Question about Brother MFC 8500 All-In-One Laser Printer
Clicking noise Our machine is making a loud clicking noise and won't feed paper. We tried changing the ink cartridge but it did the same thing. The only way to get it to stop is to open the front cover or just turn the machine off. Thank you.
    Genius:
  • 1,605 Answers
The clicking noise is the gear fro the paper feeding roller. seems that the gear is broken, need to have it replaced.
Posted on Jan 13, 2009
myob247
  • 1342 Answers
SOURCE: makes noise
Click HERE for HP troubleshooting for your printer.
Posted on Jun 07, 2008
  • 12 Answers
SOURCE: Paper will not feed from tray and makes a loud
The paper is not feeding from the paper tray. The loud click is alarming, but not the problem. Check the adjustments in the paper tray. The left and right guides should be snug, but the rear guide should give between a 1/16 inch and a 1/8 inch of free play.
If the rear guide is tight, or even snug, that is the problem. You can check for this by depressing the lever on the right front of the tray. Depressing the lever should raise the stack of paper out of the tray so that it can slide forward.
If you remove the paper from the tray, you will see calibration marks for the paper size you are using. Unlock the rear paper guide, squeeze the release, and move the guide ot the mark for the size paper you are using. For example, it you are using letter size paper, the read guide should point to "LTR".
Posted on Feb 28, 2011
EPIJAB
  • 89 Answers
SOURCE: Will not feed paper
Sounds like the gears are out of alignment for the paper pick up tray.
Posted on May 29, 2008
SOURCE: Clicking noise
Sounds like a clutch has spun out to me...It's going to require tech.
Posted on Mar 13, 2009
efs_perpends
  • 1996 Answers
SOURCE: Won't print. makes loud clicking noise from right side front of unit (ink cartridge parking area)
Please have a look at the noise troubleshooter available for your printer at the HP online support site. Click here
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Apr 29, 2009
Loud clicking noise when attempting to print
Try removing the ink catridges and checking them for any damage like leaking ink. Then replace them and try to print. Also, make sure there is nothing stuck in the paper feeding tray.
Mar 05, 2011 | Canon PIXMA MP620 All-In-One InkJet...
Loud clicking/clacking when paper feeds
Your rollers may be worn and when they are trying to pick up the paper they are not able to . Buy taking your printer to an authorized technician for a maintenance cleaning this should resolve your issue.
Jun 08, 2010 | HP D1660 InkJet Printer
Paper feed problem
The clicking noise is an indication that something's not right in the printer. But try taking out the cartridges from the printer. Then, close the cover. Remove all sheets of paper. Unplug the power supply from the printer. The power supply is the black box behind the printer where the power cord is attached. Wait at least 10-15 seconds before plugging it back in. Once printer's ready, reload the cartridges. Load some paper and try to print again. If this doesn't help and you're still getting that continuous clicking noise, it's a hardware issue. If that's the case, I strongly suggest you contact Lexmark Technical Support for further assistance. I hope I can assist you more on this.
May 28, 2010 | Lexmark X83 All-In-One InkJet Printer
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
Clicking noise
Mar 13, 2009 | Brother MFC-8460N All-In-One Printer
Will not feed paper
May 28, 2008 | Brother HL-2070N Laser Printer
Loud clicking sound
We had the same problem, with a slightly different solution... it turned out in our case that the new toner cartridge's internal drum was too stiff, so the printer was trying to turn the toner spindle and failing, resulting in the clicking noise. Our solution was to manually turn the black center gear by hand a few times, and in doing so loosen the drum up a little, so that the printer could turn it. We put it back into the printer, and voila! No more clicking noise.
Thanks to whitehorse1 for his (or her) solution... though it wasn't the exact same problem for us, it was what put us on the right track. :)
May 12, 2008 | Samsung CLP 300 Laser Printer
Lexmark x7550 Printer, Scanner, Fax - Clicking Noise Question
top feeder for the scanner (on my x6570) had a loose piece of rubber stuck between the feed wheels. The rubber is part of the guiding mechanism that guides the paper to the feed wheels. Remove rubber strip and reattach it where it belongs.
Feb 19, 2008 | Office Equipment & Supplies
Loud clicking noise
Power the machine on with drum and toner removed, check for noise....
It will be either the Fuser, Toner or the drum.
If it is non gen. or refill toner, fault found.
The drum is a normal consumable that you change every 3 to 4 toner cartridges, so if any of you have used more than 4 toners and havent changed the drum, I'd say that we have found your problem.
......now to the hangers on .....
Fuser, thats the hot bit at the back, these have a gear that cracks because the whole fuser assemble is old, brittle and stiff, you can pull it all apart and change the gear and be off, but soon it will more than likely break again, I know cause if I do that as the fix they come back within 6mnts.
Replace fuser, or have it replaced
f9d929d.jpg LINK to P/n and price
the gear that breaks/cracks
9b32a46.jpg LINK to gear info
Fuser is a HiVolt, HiTemp part. Caution!!!!
Nov 16, 2007 | Brother HL 1440 Laser Printer
Outgoing fax makes loud clicking noise
2 different problems here. 1st is with document feed and 2 is with paper feed.
1st prob seems to be with the paper feed roller not meshing at the gear. Probably a broken piece on the lower document tray assembly. No real fix for this unless you can strip it out and haywire it.
2nd prob is probably a poorly meshing drum unit. Examine the gear teeth on both the drum and the machine. As you have replaced the drum already (presumably with a brand new one) You might possibly find a missing or badly worn tooth on the messhing gear in the machine.
Oct 02, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother MFC 8500 All-In-One Laser Printer Logo
1,499 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
