Question about Asrock Computers & Internet
Building a computer
I am building a computer for the first time.I have an intel p4 3E GHZ 1mb L2-cache,800 MHZ FSB,478 PIN.& an asrockp4i65g motherboard.getting lost trying to work out what configures with what.i need a list of everything i will need from top to bottom & some suggestions on the best products.i know these arent the fastest components but thats all i got.thanks v much.
  • GLEN72154 Feb 27, 2009
    SOUND DRIVER
    Problem Solver:
  • 5 Answers
Well, first the obvious. You will need a case to house everything, as well as a quality power supply. Get an Antec, Thermaltake, BFG, Coolermaster, or other equivalent quality brand. You shouldn't need one too powerful, quality is more important here. Next, you will need a Hard drive. I would suggest IDE, since your motherboard is an early SATA board and you might have problems for a first timer. Also, a DVD burner, again IDE, also called PATA. Go for a matched set of memory, DDR400. Best would be 2 gigabyte set, but 1 would be ok too. You might check Asrock's website for memory tested compatible, but I have always had incredible luck with Patriot memory. You might need 80 pin ide cables, etc, if they didn't come with your board. Finally, you will need a licensed copy of Windows, either xp or vista, your choice, although since your hardware is a little older I would suggest xp. If your motherboard did not come with a driver disc, you will probably need to download drivers to install after windows (http://www.asrock.com/mb/download.asp?Model=P4I65G&s=478) My favorite place to buy (i have probably spent over $20,000 there) is newegg (www.newegg.com). I hope this helps, and if you have further questions I will be happy to try and help.
Posted on May 22, 2008
CAN NOT SUPPORT 2.8/1MB/533
That's because your motherboard only supports Northwood chips that have a L2 cache of 512 K. The chip you are trying to use is a Prescott chip with 1MB of L2 cache.
Your best bet would be to buy an INTEL Pentium 4 3.20GHz/512/800 Processor SL6WG Socket 478. It is a Northwood chip with an 800 fsb and has hyperthreading. There is a 3.40ghz model, but you can get the 3.20ghz chip much cheaper.
Here is your motherboards specs page:
http://support.lenovo.com/en_US/detail.page?LegacyDocID=MIGR-51078
May 19, 2012 | IBM ThinkCentre S50 8183 - P4 3 GHz...
CAN NOT SUPPORT 2.8/1MB/533 PROCESS
Here's your motherboards specs page:
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
Cant run 3E GHz 800 FSB L2 cache 1MB cpu on a ASUS P4P800s-x
here are the specs.
CPU FSB DDR DIMM Type Memory Frq.
800Mhz PC3200/PC2700/PC2100 400/333/266 Mhz
533Mhz PC2700/PC2100 333/266 Mhz
400Mhz PC2100 266 Mhz
the CPC and the moemories meets these spec. then you shouldn't have problem.
since you didn't spec the meories. I am assuming that the meories are within specs.
but, from what you say about, I suspect the memories is not up to part. looks like the meories are in PC 2100 range.
Nov 14, 2008 | ASUS P4P800S-X (610839118175) Motherboard
Cpu upgrade
Your computer has one of these options:
spacer.gif level2_arrow.gif Intel® Celeron® Processor 560
(1MB L2 cache, 2.13GHz, 533MHz FSB)
or
Intel® Celeron® Processor 550
(1MB L2 cache, 2.0GHz, 533MHz FSB)
or
Intel® Celeron® Processor 540
(1MB L2 cache, 1.86GHz, 533MHz FS
or
Intel® Celeron® Dual-Core Processor E1400
(512KB shared L2 Cache, 2.0GHz, 800MHz FSB)
or
Intel® Celeron® Dual-Core Processor T1400
Check the features with Acer first and see if your motherboard model support that speed processor.
Contact tech support directly to the manufacturer right here:
http://acer.custhelp.com/cgi-bin/acer.cfg/php/enduser/ask.php?p_sid=8P57rbgj
Oct 13, 2008 | Acer Aspire 5315 Notebook
Upgrade processor problem
http://support.intel.com/support/motherboards/desktop/D875PBZ/sb/CS-021825.htm
This website is the details of your motherboard from intel site you can have look in to that the processor 3.2 ghz is supported but L2 cache must be 512 kb only(you are trying with 1mb one it is not supported) your processor doesnt suits the motherboard specification as i have told it previously ..
here are list & details of supported processors below:
intel® Pentium® 4
3.40 GHz 800 MHz 512 KB P20 or greater All board revisions support these processors. 3.20 GHz 800 MHz 512 KB P06 or greater 3 GHz 800 MHz 512 KB P05 or greater 3.06 GHz 533 MHz 512 KB P02 or greater 2.80C GHz 800 MHz 512 KB P05 or greater 2.80 GHz 533 MHz 512 KB P02 or greater 2.66 GHz 533 MHz 512 KB P02 or greater 2.60C GHz 800 MHz 512 KB P05 or greater 2.53 GHz 533 MHz 512 KB P02 or greater 2.40C GHz 800 MHz 512 KB P05 or greater 2.40B GHz 533 MHz 512 KB P02 or greater 2.26 GHz 533 MHz 512 KB P02 or greater
so just try changing this processor to 512 kb L2 cache processor ..........
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
Jul 05, 2008 | Intel P4 3.0 800 MHZ Retail BOX
Porcesssor change
check your motherboard specifications from the motherboard manufacture website ...
i think your motherboard will not support that processor ..
as you have not given the motherboard i couldnt able to check it ...
if it supports then i think you are wrong some where ....
Jul 04, 2008 | Intel P4 3.0 800 MHZ Retail BOX
Motherboard info
Hi the best bet for you would be mobos from ASUS or SOYO .These are exceptional on multimedia provided you select the correct one as per your budget.Their websites list out the feature and performance statistics.
May 09, 2008 | Intel Motherboard
Processor compatibility
looks like you limited to the p4 Prescott, this is a p4 list of the cpu support from asus. I also looked at their bios update page and found no bios improvement. if you can move to the 775 platform ,you can move from p4. otherwise, the p4's are still  good . I had the cpu that is the 2nd one down. 3.2ghz oc'd to 3.8ghz full time with a max of 4.0ghz on air[775 platform] quad-pumped gave me a 1001.3mhz FSB
Supports Intel Prescott CPU
P4-3.20E GHz (800 FSB, L2 cache:1MB, HT, 90nm)   ALL 1006 gogo.gif
P4-3.40 GHz (800 FSB, L2 cache:1MB, rev.G1)   ALL 1011 gogo.gif
P4-3.40 GHz (800 FSB, L2 cache:512KB, HT, D1)   ALL ALL gogo.gif
P4-3.40E GHz (800 FSB, L2 cache:1MB, HT, 90nm)   2.00 1006 gogo.gif
P4-3E GHz (800 FSB, L2 cache:1MB, HT, 90nm)
SEE 4 YOURSELF
http://valid.x86-secret.com/show_oc.php?id=156822
Oct 30, 2007 | ASUS P4P800 SE (890552603657) Motherboard
Computers & Internet Logo
537 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
