Question about Refrigerators
I have an Oster wine cellar. the fan stopped working could it be a fuse and how do I replace it?
  • 7 more comments
  • Anonymous Jun 14, 2008
    the fan in my wine cooler stopped working
  • swhetsell Jul 13, 2008
    my oster 12 bottle wine chiller has stopped cooling as well. we have had it two weeks. it was set at 53 and was holding at 54... i left for an hour... and it had gone up to 65. investigation of the situation indicated that the fan had stopped running.
  • jas2599 Sep 13, 2008
    I got my Oster wine cooler for my birthday in February, 2008. I noticed last week that the temp. went up to 70 degrees and now is up to 80 and has not come down. It's only 7 months old and it's clear the fan stopped working. Sounds like a lot of other people are having the same problem with this product.
  • mepamT Sep 24, 2008
    Our's did the same thing. I contacted warranty & followed their instructions. It's been months & no refund. I called the # on my warranty card & it isn't a working number now. Does anyone have a different # than 866-866-6283? What a rip off.
  • davidgutre Nov 09, 2008
    My wine cellar fan also stopped working. If anyone knows hoew to solve ths or where to call for warranty I would appreciate it
  • Anonymous Nov 10, 2008
    After about a couple months the temperature display lights started going out one by one. Then after 10 months or so the fan died on me too. It sounds like the Oster wine coolers have a lot of problems, that's why they are so cheap. I went to Best Buy and the manager gave me 10% off on a Vinotemp. 200 bucks, but you get what you pay for.
  • Anonymous Nov 25, 2008
    Ditto
  • fitema06 Dec 20, 2008
    fan stopped working 4 months after receiving this wine frig has a gift,
    I could only hope that they stand by their product and do the right thing.
    mary
    Pennsylvania
  • Anonymous Jan 03, 2009
    Same problem after about 7-8 months. Piece of junk.
Do not bother trying to contact the company which made the unit they are being indigted on fraud. The good thing is that there is a simple solution to your problems. Replace the small fuse under the electric shrink wrap. This fuse is located near the red and green led lights on the electronic panel in the back of the unit. Replace with a 6.3 or 7 amp 250 volt fuse 3 x20mm , which can be found at Radio Shack. You will need to know how to solder in order to replace. All total cost to replace the fuse is about $3.00 and a half an hours time. The unit works great now, I paid another $3.00 to put in an inline fuse holder for the future when this fuse blows, if it does.
Posted on Jan 02, 2009
Stopped cooling no humming or nothing digtal reading are working but nothing else
you need to replace the fan at the back of the unit. no noise means the fan is not working. The fan removes the heat from inside the unit to cool it. no fan, no cool. Your local appliance repair can fix it. the fan does not cost much and there isn't much labor involved. If you want to tackle it yourself then take your model number to the appliance store and order a fan, remove the back and replace the fan. Some fans are plug and play, some are not. if yours is not plug and play then you will have to splice wires. either way, the fan is your problem.
Nov 23, 2010 | Oster 12-Bottle Wine Cellar - Black
Digital temperature display is missing part of the
You are going to have to replace the display. Easy fix even if you are not very familiar with this system
Jan 02, 2010 | Oster 12-Bottle Wine Cellar - Black
Wine cooler does not get cool - fans do not run the light and temperature display do work
if you hear the compressor tun on but not the fan, replace the fan and you may have to defrost the evaporator coils. if the compressor does not turn on either, it's the thermostat, the defrost timer, or a relay on the main board.
Nov 12, 2009 | Oster 12-Bottle Wine Cellar - Black
Wine Cooler Does NOT get cool.
Here is the web site to locate your closest oster service center. They should be able to tell you what their charge will be up front so that you can compare that charge to the cost of a new one.
Now days, sadly, many of these items are too costly to repair so they go to the landfill..
http://www.oster.com/CustService.aspx?content=center
May 21, 2009 | Oster 12-Bottle Wine Cellar - Black
Fan doesn't work on oster wine cellar
First question, do you have power to the unit and the cooling fan is not working? If this is the problem then sounds like one of the two fuses in back panel has burnt out.
Dec 30, 2008 | Oster 12-Bottle Wine Cellar - Black
The fan does not go on
Ther are two fuses in back panel of unit. One fuse can be seen other is hidden top left of panel and is coated in black shrink rap. I had to replace that fuse to correct the problem. Problem is I had to cut away shrink rap and resolder another fuse, you may have to have someone who can do this look at your uint. Hope this helps.
Dec 19, 2008 | Oster 12-Bottle Wine Cellar - Black
Brassnsassy96@yahoo.com
can you pull it out and see if the compressor is running,if it has a fan hold the fan with a rag to stop iy and put your hand on the comp. to see if it is running,if not i think you need a 3in1 start to get it going again,let me know what you find-mike
Nov 12, 2008 | Oster 12-Bottle Wine Cellar - Black
Fast start option does not work
I'm not sure how you ended up under this classification;
All Products > Oster > 12-Bottle Wine Cellar - Black > Troubleshooting
but your problem with an undescribed brand and model will not likely ever get a response.
I think your question is in regards to a microwave oven. Try reposting it with the correct brand and model #.
Nov 06, 2008 | Oster 12-Bottle Wine Cellar - Black
Oster wine cooler fuse
I just replaced mine with a "Slo Blow" and it is working just fine. Got it at Radio Shack , 4 for approximately $3.
Sep 25, 2008 | Oster 12-Bottle Wine Cellar - Black
Refrigerators Logo
261 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
