Question about Compaq FP 7317 17" LCD Monitor
Flickering screen I see the fix for the flickering, but my monitor refresh rate only has one rate, 60.My screen does not do it all the time, mostly when it is just showing the desktop. Usually when I open programs the flickering will stop, but not always. Any other ideas? My FP 17 monitor green light blinks about every second. Right after it blinks, the screen blinks on and quickly off again. There is some sort of error message, but never on long enough for me to read it. So far, unplugged computer for 20 minutes to try to reset the system. Didn't work. Yesterday this worked, and everything was fine. Today, the monitor doing same thing, and seems stuck in this mode. Also tried hitting the escape button, and clicking around with the mouse.
  • Compaq Master
  • 19,396 Answers
Check cable first
Posted on May 21, 2008
  • Ginko
    Ginko May 21, 2008
    Check first the power cable, a defective cable can cause picture stability problems.
    Check also computer video output rate and size, 60 Mhz and 1024x768 should be ok for most lcds.
    Here is the user manual
    If the above does not fix it, then test the screen on a different computer, if you keep having flickering screen on different computer, then screen is defective, probably faulty capacitor.
    If it is fine on other computer, then problem is with video adapter, probably faulty, as does not keep refresh rate stably.
Ddell studio mpp33l screen flickers on and off, how do I fix it?
Try to lower the refresh rate
Go to
Control Panel\All Control Panel Items\Display\Screen Resolution
Click on Advanced settings, Monitor, see if you have options to bring this further down
Dec 11, 2011 | Dell Studio 15 Laptop Computer (Intel CORE...
How to adjust or change a monitor's refresh rate.
If you've ever used a CRT monitor, you know that fine-tuning your refresh rate is essential. The refresh rate of a display is measured in Hertz (abbreviated Hz) and specifies the number of times per second that a display is illuminated.<br /> <br /> Setting the refresh rate to 60 Hz - a common default value - tells the monitor to redraw itself 60 times per second. For most people, that setting on a CRT monitor is too slow, resulting in an annoying flicker that can cause headaches, eyestrain, and fatigue. Bumping the refresh rate to a higher number can reduce that flicker, as long as the monitor itself can handle the faster rate.<br /> <br /> If you're using an LCD monitor then a safe refresh rate lies in the 60Hz-75Hz range. A greater refresh rate when it comes to LCD's means greater performance.<br /><br /> <b><u>How to adjust the refresh rate</u></b><br /> Firstly you will need to right click on your desktop background and select <b>Properties</b>.<br /> <img src="slasher_x_72.JPG" /> <br /> This will display the <b>Display Properties</b> window as show below.<br /> <img src="slasher_x_73.jpg" /> <br /> You will need to click the <b>Settings</b> tab.<br /> <img src="slasher_x_74.JPG" /> <br /> Once in the <b>Settings</b> tab you will need to click on the <b>Advanced</b> button.<br /> <img src="slasher_x_75.JPG" /> <br /> Then click on the <b>Monitor</b> tab.<br /> <img src="slasher_x_76.JPG" /> <br /> Here you can change the screen's refresh rate. Make sure the box next to <b>Hide modes that this monitor cannot display</b> is ticked. After you have selected the refresh rate you wish click <b>OK</b>. It would be a very good idea if you have the user's manual for the monitor handy just so that you can see what the manufacturer suggests the refresh rate should be set to.
on May 31, 2011 | Computers & Internet
My monitor compaq model MV520 is always blinking every time I open my computer, How can I fix it?.
