Question about New Home L-372 Mechanical Sewing Machine
Thread bobbin of New Home sewing machine
How do I do it? We lost the video HOW-To.
Yvonne
  • Riverrat359 Jan 26, 2009
    How do I thread the bobbin on the NewHome # L-372? I took the bobbin thingy appart & now I'm really lost!!
  • 12 Answers
SOURCE: Bobbin thread breaks
Things to check for thread breakage (top or bottom)
1. Good thread in the machine - not hand thread, cheap thread, quilting thread.
2. A burr on the hook - a small nick on the hook can grab and tear threads, however this usually causes the top thread to tear, not the bottom
3. Make sure a new needle is in the machine - one made for the material you are sewing
4. The bobbin must be installed to rotate in the correct direction in your bobbin case
5. And I'll say it anyway - tensions - the primary cause of thread breaking - Remember, there are TWO tensions in a sewing machine, top and bottom. Also, the thread you see on the bottom of the stitch is the top thread, and vice-versa.
Posted on Dec 04, 2007
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Posted on Feb 26, 2008
  • 323 Answers
SOURCE: Threading my sewing machine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Posted on Aug 27, 2008
SOURCE: bobbin threading
I need to find a needle threader for a sx 2122. I am find it impossible to find one. I lost the little spring that goes in it. Please help
Posted on Jan 26, 2009
Why won't my new home super stretch stitch model-844 pick up bobbin thread to sew manual book
If you need a manual, search the internet for:
Make + Model + the word "Manual"
or contact the manufacturer.
Try installing a brand new needle. A bent needle sometimes will not connect properly. Be sure that both upper and bobbin threads are threaded correctly.
On the other hand, the needle/hook could be out of time. You can check that by hand turning the handwheel and watching the needle/hook movement. There are a multitude of web sites and videos that discuss timing. Or--check with a sewing machine technician.
Mar 20, 2016 | New Home Sewing Machines
How to thread bobbin model L373 new hope
Google make and model + word "manual"
http://homeappliance.manualsonline.com/manuals/mfg/europro/europro_sewing_machine_product_list.html
Jul 19, 2014 | New Home L-372 Mechanical Sewing Machine
My needle won't grab the bobbin thread but if I put some fabric in and start to sew the bobbin thread comes through. However, the bottom thread is all bunched up and causes the machine to jam.
the looping on the underside sounds like a needle thread tension problem. 1st off check top (needle) threading then turn machine by hand to pick up bobbin thread
Jan 02, 2014 | New Home HF-106
New Home Type F threading bobbin take up
Perhaps one of these will help:
New Home Model 532 Sewing Machine Threading Diagram
New Home Model 2022 Machine Threading Diagram
Thread Bobbin on Newhome Sewing Machine
HINT: install a brand new needle. Remove the top thread from the machine. ALWAYS RAISE the presser foot and then rethread the top thread. The upper tension should start out set at the midway point. Use only fresh, good quality thread--AVOID old or bargain bin threads.
If the machine is threaded correctly top and bottom, but is still not catching the bobbin thread, then it's possible the machine is out of time. Search for sewing machine timing or take it for service.
Since it is an older mechanical machine, it is recommended to clean and oil the machine frequently. Oil Before using it if it has been in storage. If the machine is sticky, motor drags, etc., here's a good reference for getting it back in shape:
Wheel on right side that controls the needle up and down is very tight...
May 26, 2017 | New Home Sewing Machines
Bobbin thread not sewing tight
try adjusting the top thread tension one number or letter higher
sewing on a scrap piece of fabric till the stitch looks normal.
Jan 17, 2013 | New Home 2014LE Mechanical Sewing Machine
My daughter in law's machine won't pick up the bobbin thread. I've never even seen a bobbin that loads like that so I don't know what to tell her. In fact, I've never even heard of a new home sewing...
New Home is Janome.
The bobbin thread may not be picking up because the needle is in backwards.
Refer to the manual for the machine - some require the flat side of the needle face to the back of the machine and some to the left side of the machine.
May 07, 2010 | New Home L-373 Mechanical Sewing Machine
Threading a bobbin on the new home 2014le
place spool of thread in , route it towards your bobbin holder, take thread and put through one hole about 4 inches hanging ontop. press it in and slide it to the right where you hear a click, hit the peddle, should be winding, it will automatically stop on its own when full. click it to the left when done, snip it and then drop that into your bobbin holder , cover your plate, thread your upper thread and presto you are now sewing with your threaded bobbin, always remember these steps. #1 material choice #2 thread weight #3 needle size. you got to match those 3 for beautiful perfect stitches.
Dec 16, 2009 | New Home 2014LE Mechanical Sewing Machine
Bobbin thread not feeding into the upper needle thread
completely unthread the machine....ensure the needle piston shaft is in the correct position and retread the upper. reinstall the bobbin and turn the machine by hand to engage the bobbin thread. Draw the bobbin thread through the stitch plate and with the needle thread, allow to trail off the back. attempt to sew a piece of scap material.
please let me know what happens at this point.
clarkco
Feb 08, 2009 | White Sewing Fashionaire Sewing 2380...
Bobbin threading
Unthread the machine
Open the top of the machine and take the thread and place it through one of the whole in the bobbin (from inside to outside) and pre-wind to secure the thread around the bobbin
Wrap the thread around the far left feeder knob on the top and put the bobbin on the bobbin holder in the top right-hand side
Push the bobbin to the right until it snaps in place (it will click)
On the outside of the machine, un-secure the hand sewing wheel so that it is loose
Power the pedal and watch the bobbin load
When finished, push the bobbin holder back to the left to release it and you're done
Sep 14, 2008 | New Home 2014LE Mechanical Sewing Machine
Threading a sewing machine
Damn machine!
Nov 07, 2007 | Janome Mini Compact
New Home L-372 Mechanical Sewing Machine Logo
1,282 people viewed this question
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
Nava Hirshenson
Nava Hirshenson
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
