Question about Toshiba TDP-S9 DLP PROJECTOR *2% DISCOUNT COD/WIRE Multimedia Projector
Toshiba projector switching itself off
We have a Toshiba TDP S9 projector, it runs for a few minutes and then the lamp light goes amber and then red, it then switches itself off. We have checked that the flilters are free from dust. Please help
  • 563 Answers
Hi 123d
Have you tried resetting the lamp timer ?
If you have and it didn't solve the problem , take out the lamp and check for any discolouration or markings on the lamp.
If you do find anything out of order then the lamp would need replacement.
Posted on May 21, 2008
There are for each fan - PWM (puls wide modulation) indicators . Mostly the colour is a yellow wires, the other colours are red and black . I have somewhat the same problem that turns the projector down and want to find out if our what fan runs slower then normal . If i found out then i would try to disconnect this puls modulator cable from the input (fan) and try to parallel the yellow cabel with a good working fan , hopefully it works as a surrogate input puls .
Posted on Mar 31, 2010
We have the same problem at times with about 50 of these units and have sent most of them back to Toshiba for repair. It was found that the fans either stop or go slow if the projector is mounted upside down, but are OK if mounted on their feet and as you know, in a classroom most mount upside down from the ceiling.
Posted on Nov 25, 2008
Projector tdp s9 lamp indicator turns yellow light, even when new bulb is replaced correctly
Once you replace the lamp you need to go into settings and reset the bulb hours back to zero. That will take care of your problem
Feb 14, 2015 | Toshiba TDP-S9 Multimedia Projector
Flashing light and then shuts down, the lamp and temperature bulb lights red on and off
1,the color starts to go out, it become the white and black ,
2,then,the projector running off after only a few minutes,
it is a general issue:the inductor need to be cleaned
Use a cotton swab moistened with alcohol to clean the inductor.
the inductor (Sensing element),is near to the Color Wheel.
the industor : is a black little element,as little as a sesame seed
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Feb 07, 2014 | Toshiba TDP-SP1 DLP Projector
JUST PUT NEW BULB IN A TOSHIBA TDP-S20 ON 2/18/11 . BOUGHT PROJECTOR IN 2004 USED UNTIL THE BULB HRS RAN OUT . BULB NEVER BROKE / BURST. ON START UP WITH THE NEW BULB IN MACHINE BOTH FAN AND LAMP LIGHTS...
Your new bulb is not lighting.
Check the connections are correct.
Have you also tried putting back old bulb to see if it works.
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Toshiba TDP-S20U Multimedia Projector
I just replaced my bulb on the toshiba tdp t45u projector and the red lamp light is still on and the projector still wont come on? how do i fix?
Check out the Power supply to the lamp . It must not be high . . Check if the voltages are correct to the lamp's unit and it's PCB [printed circuit board]. I recommend using a service manual .
Here is how to replace a projector's bulb correctly :
1:Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
2:In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
3:Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
Please note that in some projectors a small inside filter should also be replaced.
4:Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
5:Reassemble the access panel, replug the cables and power up the projector.
Things You'll Need:
new projector lamp
screwdriver
micro fiber duster
Warning:
avoid touching the bare projector lamp
I hope this will help .
Apr 11, 2010 | Toshiba TDP-PX10U DLP Projector
How to change toshiba TDP-S35 lens
i got a problem with my projector, the colored break up into pieces, i want to know if how much is the price to repair it.
Mar 19, 2009 | Toshiba TDP-S35 DLP Projector
My TLP680U projector shuts off after 1o minutes of operation.
toshiba is not one of the most rliable makes im afraidi have seen this fault before and it turned out to be the bulb which i had recentley replaced and this was apparentley the wrong one and gave the same sort of results.
Feb 25, 2009 | Toshiba TLP 680 Multimedia Projector
Toshiba TDP SC25 projector
The manual says it might be because the power went out when it was on. Just a note here, as projectors age they become more sensitive to power outages. When not in use turn off completely if you can. They have an on/off button.
Otherwise not sure but think you may need to replace the fan. Try cleaning it first but gently.
Jan 31, 2009 | Toshiba TDP-SC25U Multimedia Projector
Toshiba TDP S8 projector shuts down suddenly
The reason why the projector is shutting off is so the lamp doesn't explode. It's more of a safety feature on the projector, you can reset the lamp and it might work for another 500hours. If the picture is still pretty bright I can get you the reset procedure, but be warn that when the lamp does eventually blow it could shatter the glass inside, so be careful, it shouldn't hurt the unit.
Dec 09, 2007 | Toshiba TDP-S8 Multimedia Projector
Toshiba TDP-S20 lamp problem
The lamp ballast which ignites the lamp has failed it sounds like. The red flashing lamp is the tell tale sign with a good lamp installed. Make sure the lamp door is closed too, there is a door switch that can also trigger the red lamp and no startup. There is a company in San Diego CA that can repair the unit called PROJECTOR DOCTOR
Nov 29, 2007 | Toshiba TDP-S20U Multimedia Projector
436 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
