Question about Casio EXILIM ZOOM EX-Z600 Digital Camera
Lens fails to zoom out (physically)
I switch the camera on and can hear the "motor" mechanism trying to drive the lenses out but they fail to come out well they come only partially out) Is there a fix or is it worth getting repaired?
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Posted on May 22, 2008
I turned on my camera and I get an error message that says, Lens Error Camera will shut off automatically. Then the camera shuts off. The lens will not pop out?
Hi.
This problem occurs when there is zoom-block problem. The solution is to change all the zoom-block, but normally this is more expensive than a new camera.
This mechanism fails due to sand, dust or just useful life expired.
Aug 27, 2015 | Canon PowerShot A4000 IS Silver 16MP...
Shutter wont open or close
Hi seems to be a mechanical problem.
Feb 20, 2008 | Panasonic Lumix DMC-FX3 Digital Camera
Bought a camera off of ebay it worked, brilliant condition after a couple of days, with only 2 uses the zoom bit failed to come out on start up zoom error came up on the screen and through the view...
Your camera has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the manufacturers service department in your country to find out about a free repair. (NOTE: warranty only good for the original owner). If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Oct 02, 2010 | Cameras
Lens wont open
It might seem too obvious, or be something you have already tried, but low battery power can cause this. The camera may appear to be 'on', but the batteries lack the power to drive the servo motor/mechanism to open the lens,
as this is the most power hungry function when firing up a lensed digital camera.
If new batteries fails to fix it, take it to your supplier, the mechanism that operates the lens may need replacement...
Apr 07, 2010 | Polaroid i1035 Digital Camera
Nikkon Lens works on Manual only now.
the autofocus motor in lense assembly is worn out. once changed it will start working fine.
Apr 02, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Zoom lenses is extended but wont go back in
Switch on and PRESS the "wide angle" selector switch. (in camera mode)
Now the lens should move partially back in.
If it does not move inwards at all and you do not hear a whirring noise, then the activator motor is defect.(or the lens assy is out of alignment). (or a foreign object has entered the gearing, and stalling the motor)
If you do hear the motor running, then a gear might be stripped.
All these faults do require to take the camera apart.
Mar 08, 2009 | Fuji FinePix F650 Digital Camera
Zooming lens got stuck up
The lens need to be replaced and is failing I have new lenses in stock if you need more information go to www.digitalcamrepair.com.
Mar 02, 2009 | Sony Cyber-shot DSC-W30 Digital Camera
Nikon d40 wont autofocus
Your 28-90 AF-D lens can't autofocus with the D40, which requires AF-S lenses with a focus motor in the lens. Sigma lenses with "HSM" (HyperSonic Motor) in the name also have the focus motor.
Feb 23, 2009 | Sigma f/NIKON- 28-90/3.5-5.6 Aspherical...
OLYMPUS DIGITAL ALL WEATHER
1) Make sure that the batteries are in good condition
2) Check and clean any dirt or corrosion from the battery terminals.
If the power supply voltage suddenly drops during initialization,
or when the lens is trying to extend itself, it could produce this
kind of error.
3) Make sure that the lens extension tubes are not mechanically
jammed.
4) Remove the batteries, turn the unit ON and wait for it to fully
discharge any internal capacitors, then put the batteries back
and try to turn the unit back on. This should fully RESET the
internal CPU.
Generally this kind of error means that the camera's internal
computer is trying to activate the lens zooming motors, but
the motors fail to move as expected.
Other causes could be:
a) burned out ZOOM motors
b) burned out motor drive circuitry
c) bad motor positioning sensor
d) defective computer components
e) failed internal firm-ware.
none of these cause are user fixable.
Hope this helps
Martin
Nov 10, 2008 | Olympus Stylus 700 / 700 Digital Camera
Jammed digital zoom lens
For whatever reason, the lens has failed. This can be caused by many things: the lens motor has failed or is stuck, the gears involved in driving the lens have jammed, or, as pointed out previously, the lens itself, a series of tubes which fit into one another has become stuck. You can try GENTLY pressing down on the lens when you first power the camera to see if you can free up the stuck lens. If that doesn't work, I'm afraid you are going to have to get the camera serviced.
The clicking sound you're hearing is the lens trying to move itself. Unfortunately, it's probably not going to be fixed by pushing on the lens. You are going to have to get the camera serviced. Sorry!
Oct 27, 2008 | Polaroid Cameras
Casio EXILIM ZOOM EX-Z600 Digital Camera Logo
27 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
