Question about Bissell 6590 CleanView Bagless Upright Vacuum
Bissell 6590 the part I am trying to replace allows you to lower the handle to lay flat to get under furniture and it also allows the handle to stay in the upright postion. i have looked on bissell.com and did not find it-but I will try again. you are super and Thanks allot . Have a super easy day! Michele
  • handyman-dan Oct 17, 2008
    Great now I know I can get the part, but how do you remove the broken one? Help...
    President:
  • 1,673 Answers
It is called the detent lever part # 2030052. If you can't order it from bissell.com or over the phone, most repair shops should be able to order it for you.
Posted on May 22, 2008
I need to print how to assemble a bissell proheat shampoorer
First locate screw pack (you will need a Phillips screwdriver). 2 long Phillips screws with hex nuts, 2 short Phillips screws. Should be taped to under part of handle.
2, Put upper handle into lower handle.
3, feed the power cord through the tool caddy from the flat side. Place caddy to handle so the hex shaped holes on upper portion.
4. Place the hex nut in the hex shaped hole and insert long bolt through the front of the handle. Do the same on the other screw and tighten them snuggly. Be careful not to over tighten them.
5. Insert small screws into lower 2 holes through the back side of the lower hose rack. Turn until tightened.
6. Attach tool(s) (that would be a small brush or the pet brush attachment to end of hose and on the attachment holder on front of upper handle.
7. Wrap hose around large holder closest to handle and power cord is wrapped around outer holder with rotating clamp.
Hope that helped
Dec 11, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
Now I know why the bissell is dragging. There is no middle position on the handle. There is either upright or low (for under furniture) What can I do?
Hi Eva! If your machine is dragging on the carpet, one of the clear nozzles on the front may be off alignment. Here's a link to our FAQ to help you with the dragging: http://www.bissell.com/FAQDetail.aspx?id=1102&cid=ccsocial
Sep 05, 2013 | Bissell 1699 ProHeat Clear View Upright...
The handle release pedal wasn't allowing the handle to lower. I took off the pedal and saw the spring load part was broken. What is this part and how to replace it? Bissell 3760-3 handle release
Order Slider Release (7.93, vacpartswarehouse) Pull off 'tank.' Remove 3 Screws for Foot Detent Lever. Pull off. Remove old slider release and spring (verify it's broke.) Replace with new. I just did this today after a year of dealing with it.
Mar 04, 2012 | Vacuums
My bissell 6590 works fine with hose attachment. Motor shaft turns when belt and roller are off. When belt and roller are on it's noisy and smelly. Now one end of the roller actually melted in the holding...
replace the roller,belt and before instalation clean motor shaft where belt rolls. you can turn on the vacumm and using a knife scrape the motor shaft from the black dirt.
Feb 19, 2011 | Bissell 6590 CleanView Bagless Upright...
Bissell 6590 wheel unit pins snapped, where can I get a replacement part
This is a very easy repair. I got a hose clamp. 1/2" wide, solid edge. Take your time and bend it the inside shape of the holder. drill 2 matching holes, It's a perfect fit.
Nov 02, 2008 | Bissell 6590 CleanView Bagless Upright...
Bissell 6590 handle height adjustment
The handle adjustment knob part # is 2031095, the height adjustment wheel asm. part # is 2031330. You might try bissell.com and see if you can order direct from them. If not, most repair shops should be able to order for you.
May 20, 2008 | Bissell 6590 CleanView Bagless Upright...
HANDLE height adjustment just broke and I can not find any place that sells it. Any suggestions would be of great help. Thanks, Mafiabella
It i called a detent lever, part # 2030052. Usually a repair shop can order this for you. Or you might try bissell.com and see if you buy it online from them.
Bissell Bagless Vacuum cleaner
There is no release, the part is a plastic handle release lever, you can find those at www.hesco.com, the cost is approximately 2.29 each, I have replaced more than 20 of these on the commercial vacuums for my cleaning crew, the part is easily broken and easily replaced. I always have 6 or more on hand.
Turn the vacuum over, remove the bottom plate, with a flat head screw driver punch out the old part. turn the vacuum upright again after the broken part is removed. With the body laying back on a hard surface, carefully push in the new part. Unfortunately, these are plastic, too bad they cannot design a more sturdy part for this.
Apr 10, 2008 | Bissell 3522 PowerForce Bagged Upright...
Too loud noise of Bissell 6590-W vacuum cleaner
When they get real loud either the motor bearings or the motor fan are bad and you will have to replace the motor, part #2031100, would sell for about $45.
Oct 04, 2007 | Bissell 6590 CleanView Bagless Upright...
Bissell 6590 CleanView Bagless Upright Vacuum Logo
170 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
