Question about HP Photosmart M525 Digital Camera
Memory card problem
I have a 1GB memory card. It works well in my camera but when I put it in my memory care reader it does nothing. I know that I have a lot of pictures on it. What can I do to solve my problem?
    Champion:
  • 203 Answers
Go to my computer in windows and find drive letter for card reader w/card installed-right click properties and see if there is any data on card-try opening drive to see if it will display contents
Posted on May 21, 2008
Cannot download 1GB video file
If your photos and videos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
May 29, 2012 | Canon PowerShot SX100 IS Digital Camera
Nikkon coolpix L1 After downloading memory card .. then putting back into camera. Reading says "cannot read memory card." Checked card out at store verified that it is good. Why does it not work in my...
A couple things you might try.. remove the card carefully and check the position of the "lock" tab. Make sure it is fully in the unlocked position - not locked or a point between the two positions. Reinsert and try again.
It sounds lie you're using a card reader to download the pictures - try formatting the card while in the card reader via computer. The card should be completely empty when the format is complete. You can even try copying files to and from the card to make sure its ok and format again. When complete, try again in camera.
If the problem persists, check to make sure the card is on Nikon approved memory card list for use with the Coolpix L1 (provided below):
The following is a list of approved memory cards for the Coolpix L1 digital still camera. These cards have been tested and approved for use with the Coolpix L1.
The L1 uses SD (Secure Digital) memory. Sandisk:
  • 64MB, 128 MB, 256MB, 512MB, 1 GB, 256MB*, 512MB*, 1GB*
Toshiba:
  • 64MB, 128MB, 256MB, 512MB, 1 GB, 128 MB*, 256MB*, 512MB
Panasonic:
  • 64MB, 128MB, 256MB, 1 GB, 256MB*, 512MB*, 1GB*
* - Cards rated for 10MB/s (high speed) Other cards have not been tested. For more details on the memory cards listed above, please contact the manufacturer.
The list came direct from Nikon Support. Other cards may work, but only those on the list are approved. Successful use of other cards can not be guaranteed.
I hope this helps!
Sep 30, 2010 | Nikon D60 Digital Camera with 18-55mm lens
I wud like 2 format another memory card in my qv-r61 but wen i put the card in i can get nothing onscreen to set it up any ideas? it is a Fuji memory card and when put in the camera all i have got onscreen...
Hi, have you tried using your computer to format the memory card, what you need to do is put your memory card into a memory card reader then wait a minute then open up my computer then locate the memory card then right click on it with the right button on the mouse then choose format and format it to fat32 then try it in your camera and it should then be working.
if you have been using a memory card in the camera and still have it then put this in the memory card reader and go to my computer and then right click on the memory card and select properties and have a look at what format that memory card is, and if its anything other than fat32 write down what it is.
Then put the new memory card into your card reader and goto my computer then right click with the mouse then choose format and then choose to format it to the same type as the other memory card thay you know works in the camera, once you have done this the memory card should work in the camera with no problems.
until you have formatted the memory card to the correct type it wont be recognised by your camera so give it a try what i said and you should find you will have no more problems ok.
let me know if you need further assistance ok
Jul 02, 2010 | Casio QV-R61 Digital Camera
I have a Kodak EasyShare Z712 IS camera in which I used a PNY 1GB card while we were on vacation. At one point, I noticed the "battery low" indicator & tried to shut down the camera. The batteries...
try and get a card reader. remove the card form the camera insert it to the crad reader and plug it into a computer USB port. I the port is Ver 2.0 this will auto read the photos. save all in the computer. I hope this will help.
Ravie
Jun 28, 2010 | Kingston 1GB Secure Digital Memory Card
1GB Memory Stick PRO Duo Memory Card: My sister's boyfriend put my stick into his comput...
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
May 14, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
My Sony Cybershot DSC-W120 Super steady shot Camera won't turn on
I have the same problem, but when I remove the MS Pro Duo card (1GB) from the camera it works fine again. The memory card works fine in a pc memory card reader. Is there a problem with the Sony camera built-in card reader?
Aug 21, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Formatting memory card
it's just gonna loop if you're using a card more than 1GB. This particular model will only work for 1GB or lower SD/MMC card.
Aug 05, 2009 | Kodak EasyShare C330 Digital Camera
Broken m2 card
Try to put the memory card into the card reader of any system. If nothing comes, your memory card has some problem and is better to get it replaced.
Thank You
Oct 25, 2008 | SanDisk 1GB Memory Stick M2 Memory Card
SanDisk 1GB Impact
r u unable to copy d pics........???
tell me den i will give u soln
di tpe of error comes when memory card gets full....n dere is no space for more pics....
if u r able to copy d pics den copy it and format ur card
u can format it wid camera or by using external card reader...
Jun 18, 2008 | Kingston 1GB Secure Digital Memory Card
HP Photosmart M525 Digital Camera Logo
27 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
