Unable to exit menu screen - Televison & Video
  • 3 Answers
Press the menu button, make sure theres no kool-aid under the menu button
Posted on May 21, 2008
How do I remove Blind Commentary from my Westinghouse, flat screen television?
get the on screen menu up , navigate to the section for audio , turn off any blind help or assist , go ok and exit
May 26, 2016 | Westinghouse Televison & Video
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
Will not clean servies
Brother MFC-5440CN Unable to Clean error and may work for some others.
Hi you can try
This works with most Brother printers
Procedure how to reset the error 46 error (unable to clean). This can be done on every Brother inkjet machine with a numeric keypad.
- Machine off
- Switch on the machine while holding down the “menu” button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press “99” to exit the maintenance mode
Now you are able to print again, but actually your ink absorber box is now full with ink. Ink flooding can happen if you don’t replace this ink box
Also can try.
Reset code.
Press menu then*2864 within 2 seconds (maint should be on the display and all the lights should be flashing, if not try again) press 80
then keep pressing black/mono start button until screen displays ‘purge count’
press 2783 to reset purge count
press stop/exit key
press 99
machine should return to normal
May 04, 2010 | Brother DCP 115C All-In-One InkJet Printer
Toolbar/menu/handle disappeared from saved and new documents.
Sounds like you've either gone into Full Screen mode or have turned off your Toolbars and Menu via the Customize command.
Normally pressing ESC will exit the Full Screen Mode. If you can't see the Menu try using the keyboard shortcuts like so. Keep the ALT key held down and press V followed T. Hopefully you should now see the menu and select "Customize..." to turn everything back on again.
Mar 17, 2009 | Microsoft Word 2000 for PC
Unable to hold picture settings?
unable to tell what u r working on....but are you missing a "save" option b4 u exit your menu?
Aug 30, 2008 | Televison & Video
Unable to exit TV's menu
Try to replace the remote sensor board inside the bottom of your tv. If that won't work, you need to replace the Small Signal Board (SSD Assy) of your tv.
Nov 24, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Cannot exit the TV's menu screen
So I just called Philips about this problem. Our TV was doing the same thing, she said it was a problem with the software in the tv and you need to update it.
Go to
enter your product number for the tv
go to product support
then software and drivers and then click on the link and follow the directions.
Your going to have to download it onto an usb and plug it into the tv.
And if that doesnt make any sense I apologize I dont really know what Im talking about Im just repeating what she said.
Lets all hope it works!!!
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
