Question about Nokia N95 Cellular Phone
Screen replacement i broke the screen, have now bought a relpacement but cant seem to get the new screen to light up. do i need a special tool apart from the little screwdriver? i know theres a small ribblon like piece inside the phone but i cant tuck it in where its supposed to go??
    Problem Solver:
  • 7 Answers
I gessing that by tuck it in you are talking about the connector under the key broad. There is a small clip no the bottom side of the connector that has to be up when you put the new one in. This can be open with a small flat head scerw driver. Once that is opened I have found the easiest way to get the ribbon in is to lay down the screen where it is sapose to go. Then line up the ribbin with the connector then run your finger down the ribbon torward the connector. Do this till the ribbion lays flat, then push the clip on the connector down and put your phone back togther. I hope this helps you with fixing your phone, and if this is not what you are posting about please post more details and i will try to help you.
Posted on May 22, 2008
Rear pasenger coil over spring broke at the bottom of the spring. Makes clunking noise , is there a temporary fix. I dont think it is going to come apart, I know they say spring steel cant be welded, What...
You will have to remove the strut and the use a tool like this to compress the spring to remove it and replace ot with a new one or a second hand one from a breakers yard.
images?q=tbn:and9gcr-yghhe9p9m6mn8nlcrewiaqmvzzzyfjsraudsbymtanby_7teuaimages?q=tbn:and9gctueryvh3g7wnlbbbymf7plqqsymjlsqxefxbkdq2h7i78sy5wynrvyxom
Apr 29, 2011 | Chevrolet Lumina Cars & Trucks
Power led lights green, touch screen flashes white and powers off
try taking it apart again and checking closely to see if any inner cable is loose,
Apr 13, 2010 | Nintendo DS Lite Console
2000 Chevy Impala Battery problem, got new battery worked fine for a few days and then it has to be boosted again. Something running the battery down.. Then the bright dim switch for the head lights...
Sounds like your headlight dimmer switch has gone bad and was shorting everything out
You will need to order an HEADLIGHT DIMMER SWITCH
And you have to take the steering column apart (remove air bag and steering wheel) to replace it.
This take special tools and knowledge...if your not sure take it to a pro.
Jan 18, 2010 | 2000 Chevrolet Impala
How do i replace my screen?
you will have to take the phone completely apart, and you will most likely need special tools to open it. unscrew all screws you find, there could be hidden screws under soft objects and labels.
ones you have the screws out the case should snap open from the corner, with the help of a flat screwdriver.
ones you have the case apart, you will need to unscrew and disconnect the display. then replace it with a new display, and put everything back together.
all you need are the tools, maybe some special screwdrivers etc and you can do it.
Jun 07, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Nokia 6210 Nav new screen just flashing white
These models 5110,6110,6150,6210
Are very sensitive in display contact.
Sometimes if u just dropp the phone The screen can start to fade.
take the phone apart again and dlean all the gold-plated connectors on the screen and contact areas on the mainboard with a cotton stick soaked in
isoprophanol. Let it dry avoid fingering on the cleaned surfaces.
mount the screen carefully to the mainboard tighten the skrews from left to right to finally tighten the skrews carefully.
This should do it! Please vote!
Jun 06, 2009 | Nokia 6210 Cellular Phone
Touch screen broke
I had the same problem bought a replacement screen on ebay, search on you tube for instructions on pulling 750 apart and replacing screen only took 5 minutes and it works. If I can do it anyone can.
good luck
Jan 29, 2009 | Palm Treo 750 Smartphone
Nokia N80 Lcd screen
its a problem with ur Glex cable its the faulty part ion this case.
Dec 20, 2008 | Nokia N80 Cellular Phone
To replace the spring trunk opener
you are best to take it to a honda dealer there is alot of tension on those springs and yes there is a special tool a honda mechanic i work with was careless with this issue he broke his wrist
Oct 22, 2008 | 1997 Honda Civic
Sidekick 2
If it still turns on, than the problem is the screen. Really, the only thing you can do is replace it. You can buy a new screen on ebay, and get a tool too. Just take out the screws on the metal flip part(you need a special tool), and then detach the ribbon very carefully. You can take out the Phillips screws on the screen cover to replace the screen only or just replace the whole thing with the cover already on.
Apr 16, 2007 | T-Mobile Sidekick II
Nokia N95 Cellular Phone Logo
171 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
