Question about Frigidaire FGF337 Dual Fuel (Electric and Gas) Kitchen Range
My frigidaire gas range oven won't work
The rangetop has gas and the burners work, but the oven just stopped working when I went to turn the temp up. It now flashes the (wrong) time rapidly and when I try pushing any of the buttons, it beeps and does nothing. I baked with no problems earlier in the day.
The other day it was on and I hit the up arrow to turn up temp and it showed an F1 error. I hit clear/off and started it again. Worked fine after.
It is only 4 years old.
  • Anonymous Apr 14, 2009
    I have the same problem and we just had a repairman tell us that we have to replace the entire control board ($400 for the part). He initially thought it was just the oven temprature probe. We've only had the range for 3.5 years. Frigidaire wasn't willing to work with the repairman to cover the repair.
  • 750 Answers
Hello Welcome,
If you get a F1 this means Circuit board is defective.
And you need to Check or replace: the control board.
This is a job for service to be sure before you buy the control board!
Thank You Huuum.
Please remember to leave a solved rating before you sign off!
Posted on Dec 20, 2008
Ingniters on rangetop keep sparking for no reason. wWhen it is turned off.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Apr 18, 2011 | Frigidaire Ovens
Oven won't turn on
Most likely you ignitor went bad. Very common problem and it's normal corrosion wear and tear type of deal.
oven repair in orange county, ca
appliance repair orange county, ca
Feb 08, 2010 | Frigidaire FGF337BC Gas Kitchen Range
Kenmore Range/oven Burners won't lite
Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
May 19, 2009 | Kenmore 75844 / 75849 Gas Kitchen Range
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven does not maintain temp.
It sounds like a thermocouple problem. While using the broiler, you gave the gas set to full and the thermostat is basically out of the loop.
Feb 20, 2009 | Frigidaire FGF316 Gas Kitchen Range
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
My oven won't work
most likely cause of no operation is a faulty gas ignitor, simple enough to chsnge 2 wires and a few screws mounting unit to the side of burner bar under the oven floor
May 13, 2008 | Magic Chef CER3740 Electric Kitchen Range
Viking range top 2 burners won't light
Either the igniters are at fault (which is usually the case when one or two are not working) or the entire oven ignition system needs to be replaced and can be done through Viking themselves whether you want them to replace it or you yourself replace it, you can get the part through them.
Benjamin
Nov 21, 2007 | Viking VGSC366-6B Gas Kitchen Range
Frigidaire FGF337 Dual Fuel (Electric and Gas) Kitchen Range Logo
408 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
