Question about Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2)
Linksys wireless adapter and linksys wrt54g2 router not seeing each other
I have a brand new wrt54g2 router that is connected wirelessly to another desktop PC in my home.
However, when I have my wife's dell laptop with a brand new Linksys wpc54g adapter sitting next to the router, the adapter is telling me there is "No association with the access point"
All installation steps have been followed, and the home network appears on the available networks list
  • 3 more comments
  • Mike OB May 21, 2008
    The screens don't match your view; there is no appearance of any "more info" button anywhere on the screen, only "Link Information", "Site Survey", and "Profiles".
    The weird thing(s) is that when I am prompted to choose the network, the signal strength is between 84 and 100; when I try to connect, there is zero.
    I have also tried disabling the security on the router - no good
    There is a wireless network icon on the windows taskbar on the lower right hand side, with a red "X"; there is also the wired network icon, 2 computers, also with a red "X".
    When I right click the wireless icon, the popup window shows the home wireless network as available. When I attempt to access it, an error message comes up saying that network is out of range.
    There are no icons on the Linksys screens associated with the connection. The only Linksys icon is the green box, also on the task bar
    Was able to follow all instructions, but when attempting to connect to the network, getting the same "out of range..." error message. The weird thing is that the error message saying "out of range is popping up over the windows available networks screen showing a full 4 bars.
    Just FYI - I just popped in my old 802.11b adapter, and noticed a couple of things
    1. It picked up other networks that the 802.11g adapter didn't
    2. I have 2 lights on the adapter right up until I try to connect to the wireless network, at which point the "link" light goes dark
    Hope this helps - thank for staying on this.
    Neither adapter can get to the network
  • 298 Answers
Its possible that the wireless card does not have the correct wireless settings.
Open the linksys wireless monitor on your wife's laptop.
Go to the profiles tab, highlight the default SSID then click on edit at the bottom. It will search for the wireless network, from the list of networks that it will show you, click the name of your wireless network, in if the network is secured you will be ask to put in your network key. Then click connect. Then it will say that you profile was successfully configured. then click connect to network. It will take you back back to the screen where you saw no association to the access point, check if you will now get a new message. On that same screen click the more info button at the upper left hand side. Check the IP address it should be 192.168.1.x. If you have that IP then you can test if you will be albe to get online.
if you still have any problem just reply to this post.
Posted on May 21, 2008
  • 2 more comments
  • Jeffrey Pedimonte
    Jeffrey Pedimonte May 21, 2008
    Try this can you check if there is an icon at the bottom right hand side that says wireless network connection? Does it say connected? this ico looks like a computer.
  • Jeffrey Pedimonte
    Ok, right click the Green square icon on your task bar, and select windows wireless zero configuration, when a confirmation screen pops up click yes. And the square icon will turn to gray.
    Now right click the wireless network connection icon go to view available wireless networks and click change advanced setting on the left hand side of the screen and click wireless networks tab at the top. On the wireless networks window at the bottom you will see the preferred network list (its a box). in the list remove then name that is not your and that you dont need any more, then say ok until you get out of that screen. Then right click again the wireless network connection screen and go to view available wireless network and connect to your network.
    just reply to this post with the result so we can continue troubleshooting your concern.
  • Jeffrey Pedimonte
    Were you able to check if you can connect to you network using the other adapter?
  • Jeffrey Pedimonte
    Its possible it's with the router. Have you tried to change the channel aside from disabling the security?
    If you still cant get any connection then you can do a firware update on the router.
Low connection to Internet
You can change channels, you can't increase frequency. The Linksys WRT54g is a 2.4ghz Frequency wireless device. You can purchase a 2.4-5.0ghz Frequency Dual-Band device. If you have Devices with Wireless N Adapters you will benefit, theoretically, from a N wireless access point increasing speed. Do a little research, there's more to it than replacing a Wireless device. That's only one piece of the puzzle.
Apr 02, 2013 | Linksys WRT54G2 Wireless Router
How to connect Samsung hdmi tv to linksys router
Buy a wireless adapter designed for a TV, plug it in and you should be able to connect wirelessly to your router.
http://www.samsung.com/us/video/tvs-accessories/WIS09ABGNX/XAA
Jan 20, 2013 | Linksys WRT54G2 Wireless Router
Download linksys driver WRT54G2 V1
What drivers do you want to download?
There are not drivers for Linksys router. It works on a software called as firmware?
How many wireless computers do you have?
What is the operating system on your laptop?
If your wireless network is secured then make sure that you have the correct network key.
See How to setup Linksys router
See how to connect to the wireless network
Mar 21, 2012 | Linksys WRT54G2 Wireless Router
I cannot access my WEP Hex Key, how can I locate it or reset it?
Connect to the router with an ethernet cable. Use a web browser and connect to 192.168.1.1 You should see a router home page. login as admin (default id= none/blank/null password=admin) These detailed instructions may help here http://nabtron.com/forgot-linksys-wrt54gr-password-how-to-reset-settings-of-the-router/180/ browse to the wireless/wireless security section and set up your WEP key. You can preview the web page layout here; http://ui.linksys.com/files/WRT54G2/ e.g. http://ui.linksys.com/files/WRT54G2/1.0.00/WSecurity.htm for you this would be http://192.168.1.1/WSecurity.htm
Jan 08, 2011 | Linksys WRT54G2 Wireless Router
WRT54G2 wired desktop fine, can't connect to wireless.
Hi Seth6025,
Try without using Wireless Encryption (password).
Try changing channels; default is 6; try 1 or 11.
Change your SSID: personalize it
SSID broadcast: Enable
Check the advanced wireless settings and make sure MAC filtering - DISABLED.
Reset the Linksys router by pressing RESET for 30 seconds should everything fails and re-configure. Firmware is another consideration BUT this is just a new release.
Regards,
Angel
Jul 08, 2010 | Linksys WRT54G2 Wireless Router
How to find security code for linksys WRT54G2 to
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here
for step by step Instructions on how to find the network key
Jan 28, 2010 | Linksys WRT54G2 Wireless Router
Wireless will not connect to internet after installing XP Service Pack 3. Router is a Linksys WRT54G2, adapter is a Linksys WMP11. Router is set to "mixed".
Try upgrading the firmware for your routher and the linksys WMP11. Also try setting router to 802.11g instead of mixed to see if it connects.
Sep 29, 2009 | Linksys Instant Wireless WMP11 802.11b
Linksys Wireless B Router Compatible with Windows Vista?
I would advise you to purchase a Linksys G router, Model # WRT54G2. Works well with Vista and your other laptops will work also.
If I could be of further assistance, let me know.
If this solves your issue, please be kind to rate it.
Thanks, Joe
Mar 26, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2) Logo
524 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
