Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Removeal of external case below loader door
I have trying to determine how to remove the metal curved modular panel below the fron loader door. Anyone know how to do this?
  • 5,911 Answers
If you are talking about the lower kick panel, all you have to do is remove the three 7mm (torx) screws under the bottom edge of the panel. HINT: If you prop the front feet of the washer up it makes access much easier. (I use a couple small blocks of wood). Once the screws are removed, the panel should drop down then come off. If the panel sticks, just tap on either side and it should come loose. I hope you find this information helpful. If you need further assistance, please post back and let me know.
Posted on May 22, 2008
How do I get to the belt moter on a sears Kenmore 500 cloths dryer the belt is off but not broken
The usual method of accessing the belt is to remove the entire fron panel (including door). It is usually easy to remove the panel by removing a couple of screws at the top and pulling up and out on the panel. The belt can be reached from the front. All dryer belts have a spring loaded tensioner on the belt. Check the tensioner as belts hardly ever come off unless the tensioner spring breaks.
Oct 20, 2014 | Kenmore Dryers
We have a Frigidaire "Affinity" front loader it is leaving a puddle on the floor when we use it. I assume the rubber ring is bad has anyone changed it themselves? Is it a hard fix?
Are you sure it's the door seal? If it is they are normally just held in place with 2 metal rings, 1 at the edge of the seal at the door opening and one at the outer drum. Once you remove the front ring from the door opening you can gain access to the one at the drum. Removing the lid of the machine will also help and give you a bit more light.
Anyone with a bit of DIY know how should be able to replace it, an hour tops for a beginner.
Dec 29, 2012 | Frigidaire ATF6000ES Front Load Washer
How do I remove the front panel on a gigabyte case to install a new case fan
Look on the inside of the case behind the front panel to determine how the front panel is secured to the case.
Depending upon the type of case, remove the side panels or the desktop cover.
Front panels on desktop cases are secured to the case by either screws behind the front panel on the inside of the case, or by plastic locking tabs that needs pushing to unlock fron the case or if the front panel has an opening at the bottom then it may be held in place by friction lugs, in this case pull the bottom of the front panel and it will come away from the case.
Apr 29, 2012 | Gigabyte Computers & Internet
Where would I find the model number for my Amana side by side refrigerator.The problem I have is that the freezer section is keeping solids frozen,but not ice cream and concentrated juices.I noticed the...
Most of the time when the strip is hot it is due to the condenser coils being clogged. If you pull the kick plate off under the door, you should find some coils with dust, hair, and other various debris that has to be cleaned off the coils. These coils can become insullated with dust bunnies and not allow the freon to release enough of the heat as it flows through the coils. The coils actually run through the cabinet where the metal strip is getting hot. Break out a vacuum and clean off the coils and then give it a day and the unit should begin operating properly again. If you can't find the coils underneath remove the back access panel and they should be located to the right of your fan. Also make sure the fan itself is running. The fan is what moves the air flow under the fridge to cool the coils, if it is not running it can cause the same issue.
May 25, 2011 | Amana Refrigerators
How do yoou remove front bottom panel on a kenmore front loader
You remove the lower panel just under the door by removing 3 screws under the curved part 1 each corner and 1 center, once that is done you will have only min working room,\.
Apr 01, 2011 | Kenmore Elite 45986 Front Load Washer
WATER COMING OUT UNDER MACHINE
Is this a TOP LOADER? Or, is this a FRONT LOADER?
If this is a Kenmore TOP LOADER, you will need to remove the exterior washer case to inspect the cabinet interior thoroughly to determine WHERE the leak may be coming from. The following link explains:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
The most common source of leaks on a top loader is a worn drain pump. If the pump is damaged and leaking, it is not serviceable and must be replaced. There is a follow-on link included that explains how to replace one.
