Toshiba 50H81 50" Rear Projection Television Logo
Anonymous Posted on May 21, 2008
Projection tv toshiba
I was watchingtv last night and it just cut off by its self. I unplugged the tv and it came back on for about two minutes and turned right back off. It will not stay on a little red light keeps flashing but the tv want stay on. It is a toshiba. I have had the tv for under a year.
  • star25 Jun 17, 2008
    im am having the same problem i have only had this tv for only about a year & am the 1st owner. my dauughter was wathching tv this morning & she heard a loud noise as if the tv had fell to the ground, & then it shut off & never came back on ,there is a orange light & a flashing red light there is no pics or sound however it does say to conttact customer solutins when i press the menu buttom. please assist by advising somthing thanks!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 18, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
157
Points
My tv did the same thing except it is a 57in hdtv
I've got a toshiba 57H83 rear projection tv. Last night it crackle and went out. The power in the front was flashing. So I unplugged it and plugged it back in and it sounded like an electrical short. Could...
I have had a shorted picture tube do that on a Toshiba before. It could also be a Flyback transformer arcing.
You should call a good TV Tech for an estimate.
Green screen
There is a good chance that it is a bad CRT or a bad CRT Driver Board.
Hope this Helps,
Skyassoc
KDF-46E2000 turns off then back on by its self
* Most common would be a couple of capacitors in the power supply that are not letting the proper voltage to the lamp.
* The lamp itself is not working properly.
50HP66 Plasma TV wont turn on fully. I hit the power button. It goes green for like 3-5 seconds then go back to red off light. It continues this untill I unplug the TV.
did you get your tv fixed? have same problem last night...a loud click and then blank screen and just tries to turn on, can you email at [email protected]
2answers
Phillips 64" PTV Issues
sounds like vertical problems see if you have bad solder connections then get back to me
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
No Picture, Menu screens or anything video - Sound still working!
Yes... Look for F851 and replace it with a slow blow 3.15A fuse per Toshiba. Bill
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
