Question about TruTech PLV1615T 15 in. LCD Television
Thermal Image problem
If these can shaped items are bulging, where do I purchase them for replacement?
Thanks for your help.
  • Jules21 May 23, 2008
    Thanks, so what are they called so I can look on Ebay for them?
    Thanks again,
    Champion:
  • 367 Answers
I buy mine on Ebay.Radio Shack has some,but they didn't have the ones I needed,and they are more expensive.I hope this helps.If you have any other questions,please let me know.Thank You very much!
Tyler
Posted on May 23, 2008
  • Tyler Bearor May 24, 2008
    Here is a link to the ones I used to fix my TV.You will have to look at the ones that are bad in your TV to find out the size you need.You should try to get it as close as you can to the original one.You can get one with a higher value on both specs,but not lower.For example,mine had a 10V 1000UF 8MM in diameter,and a 16V 1000 UF 10MM in diameter,and I replace them both with 16V 1000UF in diameter,and it worked perfect.You can also use different heights as well,as long as there is enough room.I hope this helps.If you have any other questions,please let me know.Thank You very much!
    Tyler
    http://cgi.ebay.com/Motherboard-Caps-Cap...
Lcd tv takes a long time to come on and makes clicking noses
Good day!!!
you have a better chances if you have failing capacitors on the power supply board.
just look at the actual image of it..if it is leak/bulged on the top replaced it with the same type,ratings and value..
thanks for using fixya..
Jul 06, 2011 | Samsung Televison & Video
Thermal fault message
Check for bad capacitors on the motherboard. The GX270 boards seem to have issues with this. See if the caps have a bulged X on the top and are not flat on the bottom.
Check out badcaps.net for help in determining if they are bad.
Also one other thing to check. Look at the North-bridge heatsink and see if it has a Z shaped wire running across it. On some Dell machines instead of the Z shaped wire there will be two U shaped wires running across the heatsink. Whether it is one Z shaped wire or two U shaped wires the ends of the wires will be connected to "eyes" on the motherboard.
These wires are part of the temperature sensing circuit. If one of the "eyes" connected to the motherboard is broken off you will get an overheating error.43b2b03.png
Nov 12, 2009 | Computers & Internet
I have a Truetech PLV16190 Flatscreen. Problem: Screen Black (no picture)but sound work fine. Any solutions for this problem? ralphw4606
Open the back of the TV,and look at the can shaped items called capacitors on the circuit boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Feb 18, 2009 | TruTech PLV16190 Television
I was looking at the tv and it went off?
Open the back of the TV,and look at the can shaped items called capacitors on the board that the power cord is hooked to.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.Most of the time the big black capacitor on the power board goes bad,and bottom bulges out,but sometimes it is the other capacitors as well.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Feb 11, 2009 | TruTech PLV16320 Television
NOTHING COMES ON
Tyler
Jan 27, 2009 | TruTech PLV16190 Television
Hello akia lct2715
What are the make,and model of them?Do you have the back off of the TVs?If so,look at the can shaped items on the boards.Do any of them have the tops,or bottoms bulged out?If so,they need to be replaced.This should get it working again.Do you know how to solder?I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Oct 29, 2008 | Akai LCT2715 27 in. LCD Television
RE: Akai LCT2715
What is the make,and model of it?Do you have the back off of the TV?If so,look at the can shaped items on the boards.Do any of them have the tops,or bottoms bulged out?If so,they need to be replaced.This should get it working again.Do you know how to solder?I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Oct 28, 2008 | Akai LCT2715 27 in. LCD Television
How do I test the Lamp Thermal sensor?
Good Day;
The indication that the sensor is bad is showing the "air flow message", not an item that can be tested with positive results. Replace, it's only a couple of dollars. Good Luck, big IRISH.
Sep 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Fuse
Open the back of the TV,and look at the can shaped items on the boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Aug 31, 2008 | TruTech PLV1615T 15 in. LCD Television
Tv need help
Tyler
Oct 17, 2007 | TruTech PLV16320 Television
TruTech PLV1615T 15 in. LCD Television Logo
Top TruTech Televison & Video Experts
Bill Wright
Level 1 Expert
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
