Question about Orion STV2763 27" TV
Just want the TV to play VHS video
Cannot get my Orion TV Model: STV 2763 to play VHS video's from my Panasonic VCR (Model: PV 8661). Just got a hand me down (TV worked this morning) TV .
I must have hooked it up wrong. What are the necessary connections to get just these two to work properly?
    Problem Solver:
  • 11 Answers
Check channel and check plugs
Posted on Nov 14, 2008
My Panasonic PV-8661 will load a tape but will not run. It stops immediately after pressing Play, Fast Forward or Rewind. The large gear wheel just rotates back and forth.
There is a possibility of some damage to the mechanism. You will have too look around for plastic parts that are damaged.
Another possibility is the mode switch is playing up. This tells the electronics what position the mechanism is in. Sometimes a spray of Servisol Video 40 on it will cure it. But if it is worn out, then it won't. You can get them, but to fit it in you will need the service manual, as they are very tricky to set up right. For example they are rarely set up in the eject mode!
Dec 11, 2015 | Panasonic PV-8661 VHS VCR
No picture on tv when playing dvd or video
does it have a picture for regular TV watching .if so then the dvd player has gone bad
Nov 22, 2015 | Panasonic Pv-d734s Dvd Vhs Player Combo...
Just want the Orion TV (Model: STV 2763) to play VHS videos
Problem Solved:
Take your connector with the 3 colors red,white & yellow and plug into VCR OUT. The other end (w/ 3 plugs) goes into the INPUT on the back of the TV. Next insert a VHS Tape & search the TV for input or a channel below #2 for Cable#1,2,3 or AUV Channel.
In this case; Channel AUX #1
Shows / Plays Video w/ clear sound & picture.
May 21, 2008 | Orion STV2763 27" TV
Recording on a Panasonic VCR
This problem is undoubtably dirty or worn video heads. Try using a good quality head cleaning tape. If this fails, re-post, and I will explain how to clean heads by hand.
Dave Duff
Mar 01, 2008 | Panasonic PV-V4022 VHS VCR
Orion STV 2763 27in TV
I am assuming that your TV has Video IN source selection.
You need to use the Video/Audio OUTput of the VCR/CD and connect them to the Video/Audio INput of the TV. To do this you would have to use a 3-wire shielded cable with male RCA connectors color yellow, red & white.
c296912.jpg RCA male connectors, yellow is usually video, red/white is audio left/right.
599898c.jpg as shown OUT of VCR/CD to IN of TV.
Pnce done, play the VCR/CD with a good known CD or tape and set TV to Video mode.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 31, 2008 | Orion STV2763 27" TV
Need remote code to control a Panasonic Omnivision VHS PV-M2079 TV/VCR combination
You need to program the VCR (which turns the sey on/off) as an aux, then program any Panasonic TV type for TV, and then set the STB button to control STB, TV and AUX and you should be set.
Jan 03, 2008 | Televison & Video
Help me fix my orion tv problem
Let it run an autoscan or see if in the menu it has channels that are blocked or disabled.
Nov 26, 2007 | Orion STV2763 27" TV
Auto-powering off within seconds of turning on
timing out or takeup sensor faulty located next to carriage
Mar 18, 2007 | Panasonic PV-8661 VHS VCR
Orion STV2763 27" TV Logo
99 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
