Question about Gateway MT3705 Notebook
Gateway Laptop power supply connection
I have a Gateway MX that will not charge. The power supply connection in the back is very loose and the charging light will come on if you put pressure on the connection. Local PC fixit shop says it is common problem, wants $200 to repair...is there an alternative?
    Scholar:
  • 143 Answers
Yes, there is an alternative... go to another shop. I think $200 is too much to be fixing that problem. I have a friend who charges half of that, so I know you can find it cheaper. Other than that, no alternative. Its solder joints are bad and it needs to be resoldered.
Posted on May 21, 2008
Gateway kav60 not charging. i have to wiggle the cord and sometimes it refuses to charge.
I guess you've got a broken laptop power dc jack or power cable.
Symptoms of a broken Laptop DC power jack:
- The laptop only operates when you hold the DC power plug in a certain direction (DC jack is broken or loose).
- The laptop only runs on battery power (no power is getting through the DC jack).
- The laptop gets no power at all.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently due to a loose or broken power jack.
- The laptop suddenly shuts off.
- The DC jack may feel loose.
- Sparks come out of the back of the laptop when you insert the power plug into the DC jack.
Apr 21, 2011 | Lifetime Gateway KAV60 Replacement Laptop...
Gateway laptop battery ran down and now wont' start up with it plugged in
Take out the battery and put it back in. Plug in the charger and start your computer. This should fix it. It happens when the battery runs down too much.
Jan 09, 2010 | Gateway Computers & Internet
Laptop not charging even when plugged in- battery or power supply
Sounds like you have a bad power jack. Broken solder connection on circuit board. Is it loose when you plug it in the back of the laptop?
If so that is what it is, seek professional repair as it is not a repair for the novice!
Jul 05, 2009 | Gateway Computers & Internet
The dc connecter is loose
Where you plug your power adapter cable into the laptop is a small soldered block connector inside. Over time, if not careful, this can become loose and disconnected from the motherboard, causing a loose connection. Now, your power supply connection to the laptop is not working anymore, and thus, you have no charge or power to your laptop. It gets worse, unfortunately. You need to find an experienced person that knows how to solder contacts on circuit boards to repair it, or bring it to a place that does component repairs on computers. The charge will be from $150-$175 usually for this service, but will fix your problem I am confident.
Mar 29, 2009 | Gateway MX6027 Notebook
Laptop wont connect to power supply
Sorry to say it, but the charging port in your laptop may be loose. The "loose" feeling that is often described is because one solder joint comes loose, so by moving it around it will reconnect. Unfortunately, doing this also causes the other joints to come loose, and they will eventually break off too. If (and ONLY if) you have experience soldering with electronics, you can open the case of the laptop, and attempt to resolder the port back onto the motherboard. Even if this does work, however, the solder that is generally available to consumers is a lot weaker than commercial grade solder, so the joint will be weaker than it was before.
The better solution would be to find somebody with experience with this, preferably a friend that won't charge you, or take it into a shop to get fixed. Make sure you get a price estimate, though, as this can be a fairly time consuming process.
Dec 23, 2008 | Computers & Internet
Not charging
I found out how to solve this problem...first power down your computer. Then take out the battery, remove the power supply, and then hold down the power button for 30 secs. Put the power supply in only (not the battery). Start your computer after everything is done loading up put the battery back in. Give it a min. and then you should be able to roll your cursor over the battery life indicator in the lower right corner of you computer and is should say charging. I have found that other people have had this problem and it has worked for myself and for them.
Aug 26, 2008 | Computers & Internet
Jack is loose where charger plugs in
This same thing is happening with my acer laptop. I sent it to the company about 3 months ago, and it happened again. I really need my laptop and cant take a month without it. I advise sending it in to be fixed to your laptop company.
Good luck (:
Jun 29, 2008 | Gateway (1532852) Power Supply
Gateway 450 ROG will run only on battery.
If it's still under warranty, it's definitely worth repairing. If not, get them to quote for the repair they say it needs before agreeing to it. If their quote is anything close to the current price, I would say it's not worth it.
May 09, 2008 | Gateway 450ROG Notebook
Won't Charge Any Battery--Even a New One
Check for loose solder connection in the power supply and the terminals that connects the battery to computer.
Sep 03, 2007 | Gateway 450ROG Notebook
Gateway MT3705 Notebook Logo
225 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
