Question about HP LaserJet 4250n Printer
Printer problem my HP laser jet 4350n printer turns on but the display screen is blank
  • 4 Answers
First remove the control panel from the machine and make sure that the cable is seated well to the panel and the control board. If they are remove both cable ends and reseat them.
Posted on Jun 15, 2008
2 Suggested Answers
  • 468 Answers
SOURCE: I can't get my HP Laser jet 4350n printer to install
Did you try those drivers
Posted on Aug 13, 2009
Show error 52.00
Note this a not something users can repair themselves. It is a fault with scanning motor. may need motor or whole scanning assembly to be replaced. Only service centre can perform this.
HP LaserJet 4200 and 4300 Series Printers - Numerical Error Messages 52.XY PRINTER ERROR For help press? alternates with 52.XY PRINTER ERROR To continue turn off then on
A temporary printer error has occurred.
X Description 0- Scanner error
1- Scanner startup error
2- Scanner rotation error
  1. Press the (Select) button to continue.
  2. Turn the printer off and then turn the printer power on.
  3. If the message persists, contact HP Customer Support.
The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error.
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. HP LaserJet 4200 and 4300 Series Printers Numerical Error Messages
Apr 16, 2016 | HP LaserJet 4350n Printer
My printer hp laserjet 4350n displayed error 49.FF05 SERVICE ERROR .what is the problem
49.FF04 - in older 4xxx printer it mneans a firmware error - try to do:
1. cold reset
2. updaete firmware
3. remove network card from printer and instert it back - or try to turn printer on without it.
4. reinstall the formatter - phisical connection may be not good ( formater is a "cage" that the networc card is inserted)
go to for more information
May 27, 2015 | HP LaserJet 4350n Printer
49 errors are most commonly caused when the printer receives a print job with commands it does not recognize. You can try updating the firmware as this will often resolve the error. Go to HP's website to find the most recent firmware, however this model is fairly old and likely the firmware update will be fairly old.
Sep 25, 2014 | HP Laserjet 2605dn Workgroup Laser Printer
My HP laser jet 4250n printer turns on but the display screen is blank --there is no message. the ready light, data light and attention light all come on
Could be bad Control Panel or bad Formatter.Start with the Control Panel, it's cheaper.1st make sure the cable is attached to it.
Sep 29, 2011 | HP LaserJet 4250n Printer
Aug 13, 2009 | Office Equipment & Supplies
Hp laser jet 1020 printed blank. toner, scanner ok
laser jet printer oprated with positive or negative charge by charging ruler so please chek it.
Jun 23, 2009 | Office Equipment & Supplies
HP laser jet 4045TN is printing a blank page before the actual documents i am printing. In the top left corner of the 'blank' page it usually prints either *s1M or s1M. Do you have a solution for me?...
i am an expert in a different catagory,...
but i read your problem accidently and i had the same problem with my laser jet..
check the order list (in you PC screen in the right end of the START bar there is a little printer ...)click on it
and if you find a printing order of a blank page delete it...if not
then its not the same problem and am sorry i can't help any more..
Jun 08, 2009 | HP LaserJet 6p Printer
Blank sheet after the printout
sir there will be no ink your printer please check and reply again
Jun 03, 2009 | HP LaserJet 4350n Printer
52.00 error
Hp says you have a bad scanner unit(laser unit) or DC controller, but first reseat all your connectors on your scanner unit(laser) and DC controller. Your scanner is located under the top cover and the DC controller is located behind the right cover. If the problem still persist replace the scanner first.
Apr 23, 2009 | HP LaserJet 4350n Printer
Blank display
If the printer control panel is blank when you turn on the printer, check the following items.
1 Make sure that the printer is plugged into an active electrical outlet receptacle that delivers the
correct voltage.
2 Make sure that the on/off switch is in the on position.
3 Make sure that the fan runs briefly, which indicates that the power supply is operational.
4 Make sure that the control-panel display wire-harness is connected. See the hint in the
procedure for Top cover.
5 Remove any HP Jetdirect or other EIO cards, and then try to turn the printer on again
Apr 04, 2008 | HP LaserJet 4250n Printer
HP LaserJet 4250n Printer Logo
417 people viewed this question
Ben Johnson
