Question about Lexmark Wheelwriter 1000 Typewriter
Wheelwriter 1000 We have a Wheelwriter 1000 in our school library that I type all our labels and shelf list cards on. Recently, it has begun not typing, the ribbon doesn't want to advance. For awhile, I was able to advance it manually with the little wheel on the ribbon, but now it won't move at all. The gear has a lot of black dust around it, and I've noticed black speckles on the paper. Thanks.
  • Ellen Weaver May 23, 2008
    So far, so good. It seems to have worked for now. It probably should be serviced for the first time in memory. Thank you very much.
  • Anonymous Mar 12, 2014
    how to put ribbon in Lexmar Wheelwriter 1000
  • Lexmark Master
  • 3,594 Answers
First try a new ribbon. If this dosen't work check to see if the plug to the ribbon feed motor is unplugged and puy some light lube on the upper & lower ribbon motor bearings. WD 40 works well.
DickyO
Posted on May 22, 2008
Wheelwriter 1000 tape does not lower
There should be a little gear beneath the carriage you can turn, which will lower it:
http://cincinnatiprinterrepair.com/ibm-typewriter-ribbon-too-high
Jan 14, 2014 | Lexmark Wheelwriter 1000 Typewriter
IBM Wheelwriter 3 won't type
Print hammer selenoid cap is broken, or print hammer selenoid is gummed up.
Jan 03, 2014 | Lexmark Wheelwriter 3 Typewriter
How do I install Ko Rec Type corrector ribbon on a Wheelwriter 1000?
The correction cassette snaps on to the bottom of the ribbon cartridge and they both go in together. You can go to (best to copy and paste this)
http://support.lexmark.com/index?page=content&id=SO4998&actp=search&viewlocale=en_US&userlocale=EN_US&segment=SUPPORT&productCode=&searchid=1258479940253
DickyO
Dec 11, 2010 | Lexmark Wheelwriter 1000 Typewriter
IBM Wheelwriter 1500 When I'm typing, only the
The platen has probably worked itself loose. Press down firmly on both ends of the roll it should snap into place.
DickyO
Oct 27, 2010 | Lexmark Wheelwriter 1500 Typewriter
I HAVE BEEPING ON MY WHEELWRITER 1000 ON LINE SPACING 1 & 2
The keyboard is probably bad and the typewriter can't see it.
Contact George Beters CO. 1-800-392-8085.
DickyO
Mar 26, 2009 | Lexmark Wheelwriter 1000 Typewriter
Wheelwriter 1000
Try snapping the plate down, by lightly pushing down on each end the have a habit of working loose.
Jul 23, 2008 | Lexmark Wheelwriter 1000 Typewriter
Wheelwriter 3500 only printing top half of letters
Sounds like the platen is not fully seated in the side frames, align the black latches with the frames and press firmly on both sides of the platen. the latches do occasionally crack in witch case you may need a platen replacement.
DickyO
Mar 20, 2008 | IBM Wheelwriter 30 Typewriter
Wheelwriter 30 Series 2
First off make sure the ribbon turns freely.Take off the ribbon and turn the ribbon wheel in the direction of the arrow and see if it turns smoothly. If it turns smoothly the ribbon motor is not moving or the gear is not moving. take off the ribbon and type. See if the black ribbon drive gear on the ribbon deck moves as you type. If not the motor is N.G. or the ribbon gear clutch spring is not grabbing the gear to turn it. Lawrence
Feb 14, 2008 | IBM Wheelwriter 30 Typewriter
Ribbon Lift Eractic
Try the unit without the ribbon installed if the mech. seems to operate properly you may only need a new ribbon.  If the condition continues you may need a new ribbon motor or board.
Oct 22, 2007 | Lexmark Wheelwriter 1000 Typewriter
Lexmark Wheelwriter 1000 Typewriter Logo
306 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
