliver, you don't have nothing attached, it will come down
  5. once filter holder is out you clean it good specially the 4 holes in sides
  6. While removing the old seal you might need to be bit rough, to cut the seal if it is too hard and non elastic at all anymore.
  7. clean it good and brush the place of seal
  8. take the new seal with numbers(mark on the seal) up and put it in the place so that numbers are going up to group
  9. push it with hand a bit
  10. get the portafilter without filter
  11. and put it in left teeth >>> roll a bit like when you put it in place
  12. do the same with left one
  13. repeat action in both teeth and with filter
  14. Control the seal, if it fits good in place.
  15. Assemble everything back and drink one espresso as an reward for work.
Mar 01, 2011 | Gaggia Classic Espresso Machine
My new Classic made perfect coffee for the first three weeks but now it sprays hot coffee in all directions from the delivery spout
Do you mean the spout OR do you mean the filter holder.If it sprays out too quickly from the outlet,it could be because the coffee is too dry, too coarsely ground or not compressed firmly enough in the filter. If it is spraying from around the filter holder it is probably old coffee grounds stuck on the rubber seal in the filter holder head (the part of the machine that the filter holder attaches to ) You can buy a special right angled brush for cleaning the rubber seal in place OR you can fold a washup sponge and use the corner to clean around the seal.
Jan 23, 2011 | Gaggia Classic Espresso Machine
Gaggia Classic Cannot insert coffee
You will have to reseat or replace the head gasket.
May 06, 2010 | Gaggia Classic Espresso Machine
I have a gaggia classic. I've descaled it and kept it running well for a few years. It now won't let any water out of the coffee filter section - the frother is perfect, but no water is coming out of the...
Remove the screw and shower in the head, check shower for blockage, if it is covered with coffee, hold over an open flame to burn out coffee (easiest way to clean it). If it is clean and you can see through all holes then turn machine on and press brew button, if not water flow, then remove 2 allen wrench screws and check spring and valve(remove carefully) then try the brew button, if no water then blockage is on the inside of the machine use the pic below to clear it will be on the top of the head.
Jan 20, 2010 | Gaggia Classic Brushed Stainless Steel...
Brand new Gaggia classic, no water coming through the brew head
take out screen and screen holder,and unscrew piece in head,clean with wire and try,i think its your head plugged out.
Aug 22, 2009 | Gaggia Classic Espresso Machine
No water coming through the head after prime etc
I have the same problem. I disassembled the unit body from the boiler. There was some scale, which I cleaned out. However, everything was flowing through the orifices with gravity -- no need to use a pipe cleaner because nothing is clogged.
So then I started tracing the flow of water. There is only one thing between the boiler and the shower head: the solenoid valve (in diagram ER0182 part # 27).
Sure enough, the solenoid valve will not accept water through the orifice that would route it to the shower head. Of course, this is with the solenoid unplugged and removed from the system. I soaked the orifice end of the solenoid valve in some decalcifiying solution in the hope that the solenoid piston may be jammed with a bit of scale.
Now I'm going to reassemble and hope for the best. However, my guess is that my solenoid valve needs to be replaced. Everything else is working (pump, valves, tubes, etc.).
I will report back.
Jul 06, 2009 | Gaggia Classic Espresso Machine
Gaggia Classic Espresso Machine Logo
164 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
