AutoCad Prob i am trying to copy and paste an object from one into another drawings. when I attempt this, the following displays on my screen: ARX ERROR: eDuplicateKey and it will not cancel and I have do CTRL-ALT-DEL to get out of AC i have never seen this before...help would be awesome!!
Autocad changes lost
The most effective solution is .dwg recovery tool when other methods don't work
The place where you may read various thing about Autocad
Here you may read more about article below
However, a few things may get it to open:
  • Try to open the drawing file directly instead of using the Recent Documents menu.
  • Check that the storage location that holds the drawing is working properly.
  • Use the RECOVER and RECOVERALL commands on the drawing.
  • Attempt to insert the damaged file into a clean drawing or template using the INSERT command.
AutoCAD Recovery tool How to repair corrupt AutoCAD drawings and fix its errors Error Drawing file is not valid when opening file in AutoCAD
Aug 28, 2017 | Computers & Internet
My autocad dwg files have been corrupted
Displays a list of all drawing files that were open at the time of a program or system failure. You can preview and open each drawing or backup file to choose which one should be saved as the primary DWG file. After a program or system failure, the Drawing Recovery Manager opens the next time you start the application. Drawing Recovery Manager displays a list of all drawing files that were open. The System Variable RECOVERYMODE controls whether drawing recovery information is recorded after a system failure and whether to show the Drawing Recovery Manager or not.
If you want to help yourself, Autodesk and other AutoCAD users make sure to send in any errors to Autodesk when you see the Customer Error Report dialog box (CER).
Finally a solution that sometimes helps if AutoCAD cannot fix the problem is to try to fix the drawing in another program that can open and save DWG files. The more users having the similar problem the better chance it will be fixed in a service pack or future version. Eventually you might
get DWG Restore Toolbox saying the problem is fixed.
from website: http://www.dwg.restoretools.com/
Jun 20, 2015 | Autodesk AutoCAD 2010
I purchaced AutoCAD 2005 new in 2005 and it has been a brilliant program that has forfilled all my needs in this feeled. As i am no longer in the area of work that needs this program I use it simplyfor my...
Hi Keith, have to tried to install and run in compatibility mode? If this does not work there are 2 free alternatives. They are DraftSight and DoubleCAD XT. Both of these are LT clones and offer pretty much all that r2005 had except 3D, Lisp and ARX. If 2D is all you need have a look at these.If I had to pick one I would go with DraftSight as it is a closer copy to AutoCAD.
Again try WinXP compatibility mode and see if that works.
Jun 07, 2011 | Autodesk AutoCAD 2005
I am using Serif Draw Plus x4. Having completed the line drawing, I now want to copy it and paste it to a text box in a Word doc. What's the quickest way to do this, please? Richard Royds
Well follow my lead :
1. Click on insert tab .
2. Select the object option.
3. If you have to display the content select object menu item.
4. A drop down list will open select the serif plus program if visible if not then you can only link the file.
5. now a browse file dialogue box will open select your file that is to be shown.
6. that's it enjoy.
easier method.
1. install Ashampoo magical snap( takes screen shots from your desktop)
2. take the screenshot of your file and save it as a picture.
3. now i guess you know how to display a picture in a word document
have fun :)
vote if solved
Feb 16, 2011 | Serif Computers & Internet
Autocad 2010 problem
If you run Win7 in XP mode, all should be fine.
May 06, 2017 | Autodesk AUTOCAD LT 2008 SLM 10 SEATS...
The lcd screen on MY moultrie d 40 doesnt show anything except a bunch of lines at teh bottom. can this be fixed?
Yes, the LCD display needs replacing, a known prob. Contact Moultrie by e-mail @ www.moultriefeeders.com and tell them the prob.They will ship a new display with instructions no cost to you.
Nov 15, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Problom on Activeting AutoCAD 2005
I assume that you are a true student. If so, there are options for you to have a copy of AutoCAD latest versions from the Autodesk company itself. Try to provide your info at the website, asking for a copy and convey them your attraction towards the AutoCAD as a engineering drawing software.
Hope you get it soon.
Bye
Have a nice day
Nov 12, 2008 | Autodesk AutoCAD 2005
Digitalizzing problem
I have a problem with the same hardware and software. I'm using AutoCAD 2008 and when I trace an object that is 1:1 it come into AutoCAD as a different scale. I have tried different scale factors in AutoCAD and nothing.
Jun 02, 2008 | GTCO CalComp Drawing Board III 34180...
Print problems
Print to fit page prints thumbnail size image.
trnsp.gif Answer Zoom out to make your design appear on a single screen, drag and draw a box around it, using the Select Objects Tool. Once it's all selected, go to Edit > copy, File > new, Edit > paste. Print from this new file.
Note: this may be caused by an extraneous object on an outer edge of your plan. When you zoom out, pan around your design to see if there is a stray object, which you can delete.
Mar 12, 2008 | Punch ! Professional Home Design Suite for...
Computers & Internet Logo
205 people viewed this question
David Payne
David Payne
