Question about Danby DWM99W Top Load Washer
Won't wash I just hooked up the Danby DWM99W and it fills with water, but won't proceed to wash. It will drain and spin if I change the setting. But won't wash. Can anyone help?
I didn't realize that you have to let the faucet run the entire duration of the wash cycle. But that was the problem.
Posted on May 22, 2008
  • Kim Henry
    Kim Henry Sep 05, 2014
    You shouldn't have to keep the faucet running unless you have the drain open.
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
My danby washer model DWM99W will not drain or spin or drain out the water please tell me what the problem is
I don't have a solution but mine is doing the same thing. Sounds like the motor is running but the washer will not drain. And now it won't spin either??? HELP!
Feb 10, 2011 | Danby Washing Machines
My Danby washer always drain the water when it fill the water up on the 3 and 4 water level setting. So I can't wash clothing at all. Hope get answer soon.
The answer is the drain hose. It must be routed higher than the machine or water will always drain. There is no actual drain valve.
Oct 07, 2010 | Danby DWM99W Top Load Washer
The water level will not stop filling up to the level desired. Washer will not drain out and then I need to empty it with a cup.
Your water level sensor is likely faulty. Contact your retailer, or Danby directly, for a replacement and instructions on how to do so. Note, if this is in warranty, they may require you to bring it to a service center.
Aug 27, 2010 | Danby DWM99W Top Load Washer
Daby dwm99w drains and fills water at the same time.
The outlet of the drain hose must be higher than the highest level of water in the tub. Otherwise, it just siphons through.
Aug 01, 2009 | Danby DWM99W Top Load Washer
My danby fills and immediately drains.
Hi, It sounds like the drain hose has dropped lower then the water level in the washer. Check and see if the hose end is as high as the top of the washer.
I hope this helps you.
Vic
Jul 10, 2009 | Danby DWM99W Top Load Washer
Washer Won't spin & smells burning when it goes on spin
Hi there.I think it could be that when the belt was changed the bolt wasnt tightened onto the flat side of the spindle.I am talking about the small pulley that comes off to replace the belt.It has one flat side in which the bolt needs to be otherwise it might just spin because the laundry weight. Quick question I have this machine and it needs a replacement belt.I cant find one anywhere!!!!Where were you able to find one???? Good Luck
Feb 19, 2009 | Danby DWM99W Top Load Washer
Danby washing machine noisy only during spin cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jan 13, 2008 | Danby DWM99W Top Load Washer
Washer fills, but doesn't do anything else
if it fills then the power is there open the lid and make sure all connectors are on to the timer if they are then more then likely u have a motor problem check carbon brushes if these are low then the motor wont turn the drum if there is no carbon brushes ull have a module if this is faulty most of the time its cheaper to replace the washer m8
Aug 28, 2007 | Danby DWM99W Top Load Washer
Danby DWM99W Top Load Washer Logo
198 people viewed this question
Top Danby Washing Machines Experts
shaun taylor
Gerry Harvey
Gerry Harvey
Mike
Are you a Danby Washing Machine Expert? Answer questions, earn points and help others
