Question about Hitachi Televison & Video
Image out of focus
When I do the manual focus I can't get the red lines to line up with the white
    Master:
    Sergeant:
  • 461 Answers
Try to reset the as below,
turn it off, remove all power supply including unplug the power cord from the main supply. Leave it for 20 minutes and turn it on again..
Posted on May 26, 2008
    Sergeant:
    Champion:
  • 304 Answers
first we would like to know the model #of your device.
`jack
  • 3,037 Answers
You should first try cleaning the lens within the tv as they are probably a little dusty and may be causing this problem. Please let me know if this makes it better and if not we can try a few other things. You will need to take off the outer covering to get to them and if you have any questions about doing this, I would be glad to answer them
good luck
Posted on May 21, 2008
  • 2,322 Answers
You have a failure with the convergence circuitry if the magic focus does not work.
The cost of this repair might be $350.00 to $400.00 if you have a TV tech to repair it.
Please provide the model and chassis number of your TV to provide you with more info.
    Brigadier General:
  • 3,614 Answers
May i know the model part # of the TV..?
Thank you
1/3 Hp 115 volt 24 year old motor 40 amps. single Phase. is this for 110 volt Plug in to wall.It also 3 wires , Orange,Red, White, were do i hook these up to on a 110 Plug. Can you Please help.
You looked at nameplate on motor to get the rating information?
Rating plate may also have small wiring diagram.
I was looking at AO Smith single-phase 2-speed pool pump motors yesterday.
The rating plates show wiring.
Open following link:
http://waterheatertimer.org/images/AO-smith-rating-label-500.jpg
Notice the image shows the words: Brown White Line Line.
Brown and white are wire colors. Line means 'power' from breaker box.
240V will have two Line wires, L1 and L2. 115Volt will have Line or L1 and N or Neutral.
Look at your rating plate and then add a comment with clear description of what appears on rating plate, or include in-focus photo. Put your camera in macro to take close-ups.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Your wall outlet has 2 plug-in slots. One is wider that the other.
'Line' will refer to Hot wire from breaker which corresponds to smaller slot on outlet.
'N' or 'Neutral' is neutral wire from breaker box which corresponds to wider slot on outlet.
Apr 30, 2011 | Electrical Supplies
The red projection tube won't focus
Set needs convergence ic's changed and possibly a few small 1/4 watt resistors. Parts have to be desoldered/soldered into circuit board and test equip.(ohm/ volt meter) is required. Most repair shops do this repair for 175.00-375.00 Hope this was helpful. Russmann
May 21, 2008 | Hitachi Televison & Video
Thin red horizontal lines across screen
replace the focus block or try to adjust the screen control on the focus block for red only. this will affect the white balance of the set so adjust it carefully. the focus block is located on the front inside the set. remove the speaker cover then the 4 screws on the front plate. the focus block is 3" x 2" black box with 6 adjustment posts three for focus and three for screen. adjust only the affected screen (R).
Mar 13, 2008 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Hitachi 57SWX20B 3D Effect due to green light convergence problem
I'm trying to fix the issue on my 43FDX20B. So far, I'm able to move the lines up and down, but can't get the left/right motion to fix it. The attached link has the dynamic mode instructions, so you can correct this issue yourself.
http://home.comcast.net/~leebailey00/Hitachi_DCAM_Manual.pdf
The only thing I didn't have was the screen overlay jig the manual talks about. I decided to create one myself and use the screen as a beginning template. I went to our local hardware store and picked up some home window weather covering. The roll cost about $15, is a clear strong plastic and the template was very easy to create. I used a straight edge after I put dots on the plastic and measured the lines for being square and equal after I took it off my tv. Good thing is that if you don't like what you make the first time, you have a 25' roll to use to try again (ha).
Mar 01, 2008 | Hitachi 57SWX20B 57" Rear Projection...
Blue out of focus; casting blue "glow"
Try changing the coolant in the blue tube. Contaminated coolant will give a halo look to the affected tube and you will experience difficulty focusing that color.Phillips/magnavox's blue is the tube most often affected with the contaminated coolant issues.
Mar 01, 2008 | Televison & Video
Convergence Problem
sounds like 1 of the convergence chips are gone theres 2 of them and better off replacing both as the other would just go a month down the line there might also be a resister or 2 gone, the price for that kind of job is around 150 +vat.
hope this helps
Feb 10, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Convergence Problem
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Dec 02, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Out of Focus
· Samsung parts for convergance problem
· http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Nov 24, 2007 | Samsung HCN4226W 42" Rear Projection...
Be very carefull replacing the fluid as leaks will short stuff out and are messy.
Jun 12, 2007 | Philips Magnavox 51MP392H Rear Projection...
Convergence not lining up
Sounds like the green is out of focus. If the focus control for the green does not control it enough to make the width the same as the red, then, the lens on top of the green can be adjusted to focus that tube. On the lens, there is a wing nut on a screw to loosen it and move the lens left or right a bit to help with the focus. Hope this helps.
Apr 15, 2007 | Mitsubishi WS-65315 65" Rear Projection...
Televison & Video Logo
27 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
