How to replace red crt on 52" RCA
I had repair man out to look at tv. had no red colour. he showed me that the light just above the board lit up on the green and blue, but not the red. He said I needed a new crt. does this sound accurate?? how do I replace this myself. I have researched as much as possible without becoming a tv repairman myself, and have taken apart much of the tv to get all the info needed. Including the number off the red crt. Or should I just scrap it.
model D52W26
serial G492CN05C
chassis ITC222
crt P16LXL00RFA(U)
  • 8,617 Answers
When a red crt goes out and wont light its usually another reason such as a transistor or even faulty CRT pc board that causes it since the set powers up the other two tubes. Go to this link and leave them an email and list the model number and tell them the symptoms they will help you out with it, they are real good with the RCa sets. If the red tube was shot it would cause the set to go into shutdown or throw red retrace lines across the screen. Heres the link,
http://servicemanuals.vstore.ca/
Posted on May 21, 2008
I have a light red hot spot just right and above center, any idea how to repair?
You have to take front projection screen off of tv. When you have taken screen off, turn on tv and observe light coming from the three crts. Look into the face of each crt and you will notice some contamination inside face of one of the crts. Most crts are sealed, so youll have to replace the burnt crt causing spot on picture.
Aug 19, 2010 | RCA P52926 52" Rear Projection Television
I have a great picture but only shows red and blue also the glare screen needs to be fixed, Is this something I can do myself?
Sounds like the Green CRT drive board is defective. You can get a CRT drive board from www.tvrepairworld.com you can also get the replacement screen assembly there also.
Jul 06, 2010 | RCA D52W23 52" HDTV CRT TV
My RCA 52 inch hdtv 3d of the colours.The three colours are all showing in a streak like a rainbow
U know how to solder?Buy a convergence kit,replaced what in that kit ur tv will be back to normal.Tries these websites for the convergence kit.Tv Repair Worl.com,Tv Repair kit.
Oct 23, 2009 | RCA HD52W59 HDTV Projection Television
I have a 52 inch RCA projection TV about 15 yr old today the colours are not lining up causing a shadow of red behind white lettering and looking like a 3 D show withought wearing the proper glasses?
you need to replace the convergence supply board, if it's one of the earlier models, you change the chip stk730-130 that will fix it. the board is small and up off the chassis to the right slightle, 4, 1/4'' screws holds it in place.
you might be able to get a whole new board, which would require no soldering to fix.
Sep 15, 2009 | RCA P52926 52" Rear Projection Television
RCA P52731WK REAR PROJECTION NO RED ON SCREEN
The RCA model is a 3 CRT projection TV. Most probably you need a new RED CRT, or there is a problem with the R(ed) channel (the picture is made up of 3 component colors: Red, Green and Blue). No way of telling without testing of the projector. Sorry!
Jul 11, 2009 | RCA P52926 52" Rear Projection Television
Green light stays on but no picture
This is very hard to know the problem. A lot more info is needed to know about voltages on the inside of the tv. I would say to take it to a repair man.
Nov 10, 2008 | RCA HD52W58 52" TV
My screen is green
Nothing that you can do. The green crt and/or driver board needs to be replaced. Let a repair man do this.
Sep 04, 2008 | RCA HD52W58 52" TV
Red screen and only red bulb powers on.
The red tube and the red crt board sound like the problem. these would be the first thing that needs to replace 250 for tube +50 for crt board. + labor about 300 to 500 to repair
Jan 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52" second time in the shop in less than one year, won't stay on, green light flashes 3 times then goes out
try changing the cap 150 on the same board as flyback transformer this should help with the tv not staying on.
Jan 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Need help
Take off back cover--look to see if red tube is lit,if not
then voltages must be measured at red CRT circuit board.
One way to help diagnose is compare voltages to working tube
either green or blue--------Let me know.....T.
Oct 26, 2007 | RCA P52926 52" Rear Projection Television
Televison & Video Logo
356 people viewed this question
Top Televison & Video Experts