If this is a Kenmore FRONT LOADER you need to remove the lower toe panel directly below the door to inspect the cabinet interior. The following link explains:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
The most common source of leaks on a front loader is the rubber door bellow. The bellow can develop cracks, rips or tears with age and needs to replaced. The following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If you have any questions about these repairs, please post back with your complete MODEL NUMBER (located on a nameplate around the door or tub rim) so that I may be able to provide you with better assistance. I hope this helps you.
Jan 18, 2010 | Washing Machines
Kenmore washing machine
Whether this is a TOP LOADER, or a FRONT LOADER, the drain pump is located directly below the wash tub in the front of the washer. Accessing either one takes, different procedures, however.
To access the pump on a TOP LOADER, you must remove the exterior washer casing. Follow the steps provided in this link:
http://www.fixya.com/support/r3631789-washer_case_removal_whirlpool_top
If this is a FRONT LOADER, you must remove the lower toe panel directly below the door. Follow the steps provided in this link:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
The Kenmore Oasis is a different configuration from the two I've mentioned. There are two pumps on the Oasis. One is a drain pump, while the other is a recirc pump. Both are accessible by removing the rear panel of the washer.
If you require further assistance, please post back with a complete model number so I can determine how your washer is configured. I hope you find this information helpful.
Dec 22, 2009 | Kenmore Washing Machines
Samsung front loader leaks out the front of detergent door, extremely bad, drain seems plugged how do I get to it? Or remove panel to clear clog?
Withe the power 'OFF' remove the lid then find the black hose leading from the dispenser to the plastic tank.. if clogged with detergent then squeeze carefully breaking up the powder then flush through.. if the hose is behind the front panel then this could also be done by removing the door seal fron the front panel for access.. i have unblocked many a times this way with as little taking apart as possible.. Thanks
Dec 17, 2009 | Samsung Washing Machines
Kenmore HE2T front loading automatic washer...model 110.4756,4757..displaying F22 error message? What does that mean and how do I fix it?
"F22" is a door latch error. It can mean any of the following:
1. The door latch mechanism is broken. Inspect the door latch to ensure it is intact and not broken. Verify the electrical connections are making good contact.
2. The door latch hook (located on the door) is broken or worn. If the latch hook is damaged, it may not allow the door latch to engage and lock properly.
3. The interconnecting wiring between the Central Control Unit (CCU) and the door latch are loose, broken, or not making good contact. The CCU is the main computer for the washer. You will need to remove the top panel of the washer in order to access. Simply remove the retaining screws located in the back of the washer and the panel will slide back, then lift off.
4. Defective CCU. The CCU controls nearly all the functions of the washer, including the door latch. If the CCU fails, the proper lock/unlock signals do not get sent to the latch mechanism.
Determing how to troubleshoot the CCU and Door Latch is in the technical data sheet included with your washer. The tech sheet is located behind the lower toe panel directly below the door. If the tech sheet isn't behind the toe panel, it will be affixed to one of the interior cabinet walls. I do not have the procedure memorized, but there are some tests you can try to determine if the problem is the CCU or latch.
If you determine the latch needs replaced, the following link may assist you:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
The procedures I provided are for Kenmore Elite series front loaders, which are the larger cousing to the HE2. The steps are nearly the same except for how to remove the door gasket from the front facing of the washer. The HE2 models are glued on instead of using a wire hoop (unless yours is a later model and has been modified). You can use a metal putty knife to carefully peel the gasket loose and reseal it when completed. A good appliance gasket cement (found at any appliance parts retailer) will work. You can also use a plumber's sealant. Just make sure you use a pliable rubber cement. Do not use super glue.
Some prefer to try to work through the top of the washer and avoid removing the gasket. This may be possible with the larger top loaders, but the smaller models are usually a bit more difficult to access.
Replacement parts can be purchased on line at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
If you have any questions, please let me know. I hope you find this information helpful.
Aug 31, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
44 people viewed this question
Sal De
fordexpert
Robert Rankin
