Question about Nokia N81 Smartphone
Loudspeaker Nokia N81 - 8 GB
Hi, the loudspeaker on my nokia N81 is not working during a call. The option for loudspeaker displays handset instead.
The function used to work, and I have had the phone for less than 1 month.
thanks.
  • 1 more comment
  • anithebunny Jul 14, 2008
    i'm suffering from the same problem....in the beginning i could put a call on loudspeaker wen attending a call.....all of a sudden...this is not possible....instead of loudspeaker it shows headset only on the right bottom while on a call....
    disappointing
  • Anonymous Nov 16, 2008
    help us!! same happened to me!
  • b88gin Dec 16, 2008
    Loudspeaker not working anymore.
    Used to work.
    Now says handset.
    What can I do?
Do you have ab luetooth headset connected?
if so try closing the connection..
Posted on Jun 05, 2008
How do I turn on the speakerphone
From the Nokia 2680 manual:
"Loudspeaker
If available, you may select Loudsp. or Normal to use the loudspeaker or the earpiece of the phone during a call."
Does your phone definitely have speakerphone? It seems that it's an option, not standard on all of this model.
Aug 10, 2012 | Nokia 2680 Slide Cell Phone
I updated my nokia e71 software. it was noticed that the loudspeaker symbol which used to come immediately after i dial a call is not coming now. Loudspeaker symbol only comes when the call is connected.
2 solutions to your problem.
1. Either restore the phone's software to the original state through Nokia PC Suite.
OR
2. Update the Nokia E71 software with the latest patch from Nokia Service Center.
I have Nokia E71 Black Handset with me and whenever I dial-in and gets success then only I get the "Loudspeaker" option enabled in the right hand corner of the screen. Once you activate this option, the Loudspeaker option is visible.
Thanks,
Amar Narkhede
Oct 06, 2010 | Nokia E71 Smartphone
I have nokia n85 i can't hear anything when i use headset
hi, try change your ear piece...it faulty.
cheers
May 29, 2010 | Nokia N85 Cellular Phone
Hoe to turn on loudspeaker in nokia 2760
During a phonecall, you will just have to press the button, usually the right option button where the "Loudsp." is aligned to it.
Also, when you want to listed to an audio message, select Options and select Loudspeaker.
Hope this helps.
Nov 06, 2009 | Nokia 2760 Cellular Phone
In my mobile there is no loudspeaker option in Nokia 6681
For volume and loudspeaker control increasing or decreasing the volume level when you have an active call or are listening to a sound, press left or right scroll, respectively. Sound applications use the loudspeaker by default.
To use the loudspeaker during a call, start a call, and press the button with the talking face icon and press again to return to earpiece.
If it does not work the speaker, or amp circuit is bad or there is a glitch in the firmware. Replacing the speaker is the only economically viable repair. If the amp circuit or firmware has malfunctioned a new phone is in order.
Jul 05, 2009 | Nokia 6681 Cellular Phone
No sound in handset mode but working fine on loudspeaker
YOu know,its all right with ur phone,but the headset may not be supported by the phone,i mean its enhancement cant support the headset model. change it and it might work.
Jun 10, 2009 | Nokia 3120 Cellular Phone
Volume
Volume control
• When you have an active call or are listening to a sound, press o) or (o to
increase or decrease the volume level, respectively.
Voice volume icons:
- for earpiece mode,
- for loudspeaker mode.
Loudspeaker
Your phone has a loudspeaker for handsfree use. The loudspeaker allows you to
speak and listen to the phone from a short distance without having to hold the
phone to your ear, for example, having it on a table nearby. The loudspeaker can
be used during a call, with sound and video applications, and when viewing
multimedia messages. Sound and video applications use the loudspeaker by
default. Using the loudspeaker makes it easier to use other applications while in a
call.
Apr 02, 2008 | Nokia 6600
Microphone not working
Many of the options that you can use during a call are network services. For availability, contact your service provider.
During a call, select Options and from the following options:
Call options are Mute or Unmute, Contacts, Menu, Lock keypad, Record, Voice clarity, Loudspeaker or Handset.
The Volume key is on the side of your phone, <--> up or down during a call.
Mar 22, 2008 | Nokia 6300 Cellular Phone
Loudspeaker does not work
What type of phone do you have? and does it have a wide audio headphone connectors ? as same as Nokia phones?
Usually it's a problem with the "headphone" settings...
Good Luck
Nov 02, 2007 | Cell Phones
Nokia N81 Smartphone Logo
170 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
