Question about Xerox WorkCentre XL2140df Laser Printer
Will not start
The printer will not start and there is a clicking noise
  • kqqd9m May 22, 2008
    The light comes and the lamp moves, the print/start light blinks and when I push it nothing happens. If you stand facing the back of the printer there is a motor on the left side almost directly in back of the fuser, is this drive motor or is it behind the parallel printer interface card.
    Thanks,
    Gary
    President:
  • 2,072 Answers
First off, open the document feeder and see if the lamp is moving freely. If not remove the glass and find what is binding it.
Next listen closly to the drum and toner cartridge for noise.
If the noise is from the right side door, then the fuser gear has worn out. But I am assuming it will NOT feed paper. If it was the fiser gear it would jam in the right side door.
Then UNPLUG the machine. remove the back cover, and on the right half of the machine, locate the main drive motor, about 4 inches by 3 inches. Held in with 4 pillips screws and one connector. Once you remove it inspect the helix gear pressed onto the motor shaft. It can appear perfect but be split and slipping on the shaft. You want to see if you can pull it off the shaft or easily spin it and not the motor shaft. If so you must replace the motor.
Let me know please.
We can progress and find the problem. These are the most likely issues. But not all.
Posted on May 21, 2008
HP 8600 makes clicking noise takes long time to start printing
Solved!
Found a misfed page jammed inside the printer on far
right side ( by the ink service station) - after removing the
"hidden" wad, the printer no longer makes "clicking" sounds
and prints right away!
Officejet Pro 8600
Feb 18, 2013 | HP Officejet Pro 8600 Premium e-All-in-One...
Making a clicking noise when it prints.
Here is a great guide that you can follow to try to identify where the noise is coming from and try to fix it or have it fix.
http://bit.ly/dif9Ck
Feb 06, 2010 | Lexmark T630 Laser Printer
Loud clicking noise when turn on printer
I would check wherever possible for foreign objects in the printer. Failing that, a partial reset is available for your PSC 2410:
A partial reset can be done by:
1) Unplugging the power cord (you are already there!)
2) Press and hold the (#) key and (3) key while plugging the unit back in
Dec 28, 2009 | HP PSC 2410 All-In-One InkJet Printer
Weird noise from printer carriage
The loud clicking noise is probably the carriage trying to move and something is keeping it from doing so. Check to see there are no foriegn objects obstructing the carriage head from moving across the paper. If nothing is found, then likely a hardware error exists.
hope this helps!
Aug 31, 2009 | HP Photosmart 3180 All-In-One Printer
Dell 964 AIO will not work just makes a fast clicking noise.
yes, the old printer has a broken tooth. it is going to cost you the same in repair as to buy a new one.
May 13, 2009 | Dell Photo 964 All-In-One InkJet Printer
My printer is making a clicking noise
I woudl try uninstalling and reinstalling the printer. It may have gotten confused.
Dec 21, 2008 | Office Equipment & Supplies
Makes noise
Click HERE for HP troubleshooting for your printer.
Jun 06, 2008 | HP Officejet 5610 All-In-One InkJet...
Printer makes clicking noise
Make sure the printer is not out if ink. When the light flashes this may be the case. Also check the print queue. If it contains pending print jobs and there is no paper the light will flash. Here is how to check print queue: Click Start > click priters and faxes > double click printer icon and see if there is something ... If you see any print jobs delete them right away. and restart your computer. This should solve your problem.
Oct 05, 2007 | HP PSC 2410 All-In-One InkJet Printer
Printer makes extremely loud clicking noise
http://printer.konicaminolta.com/support/current_printers/mc2430dl_sup.htm#Printer_Specific_Documentation The user guide should be helpful to you to pinpoint what is causing the noise. Sounds like the belt drive or gears may be having a problem. Let me know what happens. Tim
Mar 06, 2007 | Konica Minolta magicolor 2430 DL Laser...
Xerox WorkCentre XL2140df Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
