Question about Refrigerators
Water leaking into refridgerater
I own A whirlpool gold up and down. The freezer is always full of ice, and water is always pooling into the fridge. Do I need a repairman?
  • dynalady May 21, 2008
    Thank you for the quick response, sry I spelled fridge wrong. I read on some of the troublshooting guides and figured out the prob. The return line from the freezer was frozen. I fixed the problem by removing the inside rear of the freezer and defrosted the line with a blow dryer. Thank you
  • robert samples May 11, 2010
    before i can answer that i need some more info is this a top or bottom mount freezer or a sxs do you have ice and water in the door and th3e model number would be nice
    President:
  • 1,314 Answers
Your welcome
Posted on May 22, 2008
Water leaking from whirlpool gold refrigerator
When refrigerators leak water it usally is a sign that the defrost drain found inside the rear of freezer and behind the rear panel of freezer has become clogged with ice or gunk. Sometimes the pan below refrigerator has a crack and allows water to leak onto floor. Please click here=> Leaking Refrigerators Just What may Be HappeningYou will at times see water build up inside freezer bottom especially on bottom freezer refrigerators. This will take a little reading over to understand what may be happening. Click Here=> Leaking Refrigerators
I will be here should you have questions, Thanks Sea Breeze
Feb 16, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
Fridge and freezer are working just fine. But, I keep getting pools of water inside my fridge. These pools stay to the back of the fridge on all levels and they sometimes turn to ice. I notice ice layer...
Your defrost drain is most likely blocked with ice or sludge. Now when your refrigerator goes into defrost it pours into base of freezer or just anywhere it can to pool up. Click Here=> Leaking Refigerators, just what may be happening Click here also=> Leaking Refrigerator's? Please let me know if you still have questions, Thanks, Sea Breeze
Mar 19, 2011 | Whirlpool Refrigerators
Ice maker is frooze up and has quit making ice water has gathered in the bottom of the fridge
this may be a defrost problem being that water in bottom of freezer is coming from frem defrost and drain is blocked
is the freezer down to -18 deg c ?
the other problem is that the water inlet valve is leaking water into chamber when is not meant to
so if water valve is faulty this can happen so replace valve
Nov 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Hi freezer on american style fridge freezer is
there is a defrost mode that melts any frost or ice on the evaporator coils and drains it into a pan under the fridge. if that drain is blocked, the water will pool inside. also check the door seals. if warm moist air leaks in, it'll condense on the cold interior and pool as well.
Nov 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Water pools at bottom of freezer, freezes and water leaks out
Hello, this sounds like you have a blockage in the drain tube, remove bottom shelf from fridge and remove the styrofoam..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 31, 2009 | Freezers
Water Leaking all over from Whirlpool Gold Refrigerator
I think that the seals are ruined when the seals are ruined the water will leak outside and inside beacause all of the heat from outside will gather together and will melt the ice and will make the moisture act up and boost the process of it turning to gas matter into liquid matter.
Apr 24, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold side by side freezer not freezing but fridge is running
Your fan in the freezer is wearing out. When your food in the freezer is blocking the air, the motor is working too hard. After years of using, it needs to be replaced. Get a repair man in to replace with a new parts. My Fridge/Freezer was totally broken and I found this out because the ice was melting. It got fixed and now no problem.
Oct 10, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
90 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
