Question about Whirlpool Duet GHW9150P Front Load Washer
Error code f and dl won't drain or spin
I have a Whirlpool Duet front load washer. Recently when it is time to drain and spin it shows an error of F and then DL . It will not drain or spin
I have 6 kids and tons of laundry PLEASE HELP!!
  • 5,911 Answers
"Fdl" is a Door Lock error. This is usually an indication of a failed door latch mechanism. To access and/or replace the door latch, click on the following link:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
A replacement latch can be located at searspartsdirect.com. Just type in your model number in the "Search" window. You can locate it under the "Door and Latch Parts" heading as item number 7 (part #8181700). This is an easy repair job if you wish to accomplish on your own and avoid the added cost of labor.
If you do not wish to order the part online, use the part number provided and go to your nearest applaince parts retailer. I hope this helps you. Please post back if you need further assistance.
Posted on May 22, 2008
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
I have a duet front load whirlpool washer, I bought it about maybe 8-10 years ago. I'm start to get a error code when I wash on a 28 min cycle spin. The error is 5BR or 56R, it will stop spinning in the...
Hi these are not common codes for a duet. Click HERE for a list of common codes and corrective actions needed.
If you have any further questions please feel free to ask.
Nov 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front load duet whirlpool makes loud roar when it spins - no error code. Machine is only about 1 year old and just started making this noise recently
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Oct 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F11 and/or dl code on a whirlpool duet front load washer
F11 is:
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Check for:
Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
Check the Drive system for any worn or failed components
Check MCU
Check CCU
Check Motor
Check Wire Harness
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
Check the above link for a detailed article about the f11 error code.
Courtesy:JSrock
Apr 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer will rotate to balance
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
To solve this:
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
thanks.
Aug 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet will not drain, F21 error code
YOUR "DRAIN MOTOR PUMP" is clogged with all that rubber particules, if your handy with tools , you can fix this one , open the washer , locate the MOTOR PUMP , (just follow where the drain hose is connected), remove , inspect and clean all the debris and lints and stuff collected , replaced and youre good to go , AJ
May 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
178 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
