Toshiba a60??? Hey guys, For the past month, my laptop has been acting up. I had had to press hte power button several times in order for the computer to actually boot up. Evertime i pressed the button, the blue light would flicker on, but nothing would start up, till after about the 6th or 7th try, things would eventually get going. NOW the light flickers when i press the button, but the computer doesn't turn on anymore????
    Problem Solver:
  • 5 Answers
If this happens even if your laptop is plugged in to a power source it could be that your battery is dead and you need to replace it
Posted on May 21, 2008
I have a toshiba sattelite pro L850 , num lock is on, power led is on, and so the wifi led, but it does not start up just like that.. i tried resetting the memory, i did swap, took out the hard drive even...
Found this answer. hope this works for you
"First turn your computer off by pressing and holding down the start button. Next unplug the computer and then remove the battery. Press and hold down the start button for about 60 seconds. Release the button and plug in the computer power cord. Press the start button and the display should return. Replace the battery. If this does not work, try it again up to four times. No results usually indicates a bad mother board."
Mar 02, 2015 | Toshiba Computers & Internet
Check system then press f1 key
Try this:
Instructions
    • 1
      Insert the Toshiba A60 recovery disc into the CD/DVD-ROM drive.
    • 2
      Power off the Toshiba (with the recovery disc still loaded inside the optical drive).
    • 3 Hold down the "F12" key, at the same time hit the "Power" button to turn the system back on. You don't have to hold down the Power button, but keep holding the F12 key.
    • 4
      Release the "F12" key when the" In Touch with Tomorrow TOSHIBA" screen is displayed. This will open up the BIOS.
    • 5
      Change the boot order by using the arrow keys to select "CD/DVD ROM" icon in the menu. The Toshiba will now boot from the recovery disc and restore the system. Follow any additional on-screen instructions.
Aug 19, 2012 | Toshiba Satellite A60-S166 Notebook
My Toshiba Laptop is not turning on though i charge it. When i click on the power button, i see the lights going green but nothing appearing on the screen. The caps lock or the num lock is not working....
Remove the battery and use this laptop on mains/wall power, with the aid of the power brick from Toshiba. As the battery may be giving problems.
Else it may be that the computer system is experiencing severe problems, in which case a computer technician needs to help.
damnor01
Apr 04, 2011 | Toshiba Satellite A60 Notebook
Toshiba Satellite A60 wont power up
It looks like some divece in your laptop dont pass POST test. Tech support from Toshiba required
Sep 23, 2009 | Toshiba Satellite A60 Notebook
Restore to factory settingswith out cd
for toshiba factory reset without disk like this
Toshiba: BEFORE TURNING ON THE LAPTOP, press and hold the 0 (zero) button on the keyboard, then turn on the computer while holding the 0 (zero) button down. When the Toshiba logo screen appears, you can release the 0 key.
Pls rate me FIXYA for help !
Apr 11, 2009 | Toshiba Toahiba Satellite A60 A65 Series...
Intermittent power up
take out your battery then put it again,
put the original RAM, your laptop is not supporting this RAM
Oct 20, 2008 | Toshiba Satellite A60 Notebook
Toshiba satellite that randomly shuts off
may be hitting event of your laptop
also u can try to reset your bios.
go to your bios setting load default settings.
then restart pc.
Apr 01, 2008 | Toshiba Satellite 1805-S274 Notebook
Selling Laptop
You should have a restore cd that came with the computer. If not there may be a restore partition on the laptop's hard drive. If you have the latter you should be able to enter this restore mode by pressing a specific key combination during the boot process.
Dec 30, 2007 | Toshiba Satellite A60 Notebook
Toshiba doesnt start
Power suply or motherboard problem...Check those tooo
Nov 24, 2007 | Toshiba Satellite A60 Notebook
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
