Hotpoint Aquarius WF250 Loud banging when spinning
Th machine starts to bang when a spin is on, i emptied it and it was okay-then i tried a small wash and it was banging again.
  • jonesmacca1 May 21, 2008
    I HAVE DONE THIS AND WE STIL HAVE THE NOISE AS IF THE DRUM IS LOOSE.
  • 868 Answers
The hardest amount to balance is a load with just one item.Because you have nothing to counter balance the other side.So,first off,put in a normal load ,make sure your washer is level by using a level to assure it is, other wise if its not all the clothes will group in one spot where its not level ,than when time to spin you have a un balanced load.
Posted on May 21, 2008
Hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Thankyou.
Jan 31, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius wm64 loud banging noise when spinning with full load no noise when spinning empty i have found small pieces of plastic inside drum
Several possibilities here.
First and fore most is the drum support or main drum bearigs are failing., more likely to be drum support
The pieces of plastic you refer to are from inside the outer drum, because what is happening is the inner drum is catching the outer drum, and breaking the plastic inside.
You are going to have to strip it down to determine the exact cause, what I expect you will find is that the alloy 3 legged drom support has corroded away,a nd the drum has come loose.
Hope this helps you solve your problem
Nov 28, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius banging about when spinning
hi take the top of the machine and check the brick at top or bottom of the machine they sometimes come lose .
Sep 30, 2009 | Hotpoint Aquarius WF220 Front Load Washer
My hotpoint aquarius front loader has power but wont work.
Most likely the Door interlock is faulty or has fallen apart (through the banging of the door)
Aug 21, 2009 | Washing Machines
Hi,i have a hotpoint aquarius wf340.which makes a very loud banging noise every time it spins,it works fine otherwise!
I had the same issue with a similar machine. Need to replace the spindle assembly (or otherwise make sure) that the belt is tight. Try replacing belt first.
Make sure machine is level. test it by putting some stuffed sockes in the machine, let them get thrown around. Listen for the banging noise, apart from the soft socks hitting the tumbler.
Aug 08, 2009 | Hotpoint Washing Machines
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD 440
FIRST OF ALL THE PERSON WHO INSTALLED THE MACHINE SHOULD HAVE REMOVED THE TRANSIT BOLTS YOU MAY BE LUCKY THAT ONE OF THE SHOCKS MAY HAVE COME OUT OR A SPRING MIGHT HAVE BROKEN
Jul 13, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WF250-Loud banching when spinning
possible broken "spider"support on rear of basket best call serviceif unit is out of warranty be sure to ask for estimate first
May 21, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WMA42 - Noise!!
appliance sounds like it has bearing failure.common on this machine.advise looking for a new machine.sorry
Dec 30, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
350 people viewed this question
Top Washing Machines Experts
