Question about GPS
GPS Im having a problem getting an activation # for this unite there is a screen that comes up when i turn it on with a indentification # that is 4db9375374df6ac9d & it says to go to www.getactivationkey.com.but the numbers dont work thank you
  • 3 more comments
  • roxymoe Jun 26, 2008
    hello there, i have just been givin one of these gps's. i have the very same problem.on the initial start up it says to activate it before use, when i go to the getactivationkey site, i get the supposed key no,s and enter the device no and get the activation key no probs but all i get is; activation failed.....i have emailed the company and they say i have entered the inn correct no? the number is the same as the one i was givin, but the last digit was taken off. but still it fails to activate. as i don't really know what brand it is i cant do much else? all the box says. it is a MIYSIS SYSTEMS 888. IS THAT THE BRAND OF IT?????
  • leifi Aug 03, 2008
    I have looked ant tried all other numbers that I have found on the gps,
    but nothing worked.
    My GPS System is a TEVION P310 with a serial number WTYF08010007568
  • Anonymous Dec 01, 2008
    I bought a nuvi at walmart & we have no instruction booklet please advise
  • Peter Smith May 11, 2010
    I have a Miysis 888 GPS made by Navigator Australia (now defunct). I have the same problem of activation and "Ellie153" has the answer in that there is supposed to be a card in the box with a 8-9 digit code which you need to enter at www.getactivationkey.com. She has this code and once entered it allowed her to enter the product code and get the activation code. When punched in to her GPS the unit confirmed activation. I think this manafacturer code will work for all these Miysis GPS's. How can we contact her, or has someone else got this code.
    Regards, pcs1z
  • Peter Smith Jul 19, 2012
    Yes, I understand that is the brand. If there are letters in the code, it may be case sensitive..
I got the Mysis working ok my problem is finding a program to update the maps?..
route 66.com doesn't provide further map updatse for this system as far as I can tell...anyone similair?
Posted on Jul 01, 2010
Hi I have just purchased one of these units for my hubbie's birthday ( big mistake )
In the box there was a card it has numbers on it, You need to use these numbers at www.getactivationkey.com it will then generate your password, But you will still need your Id number
4db9375374df6ac9d as well, Good luck I was able to activate it but the unit works in miles not kilometers it seems to be set up for Uk and Usa and not Australia, On top of that I managed to delete the maps and now I am having problems with loading the program back on, I had to go and buy a card reader as none came with the unit and you cant use the program without it, I am about to take it back to the shop and tell them where to go lol cause this unit is not telling us
Posted on Dec 15, 2008
Simply choose activate later and then accept the license. The GPS works normally then. Sure it is a bit of a pain to do this every time but you can just leave it plugged in and just put it to sleep instead of completely powering off and then you don't see the activation screen anymore.
Posted on Aug 08, 2008
does anyone have contact details for the miysis cmpany
thanks
Posted on Aug 24, 2009
  • jason_marko Aug 24, 2009
    i have the same problem with the miysis888
    thanks
How do i update maps
Turn on the unit, enter 'System' menu in the initial screen and set the current date and time. The maps get activated when the unit is set to real time.
Feb 10, 2016 | Curtis Gpd359b Portable GPS Navigation...
710 frozen on tom-tom splash screen
1. Activate the TeleType GPS program
2. Select Tools>GPS Status>Status.
3. Look closely at the GPS output that is displayed in the View Status menu. Data should be flowing even when the GPS receiver has not locked in the position.
The data string that begins:
GPGSV... is "bad data" because the receiver has not locked into the satellites.
Whereas:
GPGSA... is "good data" indicating that the receiver has locked into the satellites. Remember - "A-Okay"
4. Once the data is flowing, go outside away from buildings, select the Satellites tab (Tools>GPS Status>Satellites), and watch the satellite signal strength
Nov 27, 2007 | Tomtom GO 700 GPS Receiver
When you turn the unit on a message comes onto the screen that says. UNIT CURRENTLY CONTAINS NO MAP! INITIATING MAP UPLOAD. you cant do anything with the unit message stays on the screen.
when you turn the unit on a message comes onto the screen that says:
May 01, 2011 | Magellan eXplorist 400 GPS Receiver
I just bought the garmin nuvi 265wt. I tried to activate the free lifetime traffic that comes with the unit but when I touched the screen to enable the traffic it told me I first must go to www.garmin/fm...
Check the information that came in your box. With my TomTom Lifetime Traffic and Maps, there was an "activation" number on one sheet of paper. I had to activate (per instructions) before I could enable the lifetime goodies.
Jan 30, 2011 | Garmin n?vi 265WT Car GPS Receiver
How do i activate the set?
There is no charge to activate a Garmin GPS. Purchase the unit, turn it on and it works right out of the box. You will need to charge it as the unit only comes with a partial charge from the factory, but it will work immediately.
Jul 02, 2010 | Garmin nuvi 255W GPS Receiver
I turn it my Garmin and it will not come up with my location, it is coming up Kanas and Im in Cleveland
Are you outside with the unit? It was made in Kansas and has Olathe, Kansas as it's default starting point. However, when you take the unit outside and it gets a satellite signal, it should find where it is currently. If not, the GPS might be turned off (for indoor use). Turning the unit off for a few seconds and then on again outside should put it in the proper mode to receive satellite signals. Let me know if this helps.
Jan 19, 2010 | Garmin nuvi 1200 Car GPS Receiver
How to activate the map once we have the code?
You can activate products by connecting the unit to a USB port of a computer. If The Tomtom Home application is installed on computer it will launch and update the unit. On page 1 of main Home menus there is an icon for activation.
To make things easy for you I am enclosing a screen capture from the HOME 2.7 application.
Dec 22, 2009 | Tomtom GO 700 GPS Receiver
I have been having trouble with my roadcom sat nav, I used it to get somewhere and had no problems but when I went to turn it on to come home, the main screen comes up but it just freezes and it wont let...
To hard reset the unit turn the unit off, hold down the mode button and turn the unit on. When the unit asks if you want to erase all user data, select yes. After resetting the unit, leave it with a clear view of the sky for about 30 minutes to acquire the satellite almanac. “ Do not worry You don’t loose Your saved rides data, only all screen settings and some other device settings will go away. Set it back to Your preferences and You’re done. Hard reset is suggested after software updates. In my case it heals all self shutdown problems in my Edge 705 GPS.
Dec 02, 2009 | Garmin Edge 705 Satellite Navigation...
Lost my activation code
the activation code is not used for anything but to activate your maps....which is not dine anymore....the activatoin code is useless...
the real issue at hand is that the softwre on the unit is messing up....go to www.tomtom.com/9091 and follow these steps
Feb 05, 2009 | Eclipse AVN2210p MK II CD Receiver w/...
Nuvi 200
Do you have a garmin home charger.
To do a test , is that working when you connect your unit with the car charger.
Less than 0.9 % of the units has a battery problem. I don't think you have one.
When it's full charge , what is the maximum bars you get ?
Dec 09, 2007 | Garmin Nuvi 660 GPS Receiver
GPS Logo
1,159 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