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to answer and solve your problem. Your Compaq MV520 Monitor is always blinking every time you turn on your computer and you want to know how you can fix it? First, we need to troubleshoot the problem. I'm thinking you probably need to refresh the flicker rate on your monitor. The flicker rate is probably set on a low setting, which is causing you screen to blink (flicker). This can be bad for your health as well because it can cause eyestrain and headaches. Your monitor is a CRT (Cathode-Ray Tube) model. These types of monitors can cause a lot of screen flickering. Now that we've troubleshooted the problem, now it's time to solve the problem. There are two ways you can solve this problem. You can either refresh the flicker rate or you can buy an LCD monitor. LCD monitors flicker-free. My suggestion is that you refresh the screen flicker rate. To refresh the flicker rate, go into your System Preferences or Control Panel, click your operating system's appearance and display link and click your screen adjustment link. You may have to click your advanced settings link. Click your monitor tab and from there adjust you screen refresh rate. You may have to adjust your screen resolution before you refresh the screen rate. If you have to do this, make sure the screen resolution you choose supports you monitor's height and width as well as visibility. The higher the resolution, the higher the screen rate. The instructions I'm giving you may sound like this because I'm not sure what your operating system is. I'm not to familiar with Mac Operating Systems, but if you have a Windows Operating System and you need better detailed instructions, just reply back. I hope this decreases your screen flickering and gives you a better viewing experience.
Jul 07, 2011 | Computers & Internet
Screen flickers with lines but when i move the screen it stops
A nearby device can cause stray magnetic fields that will cause the display to be affected. A problem inside the monitor will cause the display to have problems. If somebody turns on their monitor nearby, the monitor's degaussing when it starts up will cause your monitor to dance wildly for a moment or two.
keep electronics away from your computer. Mobie phones etc. can distort the image shown on the screen for periods of time, usually when a text or call is coming through.
Sometimes if the refresh rate isnt set high enough you will see a noticeable flicker on the screen .. to change the monitor refresh rate .. you can right click on the desktop and then left click on properties .. click on the setting tab then click on the advanced tab then click on the monitor tab ..look in the drop down menu where it says 60 hertz and see if the refresh rate can be changed .. if it cant .. uncheck hide modes the monitor cant see and then click on the drop down menu .. pick a refresh rate .. 75 hertz is what i use and it should stop the flicker
Feb 03, 2010 | Toshiba Satellite A105-S4004 Notebook
Refresh rate for this monitor. Prefs. offer 60 or
Go for the highest your video card will allow to remove any flicker from the screen, or the max whichever works best.
I also have a Viewsonic Flatscreen, they are great and I had two Viewsonic CRTs before that.
Nov 28, 2009 | ViewSonic VA702b 17" LCD Monitor
New monitor flickers when hooked to computer
There's a few usual culprits for this problem.
  1. Check the cable. Swap to a different cable if possible to rule that out.
  2. Check the refresh rate of your monitor. Most monitors have options for this via a Menu button on the screen itself.
    If you find it, change it to 60 hertz
  3. Check the refresh rate of the monitor from your operating system/video card's software.
    In Windows, right click on the desktop, click Properties, then the Settings tab, then Advanced. Change it to 60 hertz if it's anything different.
It could be faulty but hopefully not.
Couple of things there to try...let us know how you go
Nov 21, 2009 | Samsung Computers & Internet
Too much screen flickering @ 1024x768 (60hz)
setup your monitor driver supplied with the monitor, you will get more options. Thanks
Oct 29, 2009 | Computers & Internet
I just bought an X223W Acer LCD monitor. The texts appear blurred on the screen. What adjustment do I need to make it sharp? Thanks.
You probably need to up the screen resolution.
Start/Control Panel/Display/Settings tab/Screen resolution.
1024X768 minimum.
While you are in the click the advanced button then click the monitor tab. Your refresh rate will most likely by 60 Hertz. Down below that you will see a "Hide modes that this monitor cannot display" check box. Check it. Now click the drop down arrow for the screen refresh rate. Set this to the highest setting there. This will stop the flicker that gives a lot of people headaches when they spend a long time at their computer.
Nov 29, 2008 | Acer Computers & Internet
Flickering screen
i had this problem & the circittree on the back of the monitor has a little ajustable screw if you ajust this till the flickering stops hope this helps
Nov 30, 2007 | Compaq FP 7317 17" LCD Monitor
Compaq FP 7317 17" LCD Monitor Logo
206 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
