Question about HP WLAN MultiPort W200 802.11b Wireless Adapter
Blue screen on HP WLAN MultiPort W200
You said "I had to go into the router and change the settings to only pick up the B&G signal." on your last comment, would you tell me what exactly means ?
  • 2 more comments
  • Anonymous Aug 27, 2008
    I have the same problem and it's correct, that the router is the problem. I don't know what exactly happend to the driver version 1.00F, but it DOESN'T WORK !!!
    So ... I will write an email to compaq support to help me fix this problem.
    If they doesn't try to fix it, i would install Windows 2000 again :D
  • trpeterson Oct 04, 2008
    Samething, everything was fine until somebodie at the neighborhood setup two unsecure Wifi, then if I try to activate the Wireless adapter, I get the blue screen, so, yes ...It's the router. How to isolate the others two?...What should I do?
  • shadowtec602 Jan 29, 2009
    Well, I have SP3 and Have the same problem. when ever I try to connect to my router with the wi-fi card I get the blue screen of death
    the error is IRQL_NOT_LESS_OR_EQUAL
  • Anonymous Feb 21, 2009
    blue screen on restart after enabling wlan w200 adapter. Have to disable in safe mode to restart.
Rollback the W200 driver to version 1.00C. Subsequent drivers are incompatible with XP SP2.
Unfortunately, WPA support came in version 1.00E, so W200 + XpSp2 = no WPA support. :(
Posted on Aug 14, 2008
I do not Think it is the router. I believe it is a problem with how the card interacts with the machine. The solution is probably a driver change/ update which HP/ Compaq do not provide. If you look at the BSOD you will notice that the error points to probable driver issues. The device seems to work but how the device uses RAM / memory is the issue. Perhaps disabling the wired connection might work but othrt forums suggest that some Compaq Multipoet W200 might have Agere chips which WILL NOT function proprly with Intel drivers.
I am going to try some of their drivers, more soon,
Posted on Mar 20, 2010
How to enable WLAN again
Basically "disconnect" WiFi and then reconnect but select which one, in your case yours. You might have to enter a password if you have set up such I should be good to go.
For more detailed and specific information I would need to know more such as operating system device types Etc.
Sep 28, 2017 | Compaq Evo N600C PC Notebook
Hpcompaq wlan w200 driver win7
OPERATING SYSTEM SUPPORTED:
Microsoft Windows 2000
Microsoft Windows XP 32-bit Home Edition
Microsoft Windows XP 32-bit Professional
OPERATING SYSTEM NOT SUPPORTED:
Microsoft Windows VISTA -WIN7
Apr 03, 2012 | HP WLAN MultiPort W200 802.11b Wireless...
Hp wireless will not connect
check if the wireless light is amber or blue.. if its amber, turn it to blue.. hope that will work.
for further help, mail me at L2support.hp@gmail.com
May 26, 2010 | HP WLAN MultiPort W200 802.11b Wireless...
Since I did a clean install of my OS can not
jeffrundall
To be able to properly address your BSOD I will need some info from the BSOD. The link below will show you the info that I need.
http://www.fixya.com/support/r4443711-blue_screen_death_bsod_important_info
Thanks
Issken
Dec 26, 2009 | HP WLAN MultiPort W200 802.11b Wireless...
W200 cause a blue screen
First of all: If you install SP2 you don't have to install SP1 over it. It already did. Secondly, don't install SP3, it destroys Windows XP.
Try reinsalling the PC with SP2, install the drivers and do nothing else, see if that helps.
If not, by all means post back here,
Yannick.
Jun 16, 2009 | HP WLAN MultiPort W200 802.11b Wireless...
Compaq wlan w200 bsod with wrt54gs router
Check your router config for wireless "N". if it's there, disable it. You can also use the driver on the compaq to go back to the install of driver 1.0c
Dec 20, 2008 | HP WLAN MultiPort W200 802.11b Wireless...
Multiport w200 wireless goes to blue_screen with belkin G+ router
http://www.fixya.com/support/t612983-blue_screen_hp_wlan_multiport_w200 seems to have the solution.
It says:
I removed my wirelss drivers and compaq wireless client software, then installed the older driver from http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=hb-13082-1&lc=en&cc=fr&dlc=en&os=228&product=235687&lang=en which is sp23031. This seems to have worked. s.gif
Oct 07, 2008 | Compaq Evo N610C Notebook
Wlan W200 connection problem
There is a solution to this, and you won't have to buy a new card. The folks at HP, however smart in their design of this laptop, have not properly updated the bug fix for the wlan w200 drivers. What you'll need to do is actually take back your network adapter driver all the way back to Version 1.0 revision C. I did this with an n610c that I got for free because it was BSOD'ing every time the wireless was turned on. For the most part the wireless can handle older routers and wlan areas, but will BSOD when within range of a wireless "N" adapter. Simply download the driver version 1.0c and you should have no more issues.
Tip: You can disable the card manually by pressing your "Fn + F2" keys, rather than trying to navigate your menus before getting the BSOD.
Nov 07, 2007 | HP WLAN MultiPort W200 802.11b Wireless...
WLAN Multiport W200 not connecting to wireless network
Anyone who has this problem: the problem is with the W200 driver that HPclaims you should use. Download this driver instead and your problems should be fixed:
Oct 20, 2007 | HP WLAN MultiPort W200 802.11b Wireless...
HP WLAN MultiPort W200 802.11b Wireless Adapter Logo
2,241 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
