Question about Orion STV2763 27" TV
Just want the Orion TV (Model: STV 2763) to play VHS videos
How do I hook up the TV to the Panasonic VCR (Model: PV 8661) to play video's ?
Is it possible to hook a portable DVD up to play on the Television?
Problem Solved:
Take your connector with the 3 colors red,white & yellow and plug into VCR OUT. The other end (w/ 3 plugs) goes into the INPUT on the back of the TV. Next insert a VHS Tape & search the TV for input or a channel below #2 for Cable#1,2,3 or AUV Channel.
In this case; Channel AUX #1
Shows / Plays Video w/ clear sound & picture.
Yahoo.
Posted on May 22, 2008
My Panasonic PV-8661 will load a tape but will not run. It stops immediately after pressing Play, Fast Forward or Rewind. The large gear wheel just rotates back and forth.
There is a possibility of some damage to the mechanism. You will have too look around for plastic parts that are damaged.
Another possibility is the mode switch is playing up. This tells the electronics what position the mechanism is in. Sometimes a spray of Servisol Video 40 on it will cure it. But if it is worn out, then it won't. You can get them, but to fit it in you will need the service manual, as they are very tricky to set up right. For example they are rarely set up in the eject mode!
Dec 11, 2015 | Panasonic PV-8661 VHS VCR
How do i hook it up to my tv
The simplest way is to connect the screw on connector marked Output on the back of the VCR to the screw on connector marked antenna or cable input on the back of the TV. There will be either a switch or menu item on the VCR where you chose to have it output on channel 3 or 4. Chose which you prefer and then tune the TV to that channel.
Sep 30, 2014 | Panasonic Pv-9400 Vhs Vcr Hi-fi Video...
Having trouble hooking old VCR up to new LG TV and Integra Receiver. Feel like I'm missing a step...
Look at the back of the tv. What is it labeled at where you plugged the VCR into. Should probably say composite in. After that's verified, go into the tv menu and make sure you have selected composite input. Should be no need for any settings on VCR, it has to be settings on tv
Jan 11, 2013 | Panasonic Omnivision PV-7401 4 Head VHS...
Just want the TV to play VHS video
check channel and check plugs
May 21, 2008 | Orion STV2763 27" TV
Trying to hook up a playstation one
Make sure you have the cables connected correctly from the playstation to the VCR.
Yellow colour is Video output from playsation to Video input on VCR.
To get the audio from the playstation to the VCR just match the colours of the RCA connections.
Do not forget to select video input on the VCR as well.
Good Luck.
Mar 02, 2008 | Panasonic PV-V4540 VHS VCR
Orion STV 2763 27in TV
I am assuming that your TV has Video IN source selection.
You need to use the Video/Audio OUTput of the VCR/CD and connect them to the Video/Audio INput of the TV. To do this you would have to use a 3-wire shielded cable with male RCA connectors color yellow, red & white.
c296912.jpg RCA male connectors, yellow is usually video, red/white is audio left/right.
599898c.jpg as shown OUT of VCR/CD to IN of TV.
Pnce done, play the VCR/CD with a good known CD or tape and set TV to Video mode.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 31, 2008 | Orion STV2763 27" TV
Help me fix my orion tv problem
Let it run an autoscan or see if in the menu it has channels that are blocked or disabled.
Nov 26, 2007 | Orion STV2763 27" TV
Auto-powering off within seconds of turning on
timing out or takeup sensor faulty located next to carriage
Mar 18, 2007 | Panasonic PV-8661 VHS VCR
Orion STV2763 27" TV Logo
152 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
