Sony STR-DE595 5-Channel Amplifier Logo
Posted on Sep 23, 2010
It says protected - Sony STR-DE595 5-Channel Amplifier
What are the limitations for configuring link aggregation and protection on the ETHA, ETHB, and GIU boards?
The ETHA board supports only intra-board aggregation groups and protect groups, but does not support inter-board aggregation groups or protect groups. In addition, the ETHA board can be used for cascading but not for upstream transmission.
The ETHB and GIU boards support both intra-board aggregation groups and protect groups, and inter-board aggregation groups and protect groups. Inter-board aggregation groups and protect groups can be set up only between the ports on the boards of the same type. For example, a port on the ETHB board and a port on the GIU board cannot form an inter-board aggregation group.
When setting up an aggregation group or protect group, pay attention to the following points:
· A port can be directly added to a protect group. Or, it can be added to an aggregation group and then to a protect group. A port that has been added to a protect group, however, cannot be added to an aggregation group.
· Switching is of low efficiency between the ports that are in a protect group only, but switching is highly efficient between the ports that are both in an aggregation group and in a protect group. In this case, it is recommended that you add ports to an aggregation group and then to a protect group. This shortens service interruption.
2answers
What is the purpose of weightlifting gloves?
The purpose of weightlifting gloves is to protect the hand from developing corn and warts and is also intended to protect the fingers and the knuckles.
3answers
Dvd says cannot record copy protected movie how to fix ?
Depends what you are trying to record? Some TV stations have protection built in so you cannot record. If you are trying to copy a video from VHS to DVD and it's a commercial movie etc then it won't.
You can get a "box" that will get rid of copy protection signals, but only from outside the unit sources. Internal dub to dub protected sources cannot be copied.
2answers
What's your problem?my toshiba dvd player has protection on and can't get it off
The protection circuit is sensing a load problem, a malfunctioning laser assembly or a failure in the audio/video processing circuitry, far cheaper to replace the DVD player.
3helpful
2answers
I dont know how to delete a protected picture off my canon power shot a470 camera. Can you help?
You have to unprotect it first. It's a bit confusing because the menu item probably only says "Protect..." but it also takes care of unprotecting too. Go into the menu for "Protect..." and navigate to the protected one. Whatever button you press to switch the protected status (it's the SET button on my Canon) you can use it to turn the protection off as well. When you exit the protection mode, you can delete it.
13helpful
2answers
Write protected 4 GB GENX USB
I ve a 4 GB genx USB that.It become write protected. How do I remove the write protect so i can reformat it? The device doe't have a write protection switch. What's wrong with it?
2answers
Protective gear safety
ALWAYS wear protective clothing, including: * Leg protection such as chaps, leggings or cut resistant pants. * Hard hat if there's any material overhead. * Gloves or mittens with an enhanced gripping surface. * Eye protection with side shields. * Hearing protection such as earplugs or earmuffs. * Boots or shoes with steel toes and nonskid soles.
1helpful
4answers
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
