Candy AQW130 Front Load All-in-One Washer / Dryer
Problem for Candy AQW130 Front Load All-in-One Washer / Dryer
Candy Aquaviva 1300 washing machine
By Donniegate on May 21, 2008
Candy Aquaviva 1300: As the drum speeds up there are intermittent noises as though some thing is catching quite badly. I had to switch it off it was so bad. I'm wondering if some thing has got inbetween the drum and it's outer casing? Iv'e got the back off and removed the bottom hose to see if I can feel anything. Nothing. With the belt removed the drum revolves smoothly with no roughness felt in the bearings. However, when I lift the drum by its lip at the door there is a small amount of play. Could this be enough to make the inner drum foul the outer case? How big a job is it to remove the drum to remove anything that has perhaps got inside or to fit new bearings if required? Are any special tools required? I'm retired now but was a car mechanic for many years. I've searched the Web looking for a repair manual for this machine, but haven't nad any luck. Hoping you can help.
Same Problem
Jan 28, 2009
-   When my machine spins it makes alot of noise,to much noise and my belt has now broke.-   Guest
Solution #1
posted on Jun 08, 2009
Not Rated)
bernie_stoke
Rank: Apprentice
Rating: 0%, 0 votes
fabrick condictioner drawer stays full can you help me bernie
Was this helpful?
Yes
No
Popular Solutions for Candy AQW130 Front Load
Questions and Unsolved Problems for Candy AQW130 Front Load
Do you recommend Candy AQW130 Front Load All-in-One Washer / Dryer?
Answer
Answer
why wont the machine carry on its cycle after it fills with water . it wil carry out all other... (More)
Answer
Candy Aquaviva 1300: which ever program is selected the machine seems to do part of the wash then... (More)
Answer
Where do i get the tool to replace drum bearings for candy washing machine
Answer
hi, our candy aqua 1000T trips its fuse somewhat arbitrarilly. sometimes it works fine for wash... (More)
Answer
The machine washes OK, drains OK, and the drum seems to turn (slowly) during the cycle. However, it... (More)
Describe your Washing Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
